humax hd2000 dish
High Definition Humax HD satellite TV receiver help and support forum.
Old 04-02-2007   #1
My System: technomate 6900 hd darkbox rev 2007 104cm gibertini dish. moteck 2100a with diseqc 12
humax hd2000 dish
hi guys can anyone please tell me what dish i need i have a humax hd2000 reciver what dish is the best so i can get all the chanels off different satilites can i run a motorised dish with this reciver thanks
den123 is offline   Reply With Quote
Old 04-02-2007   #2
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
No different to most other STBs, depends on where you want to site the dish, how much you want to spend - a motorised dish would be tops for maximum satellite enjoyment, depending on your line of sight to the arc of course.
The Humax will work fine with a dish driven by a DisecQ motor.
Llew is offline   Reply With Quote
Old 04-02-2007   #3
THANKS MATE wheres the cheapest place to buy a dish ect i live in exeter uk would a 90cm dish be ok thanks
Old 04-02-2007   #4
how easy is it to set the dish up instructions will help me thanks
Old 04-02-2007   #5
Llew's Avatar
Some helpful tips Here.
Check out fleabay for dish bargains or any UK satellite online stores.
dish, hd2000, humax
[IMG] code is Off
