India availibility of receivers,cams etcEnglish Language for discussion of anything happening on the Sub Continent. Doesn't have to necessarily be satellite related. | |
| | #76 | ||
| i'm lovin' it Join Date: 21-07-2006 Location: Colombo
My System: *90cm Dish/Twin output LNB/NSS 6/INSAT4B *Eurostar 8110 AD+CI FTA STB | It is quite confirmed that we can receive Telstar18. The supplier for max4xxx channels recommends the following; “what I recommand STB is multi-encryptiuon with 2 card slot can read Viaccess,connax,nagra vision, Media guard,.... .no more need cam module” I want to clarify the following; 1. What is multi-encryption STB? Is it same as Universal card reader STB (e.g. Eurostar EB 777). 2. In universal card reader STBs, do I have to buy modules to use with cards? (in case of multi-encryption & uni card reader STBs are different) 3. According to the channel people multy-encryption STBs doesn’t need modules. Is it true? 4. As most of you advice not to go for Eurostar, what are the other brand/models that have multi-encryption facility? 5. What is “universal module”? Can it be used will all kind of encryption cards? 6. Now, this card for max channels is Viaccess2.5. i. If I buy any STB+2CI, do I have to confirm that STB also have viaccess encrypted? | ||
| | #77 | ||
| Crazy Techie Join Date: 28-04-2006 Location: Maharastra, Hindustan
My System: AMD PC, Skystar2 2.6D, Inverto 0.2dB Single Universal Ku-Band LNB, NUCLEUS 100cm Solid Dish |
Hi Friends Does anyone having Inverto Silvertech 0.2 dB Single Universal Ku-band LNBF ? Any pointer to purchase this LNBF in India ? (http://www.inverto.tv/ProductsPage.asp?ProductID=59) Thanx | ||
| | #79 | ||
| Member Join Date: 17-08-2006 Location: India
My System: I Have new installed tatasky digicom, New Delhi | Right now i own Tatasky but unhappy due to choices i'm planing to buy a stb lnb & a dish i'm in delhi what do you recommend which model what size of dish i'm thinking 120 cm will be good for NSS6,testar, eurostar,hotbird etc please help what's the cost like...what cam will work with the stb where to buy Stb cam etc in delhi | ||
| | #80 | ||
i have ta-ta-s-k.y dtb i have chipset number can u help to unlock it Email address removed | ||
| | #81 | ||
| Member Join Date: 15-11-2006 Location: UAE
My System: Dreambox 500s, Phoenix Cardreader, Technosat T8002 | Hi, Contact me on Email address removed can I suggest that if you have information to share then share it with the forum... maybe i can help - for skystar card! | ||
| Last edited by Topper; 16-11-2006 at 01:17 AM. Reason: removal of Email address | |||
| | #82 | ||
| Regular Member Join Date: 02-05-2006 Location: india
My System: DishTV DTH Zenega 1004s Receiver 90cm offset Sharp dish antenna | please somebody help me where can I buy Dreambox, Technomate satellite receivers in india,Pune,Hyderabad? | ||
| | #83 | ||
Hi As per my search, no one having the items in India coz there was no demand for the same in India. But now the time is changing and if any of our memebers here deals with other satellite products they can start the demanding business from now. But I have imported my Skystar2 (New Version) and Inverto 0.2dB Single Universal Ku-Band LNB from SatThaiTV (www.satthaitv.com). And I had sent a mail to TRIAX India operation head based at Chennai. They gave me a dealer address at Mumbai. But they are costing tooooo high. I do know how they will survive/compete with SpacelinkIndia/Apna DTH dishes in India. For a 110 cm dish the cost is Rs 8500/- and for a 90cm dish its Rs 6500/- !!! Rather we can get the same from Spacelinkindia by Rs 3500/- Rs 1000/- respectively. So if you want any good quality items you have to import. Thanx | ||
| | #84 | |||
My System: DishTV DTH Zenega 1004s Receiver 90cm offset Sharp dish antenna | If I import from Australia as Dreambox has branch there, do you think apart from shipping , basic cost, will I be charged any custom duty? Thanx
| | #85 | ||
Hi As I know if the cost of the item is not exceeding Rs 25,000/- INR, then there will no custom duty. But for clarification go through the govt site http://www.cbec.gov.in/ for more details. And my orders are of Rs 5000/- and I have not paid anty thing for custom duty, till now. Thanx | ||
| | #87 | ||
My System: DishTV DTH Zenega 1004s Receiver 90cm offset Sharp dish antenna | You have mentioned that you are receiving different satellites apart from Nss6, is it with Zenega STB? If no what are other STBs you are having ( Manufacturer name plz )? "Zenaga STB CD1002S, Three Ku band Dish. 60Cm,70cm,90cm getting Nss6, Asiasat 3S, LMI 1, EuroBird2 at 26E" Thanx | ||
| | #88 | |||
| Regular Member Join Date: 07-07-2006 Location: INDIA
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S |
| | #89 | |||
I got my Skystar2 new version DVB-S PCI card with USB IR receiver and remote IMPORTED from w*w.SatThaiTV.com. If you are planning to import then better add other items if you need any to avoid postal cost. BOL | |||
| | #90 | |||
My System: AMD PC, Skystar2 2.6D, Inverto 0.2dB Single Universal Ku-Band LNB, NUCLEUS 100cm Solid Dish | If anyone interested apply for the same to HUMAX * w*w.humaxdigital.com | |||
| | #91 | ||
| Regular Member Join Date: 27-05-2006 Location: Mumbai (India)
My System: Dish tv network and FTA receiver | Hi mr Pradhan i am form mumbai and few days ago i went to dish market in lamington road and search there for foreign receivers but they are only selling non branded receivers. tell me that what is the cost of your receiver and which lnb is best for 60cm dish is it 0.3 or 0.5 I bought Universal receiver form market with 60 cm dish plese tell me can it possible to receive ABS sat75E on this dish thanks in adv. | ||
| | #92 | |||
Sorry friend, if you will see my system conf, you will get to know th I do not have any receiver. I ve DVB-S PCI card which is much more than a STB/receiver, but for th u need a PC ![]() See, there is a general pronciple to LNB th, the lower the noise figure in dB, better is the reception. For ex, 0.3 is better than 0.6. Now the market trend is 0.2dB, but its not available in India. I got my Inverto 0.2dB Single Universal Ku-band LNB from w*w.SatThaiTV.com. Its difficult for to receive the northen beam of ABS-1 in India, but we will get southern beam of this satellite. http://www.absatellite.net/Satellite...n-beam-big.gif http://www.absatellite.net/Satellite...n-beam-big.gif | |||
| | #93 | ||
| Member Join Date: 10-12-2006 Location: Delhi, India
My System: Zenega 1004iS Receiver + Chainees FTA STB with 60 & 120 Cms fiber dish + PIV Pc, My Sats: ABS1, NSS6, DD DTH, Mob: 9811786161 |
| Last edited by Hareesh; 17-12-2006 at 05:48 AM. Reason: Exchange your email IDs thru PMs Only. | |||
| | #94 | |||
Please help where can I get Skystar2 in india? do I have to import what is the most reliable site for importing? Thank you | |||
| | #95 | |||
![]() See friend as per my research you will not find the card in India. And no one can beat in price to w*w.DVBShop.net from Germany, which offers the lowest price across the globe and genuine brand product. And for us the added adv is that we need not have to pay European VAT. But the bitter part is.. we will ve to pay HEAVY postal fees for the same So if you consider all the facts accroding to me you will get the cheaper price at w*w.SatThaiTV.com. Both are reliable, better the DVBShop.net one :-OTill now I ve not tried with other satellites. Coz i'm finding it very difficult hadling all with ONLY two hands .... I dnt ve any tool for satellite signals too Till now I'm not sure whether my LNB is properly mounted or not ... | |||
| | #96 | |||
What I wanted to ask was "Can you modify keys so that you can receive pay channels from different satellities using Skystar2 PCI ?" Thank for providing information about the buying process for SkyStar2. | |||
| | #97 | |||
But sorry to say that there are no cracked keess ( ) for Indian Pay channels till now except B*U Movies at PAS10. But if u ve big dish and ur able to receive other continent satellites and you ve the keys then you can watch those channels. Better for keys look to w*w.rdi-keys.com | |||
| | #98 | |||
| Member Join Date: 23-07-2006 Location: INDIA
My System: NEWBE | dvb-sat cards from h**p://w*w.computerwarehousepricelist.com/productlist.asp?ctg=43 This link is for a Indian website for computer ware | |||
| | #99 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | | ||
| | #100 | |||
| availibility, cams, india, receivers |
Similar Threads | ||||
| Stay away from Dish TV India DTH DVR | iknowall | Receiver software, international Section | 1 | 25-10-2006 08:39 PM |
| Conax plans to set up unit to support CAS in India | net1 | Indian Subcontinent General Section | 6 | 17-08-2006 05:52 PM |
| India to launch heavist satellite | gameboy | Daily Satellite and Broadcast industry News | 4 | 12-07-2006 03:10 PM |
| is there Conax hack for india ? | desi_404 | Conax, Cryptoworks, Nagravision, NDS and Others | 0 | 28-01-2006 11:34 PM |
| how to watch adult channel in india | gauch21 | Adult satellite channels | 6 | 07-05-2005 02:34 PM |
