DISH TV - ZENEGA CD 1004 iS SATELLITE RECEIVER SOFTWARE
English Language for discussion of anything happening on the Sub Continent. Doesn't have to necessarily be satellite related.
Old 14-01-2007   #26
My System: NSS6,Nile Sat 1004S, Humax Windows Vista
Originally Posted by prakasht50 View Post
Dear Ghani Pak
Introducing a 2 way splitter will further attenuate the signal, preventing locking of the signal. One way out could be to increase the dish size. What if we introduced a line amplifier at the dish output. ANOTHER IMPORTANT POINT - during installation the cable fellow said he had to make modification to the receiver if it had to work here and charged me an additional KD10/- I wonder if he did anything at all ??
Best wishes to all
Dear Prakash,
Did you notice any improvment after modification to the rcvr (paying KD10)?also please let me know the result of Spliter, As suggested by Ghani.
Thanks. my email is poulsaini*hotmail.com
Marshal is offline   Reply With Quote
Old 14-01-2007   #27
My System: Humax F1 Receiver Zenith DSR310-3-4 60cm Ku dish +911126689454
For Zenega CD1004iS you will see that it is different from earlier version of 1004S. !004S direct from Handan Korea with their original settings and possibilities open for all t/p and other settings. But CD1004iS is custom made for Zee, hence some modifications were incorporated. Now a day Zee has changed quite a lot of downloading frequencies. Now the send downward signals on 12647/V/27500 with 14 channels, 12729/V/27500 with 14 channels, 12534/H/27500 with 15 channels, 10977/H/27500 with 15 channels, 12688/H/27500 with 15 channels, 12595/V/40700 with 26 channels, 12534/V/40700 with 19 channels, 11038/H/27500 with 26 channels, 11172/H/27500 with 19 channels, 12688/V/27500 with 13 channels, 12647/H/27500 with 13 channels and 12595/H/40700 with 14 channels. Out of these 202 chanels they carry 161 TV Channels, 26 Radio Channels and 15 are Network identification channels. If your receiver is capable of tuning into any of their network signal channel your set certainly will tune into all channels. But if you tune any individual frequency mentioned above your set will be tuned only to that bunch of channels which are mentioned on that frequency. More next time
bcjain99 is offline   Reply With Quote
Old 15-01-2007   #28
My System: Zenega CD1004iS, NSS Dish, Evision thomsom setop box.
are you sure the philips LNB will work
Originally Posted by ViReN View Post
use a 4.5 dish and Philips LNB, the Zenga Recever is one of the cheapest (Dish TV gets it for around Rs. 300 in bulk... ) and it is sold for around Rs. 3500 ... (10 times the cost)
Hey viren,
are you sure the philips LNB will work...cos I'm feed up already ...i've tried so many LNB's from Eurostar.....various models ...but non seem to work.
Also I have an NSS disch set up and the installation is all ok...but I have bad signal quality and strength.
Whats this talk from ghani pak that the two way splitter will help !...
I'm lost and I need help./...this is getting frustrating.
silver_salmon is offline   Reply With Quote
Old 15-01-2007   #29
Originally Posted by Marshal View Post
Dear Prakash,
Hey Prakash,
let me know whether the splitter option worked or not...cos I'm having the same problem.
Old 15-01-2007   #30
My System: Zenega CD1004is
I tried introducing a 2 way splitter but it did not work. In fact there was a deterioration in the picture quality with the splitter in the line. Then i tried connecting a line amplifier in the cable connecting the LNB to the rceiver - neither did that work. The only other option is to try making fine adjustment to the dish alignment. If anyone has any new ideas PLEASE SUGGEST
With Good Luck to all Zenega 1004is owners
prakasht50 is offline   Reply With Quote
Old 16-01-2007   #31
Hareesh's Avatar
My System: Sat:Insat 4 B and NSS 6 Platform:DD Direct+ STB:Eurobox 9700+CI System:Celeron D 2.8 GHz,Fedora Core 6 and Windows Vista Home Premium Edition.
Moved
This thread is moved here so that more members can read the posts.
Thnx.
Imagination is more important than knowledge...
Albert Einstein
Hareesh is offline   Reply With Quote
Old 16-01-2007   #32
SATELLITE SNIFFER
mehra's Avatar
My System: Dish Tv complete equipment- 70 cm Ku Antenna, Kaon KSC-i260 MCO, Two Dish Tv OE universal LNBF, 6' C Band Antenna, Eurostar C band LNB. All attached to NSS6-ABS1-Thaicom
Smile
Originally Posted by nithkumar View Post
Please any one help me.
In my Zenega4s receiver (Dishtv -India) after software upgrding i could not Edit the TP & Not able to introduce New TPs, satellites,Datas,
If any one knows the method please reply & mail me.
With old verson software i could ADD New TPs & Satellites, but after the software upgrad i could not.
Please reply to nithkumar_s*yahoo.co.in
Advance Thanks
U CAN GET THE SOFTWARE D-GRADED TO OLDER VERSION. BUT IF U KNO SOME PROPER GUY TO DO IT. U MAY NEED A SAME MODEL STB LOADED WITH OLD VERSION SW. I JUST TOLD IT COZ IT'S POSSIBLE. U GET THE RIGHT PERSON OR NOT TO DO IT IS ANOTHER ISSUE.
CHEERS
mehra is offline   Reply With Quote
The Following User Says Thank You to mehra For This Useful Post:
depak5 (20-07-2007)
Old 16-01-2007   #33
member91040's Avatar
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S
Yes get the right person, Ones just checkout the old threads.
member91040 is offline   Reply With Quote
Old 16-01-2007   #34
Site administrator
Analoguesat's Avatar
ANd once you have downgraded it - it will automatically upgrade again!
Analogue forever!
Old 16-01-2007   #35
Yes I too got , the same dought.
Old 17-01-2007   #36
Tata Sky IN Midle East
Since many ppl including myself are tired from zenega1004is/dishTV.Lets find out if any body managed to set up tata sky in M eastren countries.Please post here ur findings/possibilties etc.
Old 17-01-2007   #37
Site administrator
This thread has drifted enough already - take any such discussions onto a new thread.
Analogue forever!
Old 17-01-2007   #38
Sory Analog! I did post without forum serch. the info is available here
Sky" target="_blank">http://www.satellites.co.uk/satellit...light=Tata+Sky
Old 19-01-2007   #39
My System: dishtv
i am using zenega 1006s..but i couldnt upgrade my package..it says download fail..can i install from zenega 1004s with data cable..pls let me no how to do it..pls help me..
keyovalu is offline   Reply With Quote
Old 23-01-2007   #40
SATELLITE SNIFFER
mehra's Avatar
Talking
zenega will get upgraded if u tune to some dish tv transponder. watching only dd+ channels wont upgrade it . kaon is better . it would not upgrade even if u watch dish tv unless u factory reset it .
cheers !!
Old 23-01-2007   #41
Site administrator
cheers !!
That can be changed easily enough in a future software upgrade - the UK Sky boxes reset themselves overnight to load new software!
Analogue forever!
Old 23-01-2007   #42
fkp
Upgarde
new upgrade now works for select diseq switch means now u can have more dish over zanega just upload the last version and also inter active is increase for all the packages good work dish people keep the good things go
fkp is offline   Reply With Quote
Old 23-01-2007   #43
For All Zenega STB.
Old 22-02-2007   #44
amritlad's Avatar
My System: NSS 6
Pl anybudy have zenega cd1004is old software then mail.
thnx
amritlad is offline   Reply With Quote
Old 23-02-2007   #45
My System: television and networking
I need same.. and tell me.
I have zenega Cd-1005s receiver I want upgradate It from NSS-6 through Dish tv plate from. it is not provide from dishtv. It is Conex Embeded and same as Dish TV IRD. can i Do through go Dish Tv Frqncy or Not? I tried locked it but not upgraded. showing DD direct chennels. somebody have idea for R and D please give me...
I will flow and go to result. it may be we will to a good destination.
spl Thanks to 910240/analoguesat/mehara/lokesh/hareesh..for their good afort to forum.
Regards
Naren
nv_karma is offline   Reply With Quote
Old 24-02-2007   #46
SATELLITE SNIFFER
mehra's Avatar
Wink
Regards
Naren
karma u r proceeding to the right direction. and i dont understand why were u confused . just give the filename as zenega and save. power on stb and downloading starts. when it' s 100% finished, its over. now rename the saved file to zenega.bin. Done . u can call me if u wish to. where do u live ?
regards.
alamgir80 (02-05-2009)
Old 24-02-2007   #47
My System: Box-»SrarTrack World in Box(S170EC) Soft-»(STM_A6690) Sat's-»13.0E,26.0E,95.0E,105.5E
Originally Posted by silver_salmon View Post
Hey viren,
Sorry for a late reply. you should have a atleast 4 feet dish, perfectly aligned. the LNB should be rotated to get max signal.
Also, you should have a dedicated cable without any spliters etc or any thing...
The bad Quality of signals is not always due to the LNB and Cable, but mostly due to the poor quality of Zenga recevers that are supplied with the Dish TV.
If you check the signal strength of a particular frequency with any other reciver.... i have tested in Star Track (World in Box) ... results very very much....
Star Track shows 85%.... Zenga shows 45%... rest is lost some where INSIDE the recever.
ViReN is offline   Reply With Quote
Old 24-02-2007   #48
Regards
Naren
karma Bro, What is the Signal Strength, Did you scan the whole tps.
Old 24-02-2007   #49
Till now zenega did not replyed any thing like that to any one, May be star track, having some extra strength, Why dont you try it one more other receiver for the final result. & Let us know.
Old 25-02-2007   #50
Locked for various TP 66-73%. Yes Whole TP i've Saved and Search to all.
I tried once agian after ur ulert. still its not upgrade.
1004, dish, receiver, satellite, software, zenega
