DISH TV - ZENEGA CD 1004 iS SATELLITE RECEIVER SOFTWARE
English Language for discussion of anything happening on the Sub Continent. Doesn't have to necessarily be satellite related.
Old 25-02-2007   #51
My System: television and networking
Dear Mehra
karma u r proceeding to the right direction. and i dont understand why were u confused . just give the filename as zenega and save. power on stb and downloading starts. when it' s 100% finished, its over. now rename the saved file to zenega.bin. Done . u can call me if u wish to. where do u live ?
My Id at yahoo co in mail me your con number..! or check Pm
nv_karma is offline   Reply With Quote
Old 26-02-2007   #52
My System: Box-»SrarTrack World in Box(S170EC) Soft-»(STM_A6690) Sat's-»13.0E,26.0E,95.0E,105.5E
Originally Posted by member91040 View Post
Till now zenega did not replyed any thing like that to any one, May be star track, having some extra strength, Why dont you try it one more other receiver for the final result. & Let us know.
Yep ... Done that .... and the result is same... I have old EuroBox 9700 Gold... and the results are same....
Even the Older KAON brand DISH TV recevers are good...
I have also checked with other friends recievers (3 of them at that)... and they all show less % signal strength and quality...
been there... done that ... and finally had to find a better gain LNB....
i checked many things at TELE-satellite mag..... and ultimately was able to get a better LNB....
ViReN is offline   Reply With Quote
Old 27-02-2007   #53
software upload...
regards.
Dear Mehra,
Thnks I got result as you have suggest me was well. Carry on ur some more tips please..
Old 27-02-2007   #54
member91040's Avatar
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S
What is your next step after this ?
member91040 is offline   Reply With Quote
Old 28-02-2007   #55
My System: Zenega CD1004iS, NSS Dish, Evision thomsom setop box.
thanks for your info , please clarify further
Originally Posted by ViReN View Post
Sorry for a late reply. you should have a atleast 4 feet dish, perfectly aligned. the LNB should be rotated to get max signal.
Also, you should have a dedicated cable without any spliters etc or any thing...
The bad Quality of signals is not always due to the LNB and Cable, but mostly due to the poor quality of Zenga recevers that are supplied with the Dish TV.
If you check the signal strength of a particular frequency with any other reciver.... i have tested in Star Track (World in Box) ... results very very much....
Star Track shows 85%.... Zenga shows 45%... rest is lost some where INSIDE the recever.
So let me ask you how to go abt this
- If I get the zenega CD1004S receiver from back home
a. would it help?
b. I would just have to use my smart card on this reciever- correct
c. How sure are the ppl on this forum, that this particular model has better reception
quality??
d. is there any other smart card recievers that work on the dish network other that the
zenega brand. If so , which models?
- on the zenega Cd1004iS receiver , if I get the Philips LNB like you had suggested
earlier, would there be a significant improvement in quality of the reception??
For your info I have a 6 ft NSS dish properly aligned, no splitters attached. Also could you give me the model no of the philips LNB so that I could check in the UAE market and also rough estimate of the price...
Appreciate your prompt response to the abv and appreciate your support as well.
Thanks and best regards
Silver_Salmon
silver_salmon is offline   Reply With Quote
Old 03-03-2007   #56
My System: Dish_TV,Zenega CD1004iS, Sony Playstation2 SCPH70006CB, Nikon Coolpix 2.0,Iomega Mp3
Angry Zenega 1004iS has become a big headache...
Hi All,
I am also facing the same problem with ZENEGA 1004iS receiver which I got frm india and after installing a 6 Ft dish and changing the LMB, the signal quality is still weak and I can receive only few channels some maybe paid, though I have taken a full package in India, numerous phone calls hv gone waste.The message that you settop box is not connected to dish appears, on ok for channel search it gives message that some transponders are not loaded.In STB info it gives message of quality of signal at 62 and 55 resp.but i cant get zee/max channels.Is it a problem of LMB?the cable guy has no clues..can somebody help, before I miss my cricket matches...PLEASE
rahul0910 is offline   Reply With Quote
Old 03-03-2007   #57
Hi Viren,
Tell me if you are able to use the dishTV to get all channels in MCT? I wanna use one in Bah, but am still stuck with it...
Old 03-03-2007   #58
Site administrator
Analoguesat's Avatar
Originally Posted by rahul0910 View Post
Hi All,
A classic sign of insufficient signal. Better alignment or more probably a bigger dish needed.
You *may* get away with just buying a better lnb but I doubt it.
Analogue forever!
Old 03-03-2007   #59
My System: NSS6,Nile Sat 1004S, Humax Windows Vista
Smile 1004is is a time waste in M. east
Hi All,
Dear Rahul,
Please go through this thread from begining (Indian Dth In Middle East) and dont waste yor time and money on 1004is. as mentioned earlier, this model is not working in Midle East, I can tell for sure that this will not work in Bahrain(Unable to find the reason,dspite extensive reserch). Try to get any older model of Zenega or any model of Kaon. you can PM me for further discusion or u can call me on phone number removed - admin
Marshall
Bahrain Resident.
Marshal is offline   Reply With Quote
Old 03-03-2007   #60
asdf68's Avatar
My System: NSS6,DISH TV INDIA,KAON KSC-i260MCO
DEAR MARSHAL,
IT SEEMS YOU ARE WELL AWARE OF DIFFERENT TYPES OF DISH TV RECEIVERS ,D SOFTWEARES AND LNBS.I HAVE BEEN FOLLOWING YOUR POSTS REGULARLYWITH INTREST.I NEED YOUR ADVISE.I AM USING ''PREMIUM X'' UNIVERSAL KU BAND QUAD LNB(WITH 4 PORTS).WE HAVE CONNECTED 2 KAON RECEIVERS (ME AND MY FRIEND) AND OTHER 2 PORTS ARE FREE.WE ARE GETTING ALL TP s VERYWELL EXCEPT THOSE 2 TPS WHISH ARE TRANSMITTING SONY CHANNELS AND ZEE CINEMA,HBO,CARTOON NETWORK ,TCM .I AM GETTING THESE CHANNELS CLEAR DURING SPECIFIC TIME OF THE DAY LIKE FROM 11 AM TO 6PM.AFTER THAT UP TO 9.30 PM, THESE CHANNELS GET SCRAMBLED AND THE SIGNAL QUALITY SHOWS BETWEEN 52 TO 55.WHEN THE SIGNAL QUALITY BECOMES ABOVE 56,I GET THESE CHANNELS CLEARLY.FROM 9.30 PM TO 12.30 AM AGAIN I GET THEM CLEARLY.WHT DO YOU THINK IS THE POSITION OF THE SATELLITE CHANGES DURING DIFFERENT TIMES OF THE DAY?BY REPLACING MY 4 PORT LNB TO 2 PORT LNB,DO U THINK THE SIGNAL STRENGTH WILL IMPROVE?WHAT CAN BE DONE TO IMPROVE SIGNAL STRENGTH?MY FRIEND IS USING KAON RECEIVER WITH LATEST SOFTWEAR WHICH IS HAVING ACTIVE SERVICES FACILITY AND HE IS GETTING SONY CHANNELS WITHOUT INTRUPTION 24 HRS.MY KAON RECEIVER IS HAVING OLD SOFTWEAR. DO YOU THINK UPGRADING MY RECEIVER WITH NEW SOFTWEAR WILL SOLVE THE PROBLEM? I NEED YOUR OPINION.I AM ALSO A RESIDENT OF BAHRAIN.
asdf68 is offline   Reply With Quote
Old 03-03-2007   #61
Site administrator
Please do not type all in capitals. Its consider to be "SHOUTING" - and is difficult to read as well...
Analogue forever!
Old 03-03-2007   #62
asdf68's Avatar
Thanx for your advise.
Old 03-03-2007   #63
Originally Posted by asdf68 View Post
DEAR MARSHAL,
Dear asdf,
I dont see anything wrong with ur LNB, as long as it is a Quad LNB (_http://www.satlex.us/en/lnb_types-type_uni_quad_lnb.html) and not Quatro LNB(
_http://www.satlex.us/en/lnb_types-type_uni_quattro_lnb.html . some signal fluctuation is always thier due to diff. factors(air density at diff times,if location surounded by high rise buildings an obscuring the line of veiw from ur dish to sat, improper alignment of dish and LNB, wind speed VS strength of hardware/brackets/holding the dish etc.) but this fluctuation is noticable only on weak signal Sat's(being out of sat footprint). u can try with single LNB (I M using Lucky Star 0.3db, available for BD1.500 only) and see if there is any improvement.also to rais the height of dish(increase the clearance between dish and ground/base, done the trick for me)
so thats all i can suggest for this time , best of luck with R&D :-).BTW I dont have much hands on experience with kaon , so cant say anything on kaon SW issue.
thx
Old 03-03-2007   #64
asdf68's Avatar
Dear Marshal,
Thank you for your opinion.I tried Lucky star lnb before going for premiumx lnb.I feel this is much better than Lucky star lnb.I would like to know which receiver you are using and how is the reception especially 12647/H/27500 and 12595/V/40700.
Thank you once again
Old 03-03-2007   #65
Thumbs up Hi Marshall
Originally Posted by Marshal View Post
Dear Rahul,
Marshall
Bahrain Resident.
Marshall,
I too am a BAH resident, and luckily I have found the SOLUTION of how u can get all channels on 1004iS in Bahrain, Its very simple, i just saw it work today, Its not the dish, actually You need to support the 1004iS with another set top box in tandam which is available for 20 BD...I will tell you all complete details in my next thread tommorow
Old 04-03-2007   #66
Hi Rahul,
I am holding my breath to hear from you the solution of 1004IS mystry, which was so far considered a "mission Impossible"(at least by me).Please post here the detailed outcome for the benifit of all other member's who are disappointed by the purchase of 1004IS.
Thx.
Old 04-03-2007   #67
My System: Satellite
Please Help Me
I,m in saudi arabia ('Abha' Southern Region), since long time iam not able to install
"dishtv of india" which is on (NSS 6 95°E), i used KU Band .3 db DANSAT LNB,2.4 Meter Dish,
2 STB (Dishtv STB,HUMAX STB) but no use always i get status 0% signal strength, where as
ASIASAT 3S (105.5°E) (SAHARA CHANNEL) workS fine with same dish, humax stb and C band LNB,,,
I changed even lnb and tried but no use, i wonder (Conax,Mediaguard) Video Encryption needs
special dish or what....
Please,, Please help me out because i lost till date three month, i have only three months
more on my smart card,,
email address removed
sharza is offline   Reply With Quote
Old 04-03-2007   #68
asdf68's Avatar
Hi Rahul,
what about channels on Tps12647/H/27500 and 12595/V/40700.
Are you getting them day and night without cutting?
Old 04-03-2007   #69
Site administrator
PLEASE lads - do not post email addresses for info to be sent direct - any non private info should be available to all the members on the forum.
Analogue forever!
Old 05-03-2007   #70
HI
Normaly it s happen when u r wire is not long like in villas where the dish in on the roof and receiver is down. and problem is only in Zenega CD 1004IS other dish tv receiver is ok. Just do one thing put one two way spilliter. put dish wire into input of spillitr and use any one output to connect receiver. This method is very strange but it will work 100%. This i m doing in sharjah UAE. Please do this and give me u r answer.
Thanks and best regards.
ghani_pak is offline   Reply With Quote
Old 05-03-2007   #71
asdf68's Avatar
Originally Posted by ghani_pak View Post
HI
This method is for which problem?
Old 05-03-2007   #72
Hi asdf68
In middle east like uae qatar and behrain with Zenega CD 1004IS we r not getting all channels but if we put other receiver like kaon every thing is perfect with same dish and LNB this problem only with Zenega CD 1004IS so i found this salution and personaly used this in 10 to 15 places. i hope u will undersatnd our problem.
Old 05-03-2007   #73
asdf68's Avatar
Hi asdf68
Hi Ghani_pak,
Thanx for ur idea.One of my friend brought Zenaga cd 1004 IS recently.i am using kaon and i am getting reasonably good signals except in two frequencies which i mentioned in my ealier posts in this thread.when i tried my friends zenega stb with my dish,it is receiving only few star channels .He is getting his own dish installed today.I will pass on your advise to him
Old 05-03-2007   #74
Hi Ghani_pak,
I Think Zenaga is Eating Signal, I have came to here from other guys too.
Old 06-03-2007   #75
email please
Hi asdf68
your email please
1004, dish, receiver, satellite, software, zenega
