DISH TV - ZENEGA CD 1004 iS SATELLITE RECEIVER SOFTWARE
English Language for discussion of anything happening on the Sub Continent. Doesn't have to necessarily be satellite related.
Old 06-03-2007   #76
member91040's Avatar
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S
Bro No mail id would be allowed here...!
member91040 is offline   Reply With Quote
Old 06-03-2007   #77
My System: Satellite
Mr.Ghani,
what is the dish size and which LNB to view Dish TV, B'Coz iam far away from you ("ABHA",KSA)
sharza is offline   Reply With Quote
Old 06-03-2007   #78
email id
Sorry I Don't know that
Old 06-03-2007   #79
asdf68's Avatar
My System: NSS6,DISH TV INDIA,KAON KSC-i260MCO
Hi Marshal and Rahul,
Hows the channel reception on TP 12647/H/27500 and 12595/V/40700(Sony channels ,HBO,TMC,CARTOON NETWORK).
asdf68 is offline   Reply With Quote
Old 06-03-2007   #80
My System: NSS6,Nile Sat 1004S, Humax Windows Vista
Dear Sharza,
1.8 Meter offset dish and Philips/LuckyStar 3db LNB's are working fine in Bah.As long as 1004is is concerned, I am waiting some input from Rahul, he is the only person, I came across, for whom this reciever is working. so only he is the person who can shed some light on this.
Dear Ghani Pak,
I have tried the option suggested by you but this is not working for me.
Bye
asdf,
All these channels are working for me normally, except when strong wind or rainy season exists.
Marshal is offline   Reply With Quote
Old 06-03-2007   #81
asdf68's Avatar
Dear Marshal,
As ur getting Sony and HBO,I presume that you r getting all other channels as these two TP s are with low signals.Let me know wts the problem for which ur looking for solution
Old 06-03-2007   #82
Originally Posted by asdf68 View Post
Dear Marshal,
I am using zeng1004s with no Prob. I m looking for solution for the use of Zenaga 1004is (A particular model of zenaga,which is not working for the most of the users in M East).
Old 06-03-2007   #83
Hi marshal,
Try to retune u r Zenaga 1004is again.
ghani_pak is offline   Reply With Quote
Old 06-03-2007   #84
I am once again replying dear friends, Zenaga Eats Signal.
Old 07-03-2007   #85
Dish tv In Jeddah
Originally Posted by Marshal View Post
Dear Sharza,
Dear Marshal,
I used KU Band 0.3 db DANSAT LNB,with 2.4 Meter Dish, and
Dishtv STB ( ZENEGA CD 1004 iS ), but no use always i get status 0% signal strength, where as ASIASAT 3S (105.5°E) (SAHARA CHANNEL) Works fine with same dish, humax stb and C band LNB i used for ASIASAT 3s,,,
but you said 3db lnb (is it 3db, or 0.3db), are you using dishtv in KSA, Because except Dammam all other area is too much far from the beams and i am in Abha Border of yemen....
Old 07-03-2007   #86
Anybody using DishTV in Jeddah Region
Old 08-03-2007   #87
Location: Pune (Latitude: 18° 28'N, Longitude: 73° 52'E), Maharashtra, India
My System: DishTV Zenega CD1006, Airtel digital TV
This is an interesting thread but drifting away from it's title
curious is offline   Reply With Quote
Old 10-03-2007   #88
asdf68's Avatar
Dear Rahul ,
It 's 6 days since you posted ur last message.We are all waiting to hear from u about the new set top box u attached to Zenega
Old 11-03-2007   #89
My System: Dish_TV,Zenega CD1004iS, Sony Playstation2 SCPH70006CB, Nikon Coolpix 2.0,Iomega Mp3
Zenega
Hi friends, i m sorry that i didnt reply earlier as I was too busy....anyways I have installed zenega 1004iS here at home in Bah and I am getting all the channels like dishTv interactive, Zee, Sony, Max and all. It took the dish guy sometime to fix it up, and the secret is that he used another settop box SATCOM make and he connected the dish cable to it and than a loop from it to the dishTV settop box, and Dish TV settop to power, so the new settop box isnt powered, and its just a normal LNB used and I m getting very good reception, only problem is during mornings when the signal is weak...dont know why, but it becomes normal by 10 AM. The cable guy says that he does some tweaking in the second settop box he installed, but he isnt letting the secret out...so maybe with Marshall, we can chk out the secret.....
But one thing is for sure.........u can get Zenega 1004iS work here in middle east. i m seeing it here, so thats the proof....
rahul0910 is offline   Reply With Quote
Old 11-03-2007   #90
Dear Rahul ,
Hi asdf,
Call me at my number phone number removed -admin so we can discuss about yr problem.
Old 12-03-2007   #91
amritlad's Avatar
My System: NSS 6
Dear Rahul Thnx for zenega 1004 si solution but u r talking for settop box SATCOM make. but what is the model # for that settop box. pl specify. thnx again
amritlad is offline   Reply With Quote
Old 13-03-2007   #92
My System: 2 dishes one for hotbird,nilesat & arabsat and one for DISHTV
i am from Kuwait Had DishTV installed recently. Have a 6 foot dish and .2db GoldStar(Lemone) LNB installed. I was able to view some of the channels and most of them could not be viewed. The Technician informed me that the chip had to be upgraded and after updation I have been able to watch almost all channels. So if ur in Kuwait suggest you to go to Hawally and update the chip. They charge KD 5
yesrkay is offline   Reply With Quote
Old 13-03-2007   #93
Smile ZENEGA1004iS
Dear Amritlad,
The connections for Zenega1004iS goes like this Cable wire goes to IS in of another Digital Satellite receiver STARSAT (its not SATCOM which I wrote earlier by mistake) MODEL NO. SR-X4000D (made in Korea) and from this receiver's IS out same type of cable goes to Zenega1004iS (in teminal) and than on to TV. If you can buy this receiver you can try this method. But donot power the STARSAT model...Just put Zenega on power. Its a much cheaper option than splitter method. The dish is a 6 ft one on top. Check this out and let me know too.
Thanks.
Old 13-03-2007   #94
Dear Rahul
The spilliter price is 5 Dhs and the starsat 4200 is nearly 100 dhs so which is cheaper receiver or spilliter. Just go to market and check it then tell which is cheap.
Thanks and best regards.
Old 13-03-2007   #95
Zenega1004iS
Originally Posted by ghani_pak View Post
Dear Rahul
Dear ghani_pak,
I dont know who has quoted you that price, what I know is that splitter which is available at DXB and the settop box etc you have to buy costs more than 120 Dinars. Where as this settop box is easily available in market, for about 20 BD
Old 13-03-2007   #96
Dear Rahul,
Spilliter is just a devider which is used for devide one wire into two receiver and its commonly use for deviding arabsat c-band, and normaly we r saying two way spilliter or four way spilliter and its more cheap than diseq switch.
120 dn means more than 1200 dhs does it make sence that a normal devider this much cost. Please kindly check in any dish shop near by u.
I hope u will understand what is spilliter or devider.
Old 14-03-2007   #97
OdiYaN
My System: ZENEGA DISHTV
Cool Simple Signal Amplifier
Hi guys,
I figured to find a solution for the two frequencies in Zenega,
1) Get a splitter open it from the back side remove all connection from it.
2) get a insulated copper wire of medium guage, ( telephone or Network cable wire ok)
3) make ten turns on a pencil or a reynold ball point pen
4) solder the two ends to the spliter outputs (leave the input free)
5) make a small gap after the fifth winding. connect one end to lnb and other to the receiver
6) now you got to STB info and select red button for setup,
7) select hometransponder and adjust the winding gap till you get a quality of above 60%.
Its works in abudhabi UAE, fully tested, you need some patience in adjusting, and use a good LNB, noting like global, universal etc, use philips if you get it.
OdiYaN
odiyan is offline   Reply With Quote
Old 14-03-2007   #98
My System: Zenega CD1004iS, NSS Dish, Evision thomsom setop box.
Originally Posted by odiyan View Post
Hi guys,
OdiYaN
hey Odiyan,
I am also from abu dhabi , I'm really intersted to make my Dish TV to work properly and recieve all the said channels....could you try calling me on my mob 050 5460730 and we can discuss over the phone and clear up all doubts. if you don't mind that is...
When you say splitter , do you mean the dividers you get for 10 dhs on electra street...cos thats where I bought my splitter from. Or is it something else all together?
PLease call me and we can discuss better over the phone.
Silver_Salmon
silver_salmon is offline   Reply With Quote
Old 14-03-2007   #99
OdiYaN
yes the normal splitter which is available for 10dhs
Old 14-03-2007   #100
Do you have the step by step pictures along with the instructions, it would really help a great deal.
1004, dish, receiver, satellite, software, zenega
