DISH TV - ZENEGA CD 1004 iS SATELLITE RECEIVER SOFTWARE
English Language for discussion of anything happening on the Sub Continent. Doesn't have to necessarily be satellite related.
Old 14-03-2007   #101
My System: ZENEGA CD-1004S
How to prevent upgradation of zenega 1004S software?
where can i get fun smart cards and programmer in india maharashtra
dineshvjoshi is offline   Reply With Quote
Old 14-03-2007   #102
member91040's Avatar
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S
Dont Tune it to nss, you can stop upgradation,. No way to find programmers in india.
member91040 is offline   Reply With Quote
Old 14-03-2007   #103
My System: dISHTV
Hi
I too am in Kuwait and recently bought dishtv receiver from india and would like to know whether i can view few sports channel using nilesat after updating the chip and what is the name of the shop in hawally.
thanks
Michael
MichaelMoses is offline   Reply With Quote
Old 15-03-2007   #104
thanks
Michael
No Bro It cant be possible to view.
Old 15-03-2007   #105
My System: dISHTV
Originally Posted by yesrkay View Post
i am from Kuwait Had DishTV installed recently. Have a 6 foot dish and .2db GoldStar(Lemone) LNB installed. I was able to view some of the channels and most of them could not be viewed. The Technician informed me that the chip had to be upgraded and after updation I have been able to watch almost all channels. So if ur in Kuwait suggest you to go to Hawally and update the chip. They charge KD 5
Mr. Yesrkay, i too live in Kuwait and would like to know the satellite or Dish position you have set your DishTV. Meantime, please let me know the name of the shop in Hawally from where you have updated the chip.
Old 16-03-2007   #106
SATELLITE SNIFFER
mehra's Avatar
My System: Dish Tv complete equipment- 70 cm Ku Antenna, Kaon KSC-i260 MCO, Two Dish Tv OE universal LNBF, 6' C Band Antenna, Eurostar C band LNB. All attached to NSS6-ABS1-Thaicom
Exclamation
Guys I Suggest To Make This Thread Named As Dish Tv Receiption In Mid-east. This Will Give Other Members A Benefit And A Meaningful Topic. Analoguesat Plz C If It's Possible.
mehra is offline   Reply With Quote
Old 17-03-2007   #107
You are right bro, Many middle east guys getting heavly problem, soo it would be better to helpful for every new or old member to find it.
Old 17-03-2007   #108
asdf68's Avatar
My System: NSS6,DISH TV INDIA,KAON KSC-i260MCO
Originally Posted by odiyan View Post
Hi guys,
I figured to find a solution for the two frequencies in Zenega,
1) Get a splitter open it from the back side remove all connection from it.
2) get a insulated copper wire of medium guage, ( telephone or Network cable wire ok)
3) make ten turns on a pencil or a reynold ball point pen
4) solder the two ends to the spliter outputs (leave the input free)
5) make a small gap after the fifth winding. connect one end to lnb and other to the receiver
6) now you got to STB info and select red button for setup,
7) select hometransponder and adjust the winding gap till you get a quality of above 60%.
Its works in abudhabi UAE, fully tested, you need some patience in adjusting, and use a good LNB, noting like global, universal etc, use philips if you get it.
OdiYaN
Hi odiyan,
After removing back cover,i found small cicuit chip.Should I remove whole chip?where to solder the wire to the out puts?inside or out side?if i remove all conections inside,how the signals pass from input to out put?u asked to connect one end to lnb and other one to receiver.Do u mean out put no1 to lnb and output no 2 to receiver? I am totally confused .Please explain the process in detail
asdf68 is offline   Reply With Quote
Old 17-03-2007   #109
SATELLITE SNIFFER
mehra's Avatar
Exclamation
Originally Posted by asdf68 View Post
Hi odiyan,
asdf u seem 2 b doing something complicated . take care for what u do. better contact ur buddy on phone, discuss whole thing so u dont damage ur equipment.
regards.
Old 17-03-2007   #110
My System: w
Hi guys,
OdiYaN
Could u plz upload the pictures of your splitter
jassi2000 is offline   Reply With Quote
Old 18-03-2007   #111
OdiYaN
My System: ZENEGA DISHTV
Splitter Pic
regards.
OdiYaN
DISH TV - ZENEGA CD 1004 iS SATELLITE RECEIVER SOFTWARE-if_line_amp-jpg
odiyan is offline   Reply With Quote
The Following User Says Thank You to odiyan For This Useful Post:
jobinjv (01-11-2008)
Old 18-03-2007   #112
asdf68's Avatar
Hi odyan,
I made some modification to your idea and i am now getting good signals especially sony channels tp.hbo and cartoon network tp signals also improved but not as great as sony tp.After removing the back cover,i made coiled wire as described by u,but i soldered one end to input and one end to out put.I attached lnb to input and receiver to out put.i kept other output free.By moving the both ends of the coil up and down (towards input side or outputside)i can adjust the signals.U have done a great job and keep it up.
Old 19-03-2007   #113
fkp
Conax
u can do uprade any reciver cas to work conax possible with some knowledge of know how RSA needed only
fkp is offline   Reply With Quote
Old 19-03-2007   #114
My System: I HAVE INSTALL DISH TV CONNECTION WITH DD DIRECT+ AND HAVE COMPUTER
please anyone tell me the password of kaon stb comes with dishtv
SAT_AGT is offline   Reply With Quote
Old 20-03-2007   #115
My System: A comuter networking guy
hi
Anybody knows or tried how to use Dishtv smartcard on a differnt STB, I tried with Conax CA on Humax and it doesnt work. Any idea how to solve this
subair12 is offline   Reply With Quote
Old 21-03-2007   #116
My System: needs to explore
Zenega CD1004iS
Dear All,
I am having a Zenega CD1004is for DishTV. Now when I plug the power, the orange and the green light is blinking, seems to be some problem with software and it is not switching on. Could you please advice on how to reload/reset the software from computer. If anybody is having the software, please send the same and the instructions for doing the same.
Thanking you in advance.
madhuk is offline   Reply With Quote
Old 29-03-2007   #117
I think this happens when the receiver goes into the upgrade mode and it does not receive strong enough signal to do the upgrade. I have had the same problem and the receiver goes into an endless loop of looking for signal. The solution to get it back to normal mode is simple. Just remove the lnb cable while the receiver is doing that, and wait for few seconds. When you see the DishTV logo on the bottom right corner of the TV screen, put the cable back. The receiver should be normal now. Hope this helps.
mcruiser is offline   Reply With Quote
Old 12-04-2007   #118
ಕನ್&#32
kannadiga's Avatar
My System: ಡಿಶ್ ಟಿವಿ ಜೀನೆಗ 1005S ಮತ್ತು ಟಾಟಾ(ಸ್ಕ್ಯ್ ತಾಂಮಸನ
help me
I tried to load Software version 1.56 software for Zenega 1004IS but i am unable to load the software. In this possess receiver light blinking in yellow and red.
best regards
kannadiga is offline   Reply With Quote
Old 15-05-2007   #119
My System: Zenega 1004is
Cool
Hi guys,
I also installed a Zenega 1004is in Kuwait.
Am getting two to the transponders at 75% - the second last and third last transponders, i.e.:
11172 27500 Horizontal
11038 40700 Horizontal
The remaining are 1% - 3% (including the "home transponder")
As of now, I am not getting ESPN (I can view it on the split screen from active on Star Sports), Sony TV and Zee TV
So which one will be a better solution:
1. The splitter theory
2. Getting the circuit fixed
3. Both
I have seen the forums and saw guys improving their reception thru the splitter, but their home transponder signal was slightly there
Plus, even I was getting the 303 Error message; "Services not installed"
What I did was just switch off the main power for the set top box from the wall (not the receiver)
Hold the 'menu' button on the remote
Switch the power on
You should turn the power on then off quickly, otherwise it will give the 303 message again
This way, when the two transponders were identified, I changed the home transponder by pressing 7531 and inserting the transponder frequencies of the strongest one
Then I switched off the power with the remote and then turned it on again. The receiver started searching for channels and identified 32 channels
But I am aiming for getting all the channels
Last edited by prof_raza; 15-05-2007 at 02:02 PM. Reason: Entering the transponder frequencies
prof_raza is offline   Reply With Quote
Old 15-05-2007   #120
asdf68's Avatar
Hello prof,
Try the splitter as modified originally by odiyan.I am using it and my signal strength got improved.He uploaded the pic of the pic also.Try it before embarking on anything else.This is cheap and effective.Good luck
Old 15-05-2007   #121
Thanks. Will give it a try.
I have got hold of a disposed 2 / 4 splitter from the terrace. Guess that should do the trick.
Next stop is to get a solder iron
Old 19-05-2007   #122
I tried the splitter - did not work
I got the IC resoldered. The receiver showed all the channels, but there was a message "Bad Signal" on most of them. Did a channel search, and then they disappeared again !
Now I am again stuck with 42 channels, and being able to see ESPN on the active split screen
Old 21-05-2007   #123
My System: television and networking
Dear all, can we copy smart cart through smart card reader of any stb what is in it ?..
If anybody have idea pls reply..
nv_karma is offline   Reply With Quote
Old 22-05-2007   #124
My System: NSS6,Nile Sat 1004S, Humax Windows Vista
Modified Splitter in line DishTV Rcvr
Dear Mr. Odiyan,
Good Morning,
I am regularly visiting the FORUM posts to get the ZENEGA 1004S user view and the test conducted by them to get the better quality signal in Bahrain Kuwait, Qatar etc.
Last week, we also followed your advice to fix a splitter and started getting better signal for SONY, SAB, MAX etc, but still after 5:00 PM signal start fading. Therefore, you are requested to give us some information on this subject to have some improvement.
1.What percentage of Signal strength/quality you are getting for Home transponder?
2.Where did you fixed the modified Splitter (Near LNB or RECEIVER)?
3.What type/thickness of wire you used to connect the splitter outlets?
4.How many turns/diameter of wire coil used?
5.Can we fix more than 1 splitter to get extra gain?
6. BTW asking all this to use in Bah :-)
Your cooperation in this regard will be highly appreciated.
Regards
Marshal
Last edited by Marshal; 22-05-2007 at 09:12 AM. Reason: Typographical Mistake correction
Marshal is offline   Reply With Quote
Old 22-05-2007   #125
Site administrator
Analoguesat's Avatar
No. Cloning/copying of smart cards was the first thing the pay tv providers stopped in the new generation of cards.
Analogue forever!
Analoguesat is online now   Reply With Quote
1004, dish, receiver, satellite, software, zenega
