DISH TV - ZENEGA CD 1004 iS SATELLITE RECEIVER SOFTWAREEnglish Language for discussion of anything happening on the Sub Continent. Doesn't have to necessarily be satellite related. | |
| | #176 | ||
| Member Join Date: 25-07-2008 Location: Srilanka
My System: Dish Tv, Zenega 1440 is | hi, i am using dish tv. once i have reset all in the receiver. now i did not get any channels. only seaching for some time and tell no program installed. please any one help me | ||
| The Following User Says Thank You to trshankar2004 For This Useful Post: | shyammahavalkar (2 Weeks Ago) |
| | #177 | |||
| Member Join Date: 12-02-2008 Location: BAHRAIN
My System: DISH TV |
All the best and better use any other guy who knows his job. regards surender | |||
| | #178 | |||
My System: DISH TV | hope this will be ok for u to setup your dish tv regards surender | |||
| | #180 | |||
| Member Join Date: 02-03-2009 Location: dubai
My System: nss 6, windows xp |
12.638 (v) 13300 12.647 (h) 27500 12.688 (v) 27500 12.729 (v) 27500 I can even see the free to air : dish interactive and icici active on the starsat So I am definately getting nss6 signal in my cable line my signal is around 48/65 for all these tp frequencies when I check on starsat reciever but all the channels are scrambled with conax and secca But when I connect the same line to my new zenaga1004is. it shows no signal at all (2/3 %) DO I NEED TO CHANGE THE LNB FREQUENCIES IN THE RECIEVER SETTINGS. Default settings are LNB HI frequency (MHrtz) 10600 LNB LO frequency (MHrtz) 09750 I tried a few options if i give a diffrent numbers for HI and Lo noting is happening but if I put 11500 for both HI and LO home transponder 12.688 (v) 27500 goes green with 50/65 signal. but I think that makes it nilesat. I have no idea about hi and low as my last reciever starsat had only one number for LNB type where you could put one frequency or universal as option GUYS PLEASE HELP I AM DESPERATE | |||
| | #181 | ||
My System: nss 6, windows xp | is there any way to use dishtv smart card with a diffrent reciver.???????? as zenega is realy sad. my zenega 1004is is catching only one transponder with 25% quality when on the same line my starsat catches 5 dish tv transponders with quality of more than 60% | ||
| | #182 | ||
My System: nss 6, windows xp | hi I ve got a zenega 1004 is ( i know its a bad start.....) my buildng has a centralized dish system working on diseq and 22khz. my lnb setting is on diseq 1. When i conect the cable directly I get two transponders 12638 v 13300 (45%/60%) 12688 v 27500 (29/35) when i introduced a line splitter in the wire i gain one transponder but i lost one as well ( strange) 12638 v 13300 (40/50) 12534 v 40700 (47/55) but i loose 12688 v 27500 (2/3) when i tried to attach an in line amplifier 10db (950-2150 mhz) I got no signal at all Does any body know if this is due to disceq system istalled or something else is there ant other way i can amplify the signal when i use the same line with a diffrent reciever (starsat) i get more than 60% signal for 5 dish tv transponders guys please help | ||
| | #183 | ||
| Member Join Date: 20-06-2008 Location: INDIA
My System: dear, sir zenega cd1004is data cord RS232 digram . send my email .thanks sir | Hi, Please any one help me. In my Zenega4s receiver (Dishtv -India) after software upgrding i could not Edit the TP & Not able to introduce New TPs, satellites,Datas, If any one knows the method please reply. | ||
| | #185 | ||
| Member Real name: TEWARY Join Date: 12-04-2009 Location: INDIA
My System: NSS6 | zenega CD-400iS when powered up its start LED blinks lightly and proceed to max intensity within 30 minutes. previously the same phenomena take 5Min. only. when intensity gets maximun it works properly.Can anybody help me what may be the reason and its rectification. | ||
| | #189 | ||
| OdiYaN Join Date: 14-03-2007 Location: ME
My System: ZENEGA DISHTV | Try changing the filter capacitors in the power section of the receiver. | ||
| | #190 | ||
| Member Join Date: 31-08-2005 Location: mabuto
My System: ku satellites |
I have been using Zenega for last 4 years withouth any problems. You must only use LNBs wchich have been tries and tested by others. You can also change Zenega Home frequency very easily. Once you are on existing Home frequency just enter password 7531 and press OK. Thats it. You can set frequency what you want. Saamer DXer | ||
| | #192 | ||
| Regular Member Join Date: 02-05-2006 Location: india
My System: DishTV DTH Zenega 1004s Receiver 90cm offset Sharp dish antenna | 1.You will need two STBs. 2. Target( the one you want to update ) and Source 3. Connect these two with RS-232 cable ( Null modem ) 4. Go to Download Menu and Start For more details refer to previous posts on the forum. | ||
| 1004, dish, receiver, satellite, software, zenega |
