Receiver softwareEnglish Language for discussion of anything happening on the Sub Continent. Doesn't have to necessarily be satellite related. | |
| | #26 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | mehra - the loader is permitted on the forum. Bin files arent. | ||
| | #27 | ||
| Vintage Sat enthusiast! Join Date: 11-12-2006 Location: Stoke on Trent, UK.
My System: 90cm Dish. Dual Lemon LNB for 13E/19E. Twin Output Lemon LNB for 28.8E. Samsung 9500 with 'alternative' firmware. Couple of DigiBoxes. Amateur Radio station. Going Bald with a patient wife! | One thought - if you feel so tempted to reprogramme your receiver with 'alternative' firmware - ALWAYS ALWAYS ALWAYS read the original firmware first and save the files. Then backup the files onto a CD-ROM or something similar that you can safely keep offline. So - then - if you mess up - you have the manufacturers firmware to hand. As for sharing firmware, etc, just look around the web - there are enough depositorys for this stuff. Leigh.... | ||
| | #28 | |||
| SATELLITE SNIFFER Join Date: 23-10-2006 Location: india
My System: Dish Tv complete equipment- 70 cm Ku Antenna, Kaon KSC-i260 MCO, Two Dish Tv OE universal LNBF, 6' C Band Antenna, Eurostar C band LNB. All attached to NSS6-ABS1-Thaicom |
...all process is in sequence.and one common answer to ur questions is that the firmware provided is the best suit for that hardware. swapping or editing bin files is not a good idea. and yes a backup is ok, but even then it's no guarantee that backup works ok again.dont take chances. | |||
| | #29 | ||
My System: Dish Tv complete equipment- 70 cm Ku Antenna, Kaon KSC-i260 MCO, Two Dish Tv OE universal LNBF, 6' C Band Antenna, Eurostar C band LNB. All attached to NSS6-ABS1-Thaicom | hi all ! i have taken backup of my kaon stb also . but i dont know that how many blocks should i include. mean reading software should start from which block and end at which one . any one knowing this please respond. thanx in advance. | ||
| | #30 | ||
| Regular Member Join Date: 02-05-2006 Location: india
My System: DishTV DTH Zenega 1004s Receiver 90cm offset Sharp dish antenna | How backedup fimrware be debugged So that exact location can be edited in "hex editor" ??? How to find which bytes to be changed? Please help!!! | ||
| | #31 | ||
Does anyone know how to debug firmware? So that exact offset is known for changing in hex editor | ||
| | #32 | ||
My System: Dish Tv complete equipment- 70 cm Ku Antenna, Kaon KSC-i260 MCO, Two Dish Tv OE universal LNBF, 6' C Band Antenna, Eurostar C band LNB. All attached to NSS6-ABS1-Thaicom | hi analogue sir, where r u, plz help me...! | ||
| | #33 | |||
| Regular Member Join Date: 19-10-2004
pls send me the software for backing up zenega 1005 - old version, if u have pls | |||
| | #34 | ||
My System: Dish Tv complete equipment- 70 cm Ku Antenna, Kaon KSC-i260 MCO, Two Dish Tv OE universal LNBF, 6' C Band Antenna, Eurostar C band LNB. All attached to NSS6-ABS1-Thaicom | | ||
| | #35 | ||
| Member Join Date: 12-09-2006 Location: J&K ,INDIA
My System: Dishtv ZENEGA CD1005S STB+90CM parabolic dish Also 6ft & 8ft mesh dish | | ||
| | #36 | ||
| Regular Member Join Date: 07-07-2006 Location: INDIA
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | | ||
| | #37 | |||
| Member Join Date: 22-06-2006 Location: melbourne,australia
My System: 2.3m meshdish recieveing asiasat3s | hi there can you please name which loader software to use or if you please give me link to downloader loader and can you please provide me with old version file for zenega CD-1006S. thanks Raja
| | #38 | ||
My System: Dish Tv complete equipment- 70 cm Ku Antenna, Kaon KSC-i260 MCO, Two Dish Tv OE universal LNBF, 6' C Band Antenna, Eurostar C band LNB. All attached to NSS6-ABS1-Thaicom | hi raja, i used this attached loader. it is available with this forum in some other thread also. i have "read" my zenega 1006 with it . u can also try it. i have got the bin file that is 322 kb in size. any query ? | ||
| | #39 | ||
My System: Dish Tv complete equipment- 70 cm Ku Antenna, Kaon KSC-i260 MCO, Two Dish Tv OE universal LNBF, 6' C Band Antenna, Eurostar C band LNB. All attached to NSS6-ABS1-Thaicom | hi raja, the loader i used is available with this forum in some other thread also. i have "read" my zenega 1006 with it . u can also try it. i have got the bin file that is 322 kb in size. any query ? i tried to attach it but could not. just pm me ur id and i'll send it . | ||
| | #40 | ||
| Member Join Date: 12-02-2007 Location: India
My System: Computer | Hello dear can u send me the software old one for operating my Zenega CD 1005S STB as it is blocked by Dist TV my email is removed*yahoo.co.in | ||
| Last edited by Topper; 12-02-2007 at 02:20 PM. Reason: no email addresses to be posted | |||
| | #42 | |||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | You do realise that even if you successfully downgrade the software the box will automatically upgrade it again? The ONLY way to stop the software ever being upgraded is to never use the box on Dish TV ever again! | |||
| | #43 | ||
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | Maxmimum You dont need Drivers for it, If your cable crossing the links, then you need few drivers, If it is than it is not null modem, Pls refer old thread for null modem. | ||
| | #44 | ||
My System: Dish Tv complete equipment- 70 cm Ku Antenna, Kaon KSC-i260 MCO, Two Dish Tv OE universal LNBF, 6' C Band Antenna, Eurostar C band LNB. All attached to NSS6-ABS1-Thaicom | well friends i m giving the information that would suffice u to backup ur zenegas. prepare a null modem cable. pin connections will be : use two female serial port sockets that are freely available in market . use networking cable by soldering as follows.pin 2 - pin 3 pin 3 - pin 2 pin 5 - pin 5 now the software part of game. here i would like to tell admn and mods that even after repeated efforts i could not upload the loader . till now i have entertained all the requests, and have e-mailed to all the ppl here who have asked me for it. analoguesat sir plz help me to upload the loader here. finally let me divert all the thanks to the actual owner of loader.a filnal word- plz be aware for what u r going to do with ur stb. enjoy !! | ||
| | #45 | ||
| | #46 | ||
| | #47 | ||
My System: Dish Tv complete equipment- 70 cm Ku Antenna, Kaon KSC-i260 MCO, Two Dish Tv OE universal LNBF, 6' C Band Antenna, Eurostar C band LNB. All attached to NSS6-ABS1-Thaicom | dear friends here is the link for loader for zenega. Let it b clear that it's repost. So thank to the actual poster. plz reply if any problems r felt. DOWNLOAD HERE | ||
| | #48 | ||
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | Remember the handshaking. | ||
| | #49 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | | ||
| | #50 | ||
| Member Join Date: 13-02-2007 Location: Worldwide
My System: 1 x SeaTel 6003 (Gyro Stabilized 150cm Dish) 1 x Quattro Linear LNB 4 x Xtreme U-cas (Kaon?) 1 x Triax TMS 9x8P Diseq 1 x TAC 92 Tracking Unit 4 xT-rex Twin Module 4 x Dual CA (Irdeto&Conax) 2 x Conax Technicam CX | Hi all. I've got a Xtreme U-cas tuner and a T-rex Twin module Cam. How can I access Orbit on Badr 26E? I have been into the menu on the tuner after installing the T-rex and it is possible to enter codes in the CA menu. Is codes all I need or do I have to by a programming unit for my cam or an card + programming unit? Sorry for the lame language, I'm pretty new to this:-) Cheers | ||
| receiver, software |
