Dish TV in BAHRAIN | |
| | #26 | ||
| Member Join Date: 26-07-2007 Location: india
My System: discuss about satellite tv | Dear Hareesh, Is there any reported case of catching people comming with DishTV receiver at Bahrain airport. It is happening in UAE !!!!!!!!!!!!!! ![]() Kindly update. Thank you, Saju Last edited by saju; 28-07-2007 at 07:58 AM | ||
| | #27 | |||
| Member Join Date: 02-01-2007 Location: Middle East
My System: NSS6,Nile Sat 1004S, Humax Windows Vista | Never heard any such report in Bahrain. A friend of mine brought DishTV Rcvr 3 months ago, without any problem. I dont know if any restrictions are implemented recently. Marshal | |||
| The Following User Says Thank You to Marshal For This Useful Post: | saju (28-07-2007) |
| | #28 | |||
| Member Join Date: 03-03-2007 Location: bahrain
My System: NSS6,DISH TV INDIA,KAON KSC-i260MCO | About 6 months back,they confiscated some receivers for some time,but later they contacted them on phone and handed over them back.One of my friend got it back.I think nobody catching now in Bahrain | |||
| The Following User Says Thank You to asdf68 For This Useful Post: | saju (28-07-2007) |
| | #29 | ||
My System: discuss about satellite tv | Thanks everybody for the replay to my questions. Anybody recently brought DishTv receiver kindly update. Thanks in advance Last edited by saju; 28-07-2007 at 07:58 AM | ||
| | #30 | ||
My System: discuss about satellite tv | Hi, Which LNB is best suited for DishTV. Based on which criteria LNB should be bought . some measurement like 'db' Anybody kindly explain thanks in advance Saju | ||
| | #31 | |||
My System: NSS6,DISH TV INDIA,KAON KSC-i260MCO | First i tried lucky star quad output lnb .3db,as 3 of us are using same dish.As there was some problem with some channels,our technician changed it to premiumx quad lnb .3db.After the change,reception improved(I mean better than before).I strongly recommend premiumx .3db universal lnb.You can try other different lnbs also as they are cheaper,may be 1.5 or 2 b.d.One of my friend using Invocam lnb .3 db,its expensive(single output ,he got it for 16 B.D!!) and its not better than my premiumx lnb. Anybody using newly introduced dish tv VGA box? | |||
| | #33 | ||
| Member Join Date: 28-03-2004
| Dear Suja Invocam lnb is very good but for this u need seprat feed horn, premiumx is good LNB but not same to Invocam. Keep in mind Primiumx model which i found in markeet is bascally for off-set dish, it will NOT give good result on primfocuse dish. try to find Sharp lnb IT IS GOOD & CHEEP THEN Invocam. A good LNB must set properly, most tech dont have idea about prime focuse & offset dish diffrence. | ||
| The Following User Says Thank You to fawad For This Useful Post: | saju (25-08-2007) |
| | #34 | ||
| Suja 0.2 DB LNB is better then .3db but dont beleave what they write, a good brand from Germany/UK of .3db is far beter .2db from... | ||
| | #35 | |||
I thinkthe dish we r using in bahrain for nss6 IS off-set dish.So,premiumx 0.3db is best. | |||
| | #37 | ||
| Member Join Date: 23-07-2007 Location: BAHRAIN
My System: dreambox 7020, tata sky receiver | So looks like no one has succeeded with tata sky in bahrain... more money down the drain for me ![]() looks like i'll have to go with pehla again.. | ||
| | #38 | ||
| Member Join Date: 27-06-2007 Location: Kingdom of Bahrain
My System: Relook 200S Nilesat Hotbird Asiasat Insat2E | My Technician told me that Tata Sky is available in Bahrain and I am planning to bring the receiver after one month. Presently I am using DishTv with Kaon Receiver But I am not satisfied with the Signal Quality for many important Channels like Star Cricket, NDTV Profit and so... | ||
| | #39 | ||
My System: dreambox 7020, tata sky receiver | pardesi, I am currently in India with my tatasky receiver with a view of just giving it away to someone who can use it..your reply has made me start to hope again.. I am returning to bahrain on saturday.. i had checked with a guy called prashanth who runs a cable network in manama, and he said dish tv will be received, but not tatasky..So i brought it to india with me thinking it is useless there.. Is there really any chance that tatasky signals will be received in bahrain? Then i will retain my receiver.. Can you provide me contact details of your technician who said signals are being received? Or could you re-check with him whether he has tested the signals and how much further investment would be required? I would really appreciate it. Thank you. | ||
| | #40 | ||
My System: Relook 200S Nilesat Hotbird Asiasat Insat2E | Hi Smita, When i Installed DishTV in My Flat the Technician told me that recently he found that the signals for tatasky is available in Bahrain. And Channels are Much Clear than DishTV but not All the Channels available, So i told him that i will change from DishTV to Tatasky. I just need to Tune my Existing Dish to Tatasky Satellite. No other expenses involved. I dont have the contact number of him but his name Is Paresh and his shop is in Joofri Street near a Gujrathi Cafeteria where 4 roads meet. | ||
| | #41 | ||
My System: dreambox 7020, tata sky receiver | Thanks again pardesi. What I'm going to do is leave this receiver here in india,verify with that guy in bahrain( paresh)and then perhaps get it back. Another query is, what size dish do you have in bahrain for receiving dish tv? We have an ancient 10ft mesh dish which i think is not suitable for these kind of signals.. Anyway, thanks. regards, smita | ||
| | #42 | ||
My System: Relook 200S Nilesat Hotbird Asiasat Insat2E | Smita, I advise you to bring the Tatasky Receiver to Bahrain meanwhile you can talk to Paresh his contact no is *******. I am using 165 cm Ku Band offset Dish and Premium X LNB . Wish you Happy Flying Last edited by Lancelot; 14-09-2007 at 10:55 AM Reason: No phone numbers | ||
| The Following User Says Thank You to pardesi For This Useful Post: | smita (15-09-2007) |
| | #43 | |||
| Member Join Date: 14-09-2007 Location: bahrain
My System: planning |
can you please give me the phone no of paresh or the shop no where he is available | |||
| | #44 | ||
My System: dreambox 7020, tata sky receiver | Hi Pardesi, I left the receiver back in India as i saw your post only this afternoon.Anyway, i will be returning to India in november, so iif i get confirmed reports that tatasky works here,i can get it back. I could not see the number you posted as it appears to be against forum rules to post numbers- how do we work around this problem?I dont know how to use the private message system, as i think phone numbers maybe allowed there.. Anyway, if that doesnt work, i will post ,my mail address so that you can email me the number. regards, smita | ||
| | #45 | ||
My System: dreambox 7020, tata sky receiver | Hi! Just wanted to update that i went to the shop- its called jabbari electronics and is near gujrathi rest. like pardesi said. I didnt meet paresh, but it turns out that he's the guy who did pehla installations for our whole building when we were in salmaniya( small world huh?). Anyway, i want to thank pardesi again for the info. Now am waiting to get my receiver back- which will be in november. As an aside, if pardesi is reading this, paresh said it'll cost be about 85bd for the installation(maybe it includes the dish etc)- does that sound reasonable? regards, smita | ||
| | #46 | ||
My System: Relook 200S Nilesat Hotbird Asiasat Insat2E | Smita, I fixed the eurosat 165CM Dish with some ordinary LNB for BD 65, it inludes the Dish, the Stand for Dish, LNB, Cable and Labour Charge. It is advisable to fix Dynasat Dish larger than 165CM and PremimX LNB. There are technicians here who will do this for may be less than paresh. But i am not sure that they know better than paresh about Tatasky. Mr. Shibghat in 'Future Tech' Rasruman Near Orbit May help you to find a technician. I want to change my 165CM dish to Larger one. but it costs money around 50 BD maybe. But because yours is a new installation better go for larger one. I will receive my receiver last week of Oct. I will post my Experience | ||
| | #47 | ||
My System: Relook 200S Nilesat Hotbird Asiasat Insat2E | Today i installed tatasky !! i can watch most of channels. But some movie channels like star gold zee cinema are not available, i can wacht even DD channels and i advice all Indians and Pakistanis in Bahrain to fix Tatasky | ||
| | #48 | |||
My System: NSS6,DISH TV INDIA,KAON KSC-i260MCO | Can u post the details like size of the dish,lnb,and the technician who installed it? | |||
| | #50 | ||
| Member Join Date: 04-09-2007 Location: Bahrain
My System: Dish TV, NSS6, Zenega 1004IS, Vivax, Windows XP | Hi, I recently installed dish TV in Bahrain. However, I am getting only around 30 channels on the TPs 11037H/40700 & 11172H/27500 with signal strength of 70+. The rest of the Tps are not showing any signal. Has anyone else encountered this problem? What is the solution? | ||
