Satellite Antenna Alignment v2.36.8
Tudo sobre instalações e dúvidas de pratos, LNB's, motors, DiSEqC, e frequências dos sats.
Old 06-01-2008   #1
fox2004's Avatar
My System: Teka 1000 M, Strong STR 6125, Toshiba A200, Asus EeePC 1000H, Apple iMac Core 2 Duo 17"
Pode ser útil a muita gente.
Programa para alinhar antenas:
"The program “Satellite Antenna Alignment” is used to calculate the angles necessary for installing satellite dishes. The main difference from similar software is the possibility to calculate the position for all satellites at once. Thus, you get a clear picture about what satellites can be physically visible from the location where the dish will be installed. It should be kept in mind that the program makes a purely theoretical calculation according to formulas and in real circumstances a lot of additional factors should be taken into account when a satellite dish is installed. These factors include various obstacles (buildings, trees), the landscape, the altitude, transponder orientation, polarization, etc. Nevertheless, this program will allow you to evaluate the position quite precisely. The calculation can be saved to a text file, copied to the Windows clipboard or printed out at once. It is possible to save the list of locations for which the calculation is done. Later on, you will not have to enter the coordinates of these locations again."
Download
__h**p://rapidshare.com/files/66921988/Satellite_Antenna_Alignment_v.2.36.8.rar
fox2004 is offline   Reply With Quote
The Following User Says Thank You to fox2004 For This Useful Post:
nowready (06-01-2008)
alignment, antenna, satellite
