How to check Pehla Subsription Card ValidityDiscussion on the Irdeto encryption technique | |
| Member Join Date: 28-08-2008 Location: Nigeria
My System: Satellite |
Can anyone help me to tell what is the method to check the validity of the subsription of Pehla card. I am using ART card. I have subscribed for 1 year Pehla silver. I want to know the method to check when it will be due. Is there any way to check?? Please help.. Decoder - MYtv satellite decoder Satellite: Nilesat 7 degrees West Encryption: Irdeto 2 Dish Size: 120cm off-sett Thanks, Jerry | ||
| | #2 | |||
| Archived Member Join Date: 13-08-2007 Location: Middle East - Israel
Then give your satellite system details, including receiver model, dish size and pointing to which satellite. You shouldn't mention anything to do with c a b l e, so delete what you have written as it is not relevant from where you got the card. | |||
| I am not familiar with your receiver, but usually you would need to look in the installation menu or the CAM menu and then select Authorization, and it should tell you the start and finish dates of the sub. If you can't find it, attach few pictures of the menus or attach the receiver user guide. | ||
| card, check, pehla, subsription, validity |
