Bulsatcom on Skystar HDDiscussion on the Irdeto encryption technique | |
| Member Join Date: 19-11-2008 Location: Bulgaria
My System: 150 CM Dish, Technotrend SkyStar HD2 DVB-S2 PC Card. AMD 64 Athlon 5200+ |
Hello, I have a satellite receiver of the bulgarian provider Bulsatcom with a card i bought from them. I also have a TechnoTrend Skystar HD DVB-S2 PC Card installed on my PC. So my question is, can i somehow transfer the codes from my Bulsatcom card to my Skystar HD PC card so i can watch difrent channels than the the ones my wife watches in this moment on the TV. Encription of Bulsatcom is Irdeto2, Grifin and Bulcrypt, and they are on HellasSat 2 39.0 E. Thanks in advance. | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | You could watch different channels of the same polarity as those your wife is watching if the receiver has an LNB out to connect to the Skystar LNB input. Not ideal of course, and could some domestic strife if she switches over to different channel polarity ![]() Otherwise, you would need a separate card from your provider to use in a CI module connected to your Skystar HD card (if it is the version with that option), and a twin output LNB on your dish to connect to the Skystar if you haven't already got one. Llew | ||
| | #3 | |||
| bulsatcom, skystar |
