Showtime & Al Jazerra
Discussion on the Irdeto encryption technique
Old 02-12-2008   #1
My System: Astra 2d 1.45 mt dish & Nile Sat.
Hi all can anyone advise.
I have a cristor x3 box for Nilesat with a showtime card. I also have an Al Jazeera Sport card that I want to start using. Showtime needs to be left on Show Sports 1 when not in use. Ok can do.
I have been told that it is OK to leave the Al Jazeera card out of the box when not in use, however on the back of the it says "Do not remove and re-insert unnecessarily)
Is it better to buy a new box with two card slots and leave both in. If so can anyone recomend which box to buy.
alicantebaggie is offline   Reply With Quote
Old 12-12-2008   #2
My System: with l
depends if your al jeezera card is for hot bird...if fo nilesat then you have 2 options...
1. get in touch with the guy that sold you the showtime card and get him to ad aljezeera sport to your showtime card...this can be done i sell them. then there is is no need to take the card out
2.get a second box and twin lnb and get them installed...you can get a box with embedded irdeto card reader or seperate box and seperate irdeto cam. dont get multicam as the cards need to be in irdeto cam or embedded to be activated. this option will allow both cahnnels to be watched on 2 tv's or more.
hope this helps
paulkelly is offline   Reply With Quote
Old 12-12-2008   #3
aka Skyman
Zorba's Avatar
My System: 3m(sky),1.8m(astr/hotbird),1m (nilesat)1m(arabsat)diseqc 4,sky plus,humax freesat,visionet 8000s,technomate 5400 ci+ usb super. Satlook nit colour + Horizon hdsm. wii
Are you sure you can put Al Jazeera sports on a Showtime card?
I was told you can't,but you can put Art Sports on.
Zorba is offline   Reply With Quote
jazerra, showtime
