smartcard theory & ECM EMM? | |
| Member Join Date: 21-03-2006 Location: FR
My System: Humax |
Hi, I want to smartcard technology (used in Digital Receiver) in detailed. Is there any books/tuto available? I want to know how a encrypted channel is decrypted also how a subscription is managed. I guess I need to learn HMK,PMK,MK ECM EMM etc. If you anyone can give this info in detailed..... Thanks, Bye BT | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Have a look here for some good basics.
__________________ | |||
| Regular Member Join Date: 20-04-2006 Location: Lost in the night
My System: ? | DVB protocol describes a scarmbling lagorithm. This algorithm is called CSA, Common Scrambling Algorithm. Every provider uses this algorithm. In it's simplest way of implementing scrambled transmission, the operators scarmbls the service with a fixed key. Every one who is supposed to receive this service gets the fiexed key and he receives the service. This method is used for connections from one partner to another. It is not convenient for operator to use it for their broadcasting. In order to broadcast, they use one encryption system: Irdeto2, Viaccess etc How it works? Firstly, the encryption system generates a random key for CSA. The service is scrambled with the key. Then, the key is encrypted by the proprietary (and also TOP SECRET) algorithm of the encryption system. ECM contains the encrypted key.The CAM/smartcard decrypts the key. Then, the receiver gets the key and descrambls the service. It is possible for an operator to use more than one scrambling systems. The service is scrambled, the encryption system encrypt the key. Finally, different ECMs are transmitted, one for every scrambling system. | ||
| The Following User Says Thank You to tesla For This Useful Post: | De Fault (13-05-2008) |
| | #5 | ||
My System: ? | When a new customer subscribes, the technical staff of the operator sends a command to the smartcard. This command assigns the appropriate products to the smartcard. When the customer stops his subscription, then the technical staff sends another command to the smartcard. This commands removed any asigned product from the smartcard. | ||
| | #6 | |||
| Member Join Date: 13-05-2008 Location: Thailand
My System: ARM Developer Suite AXD Debugger ARM processor emulator |
To be more precise, I believe the decrypted key can probably be found in the CAM's RAM memory? Please correct me if I am wrong. Are there any Irdeto CAM's based on the ARM processor? Is there a JTAG interface test points available in the CAM? Did anyone try to examine the CAM's PCB? Can we have access to the CAM's PCB and JTAG test points? Please e-mail me at REMOVED ![]() Last edited by mhku; 13-05-2008 at 10:03 AM. | |||
Similar Threads | ||||
| What do I need to read and extract the keys from a official Irdeto1 smartcard ? | tisurame | Irdeto system | 13 | 22-10-2005 08:25 PM |
| Smartcard ERROR ( no ATR ) | sputnick | X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex | 10 | 17-06-2005 04:10 PM |
| csat & phoenix smartcard | edmond1 | Cards & Programmers General | 1 | 28-04-2004 05:44 PM |
| Unification Theory | orphidian | Einstein's Alcove | 31 | 06-02-2004 12:43 AM |
| viaccess smartcard | radiotech | Viaccess | 3 | 22-05-2003 02:13 PM |
