dstv single view irdeto smart card | |
| Member Join Date: 15-07-2007 Location: south africa (johannesburg)
My System: dstv single view | hi guyz i am new to this i install sats in sa want to no if there is any way to c rack or c lone a d s t v smart card i do have a card reader but dont know what prog it uses any ideas please help i can always pay you back with decoders used smart cards thanx | ||
| The Following User Says Thank You to mervynvenom For This Useful Post: | zawmintun1 (20-10-2007) |
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Not as far as I know, have also moved this to an appropriate section. Most modern smartcards are pretty much impenetrable, access to these packages normally comes from other directions.
__________________ | |||
| The Following User Says Thank You to rolfw For This Useful Post: | zawmintun1 (20-10-2007) |
| Section Leader Join Date: 07-07-2006 Location: INDIA
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | Welcome mervynvenom , Pls swith on your PM.
My System: dstv single view | | ||
| | #8 | ||
| Member Join Date: 11-05-2008 Location: South Africa
My System: DSTV and FTA on IS 7 (KU). Busy with 2.4m CBand (motorised). Own a shop distributing satellite equipment (specialising in FTA) | Mervyn... Did you manage to get anywhere with this? I think is just about impossible now that they've started marrying the decoder to the card | ||
| | #9 | ||
My System: dstv single view | cracked a few some of the dsd720 and older do not marry cards unless you call multichoice and tell them that you want to activate the card.........i changed my decoder to fta 2.4m dish pointing w3a unlocked most dstv chanels | ||
| | #10 | ||
| Member Join Date: 18-03-2008 Location: Bangalore - INDIA
My System: Setting up one. Any suggestions most welcome. | I thought Dstv broadcasts their packages on Intelsat 7, Intelsat 10, Eutelsat Sesat and Eutelsat W4? | ||
| | #11 | ||
My System: DSTV and FTA on IS 7 (KU). Busy with 2.4m CBand (motorised). Own a shop distributing satellite equipment (specialising in FTA) | Please explain... Are you using card sharing? Why 2.4? Isnt w3a strong enough to use a 82cm? And I had no idea w3a had M.choice content on it. | ||
| | #12 | ||
| Member Join Date: 31-08-2008 Location: 234
My System: For research purposes | Pls lets post something more reasonable with enough information to defend what we post here, Most of us are here for research and comfort purposes..... many thanks to those who post clearer messages on here. Kudos! | ||
