Can I load keysd straight into the receiver?
Info exchange on hex/plain/masters, handler/service-keys, Prov-IDs, ChIDs, PPUAs, etc. NO KEYS MAY BE POSTED!
Old 27-09-2007   #1
My System: Phoenix Apollo CI Digital Satellite Receiver
I bought a null modem cable and I want to load the SoftCam.key file into my Phoenix Apollo receiver. Does anyone know what software I need to do this and what I am supposed to do to get the keys loaded?
Thank you.
mgyi99 is offline   Reply With Quote
Old 27-09-2007   #2
My System: Phoenix Apollo CI Digital Receiver, Invacom 0.3db Universal LNB, 80cm dish, Manhattan HH100 or 120 motor (not sure which one)
I also have 'Key Updater 2', is this the software that I need?
bmonkey is offline   Reply With Quote
Old 27-09-2007   #3
jimbo's Avatar
My System: Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
Does it occur to you to perhaps search this wonderful site for information. If you want to get into the satellite hobby you need to be a bit more pro-active guys.
Here ... I'll start you off Phoenix Apollo CI+MC
Jimbo
jimbo is offline   Reply With Quote
Old 27-09-2007   #4
My System: Humax ir-ace hotbird
can someone also please explain how i can do this in a xcruiser xdsr 200 and tell me what software to use pleasee, thanks in advance.
Driller_786 is offline   Reply With Quote
Old 27-09-2007   #5
jimbo's Avatar
I haven't seen too much on that model (not on here anyway).
Try this http://digitalweb.wo.to/forums/forumdisplay.php?f=12
Jimbo
The Following User Says Thank You to jimbo For This Useful Post:
Driller_786 (27-09-2007)
Old 27-09-2007   #6
thanks alot man
Old 27-09-2007   #7
i managed to find a file containing the key updater, softcam file and instructions for the Phoenix file, so I should be able to go ahead and do it now, but I just have one question before I go and do it.
The instructions say to turn off my box and then turn it on when the transfer process is about to start. Does this sound right? Wouldn't the box need to be turned off throughout the process? I'm just being cautious in case I mess up the box, if thats even possible. And after i've done it, should the keys be populated in the hidden menu? Thanks for your help.
Old 28-09-2007   #8
My System: 1M DISH TECHNOMATE 5000CI
Thumbs up
i did mine last week having done the same with a manhattan before that and it all works great so go ahead
robloman is offline   Reply With Quote
keysd, load, receiver, straight
[IMG] code is Off
