Absolute novice help required. Softcam keyInfo exchange on hex/plain/masters, handler/service-keys, Prov-IDs, ChIDs, PPUAs, etc. NO KEYS MAY BE POSTED! | |
| Member Join Date: 01-10-2007 Location: uk
My System: ye-2000 cx SUPER PLUS | I had a Next YE2000 CX super plus installed in my apartment in Marmaris Turkey. I have got twin transponders to receive Astra and Hotbird. A local installer said he could supply keys to unlock channels if I provided a USB key. This I did and he just plugged it into the receiver and immediatly updated it. It uses a softcam.key. My question is how do I do this for myself when the keys change? | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Hi, You will have to go find the keys from somewhere. Then edit the softcam with a notepad hopefully. Have you tried opening the file with notepad? You need to know the encryption and provider IDs, for the packages you want. Once you know these you can overwrite the ones in your softcam, an reload to receiver. | ||
My System: ye-2000 cx SUPER PLUS | Thanks for reply. I downloaded SoftCam editor and this is what keys its showing. Iredeto Seca Agra Viaccess Crypto Conax Biss So what do I do next? search for keys? where? Sorry about this but absolutely new to this , but wish to learn. | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Hi, You might find some info here:- The Big Links List Also they can be found all over the internet. Have a pog around, you'll find them. | ||
| The Following User Says Thank You to Robbo For This Useful Post: | rlg (02-10-2007) |
| | #5 | ||
| Member Join Date: 19-07-2007 Location: London
My System: Humax ir-ace hotbird | please can i have found out a lot of information so far but i am stuck please give me a link so i can download a loader to load the softcam keys once edited on to my receiver please give me the name of the software or website i can download it from and if you need to know i have an xcruiser xdsr200. Thanks in advance. | ||
| | #6 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | | ||
| absolute, key, novice, required, softcam |
