How to Enter Codes to Truman 150 X ultra ?Info exchange on hex/plain/masters, handler/service-keys, Prov-IDs, ChIDs, PPUAs, etc. NO KEYS MAY BE POSTED! | |
| Member Join Date: 24-07-2008 Location: west yorkshire
My System: satellite forum | Hi, To enter the codes for the truman 150 ultra, press 9339 that will pop up a menu where you can modify the nagra, viaccess codes, Ciao | ||
| | #3 | |||
| Member Join Date: 10-01-2008 Location: eygpt
My System: satellite | 1. Stand on any channel and enter the 9339 figure you'll see a list chosen Code Edit and click on OK to show you a list of encryption systems, select an encryption system BISS then click on OK 2. Press the green button in the remote keys to add channel 3. Click on the button INFO in remote encoding system for the selection of DCW and you'll see the word 16-Bytes key 4. Service ID in the box enter a value in a box in the Hex Frequency Enter frequency channel in the box Key Data Enter the 16-key keyboard of the first two of the 32 components of the code, then click the OK button in the remote for the Conservation of new data (keys existing explanation does not work now, Is to clarify only) 5. Enter the 16 other key then press the button OK, and press the button Exit out of the list of encryption http://img218.imageshack.us/img218/8085/71615318gw7.jpg[IMG] http://img211.imageshack.us/img211/2866/48047363dc5.jpg http://img210.imageshack.us/img210/4883/43710629qy0.jpg Greetings engineer / عزت جودة Tanta - Egypt | |||
| 150, codes, enter, truman, ultra |
