smart card or receiver software
Old 09-03-2008   #1
wich is better to open encrypted channels, smart card or using receiver software that is finding in diffrent forum?
what is the difference between using smart card or receiver?
GIVARGIS is offline   Reply With Quote
The Following User Says Thank You to GIVARGIS For This Useful Post:
larlar (13-06-2008)
Old 09-03-2008   #2
Dont eat yellow snow
stuzeeuk's Avatar
My System: Hotbird 13E - 8ft dish Arabsat 26E - 8ft dish Invacom quad LNB Powersky 8210 Startrack receiver Viaccess cam T Rex Cam Diablo Cam ART subscription Al Jazeera subscription (13E)
Smartcards are best used for official subscriptions. The question should be between CAM's and receiver software.
For CAM's the best on the market at the moment I would suggest is the 'Diablo CAM' which currently has excellent backup and support.
The best receivers I would suggest are the 'Technomate's, 1500CI is posibbly best supported at the moment.
Which is best between these is a gamble ...... depending on price, availablility, your location, what satellites you are pointing at, and most important, what the future support for these products will be.
Do a bit of reading on the forums here and then make up your own mind.
stuzeeuk is offline   Reply With Quote
Old 10-03-2008   #3
If my receiver has built-in satellite smart card reader can i use it for open channel by programming a smart card or must have cam?
Old 10-03-2008   #4
stuzeeuk's Avatar
depends on your receiver and what encryption is embedded. It also depends on wether it has a UCAS mode, in which case you may not need a card.
Since I have no idea what sat box you have or card you are looking to purchase its difficult to judge.
Old 11-03-2008   #5
I like to change from useing receiver file to useing smart card
but i don't know how smart card works
just i know that there is diferent type of smart card with diferent eprom that can send file to it with smart card programmer
I want to know is smart card same for all type of encryption or each one has its related one?
becase i know when useing cam you must buy different cam for that encryption
but how about the box that has built in smart card reader, can i use cam with smart card reader????
for example if i buy a funcard can i put it in the box and use it?
to many question.....
Old 11-03-2008   #6
Amo Amas Amant Admin
Topper's Avatar
Look
Cards are old technology, they do not have enough processing power or memory to assist in decryption, these days most systems use emulators or cams that do not require cards. Some well supported receivers use modified software or patches. You can buy as many funcards as you like but just about all you will be able to do with them is scrape ice off a windscreen. I suggest you start reading some threads because you are obviously new to this and therefore need to do some background reading. If you want to get really technical then this site is good for educational purposes
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 13-03-2008   #7
I read that site and choose some words from that site to make clear my question
If my receiver has [CI module: common interface] and if i find the part of the [firmware] taht contains all type of the keys [all cam] then can i put that file to the smart card and use it with CI module and wach the same channel that when i use frimware update?
If it is impossible, why?
because
The smart card memory is small?
I cant find that type of file that contain all type of keys?
The CI module cant handle the smart card?
Old 13-03-2008   #8
rolfw's Avatar
Real name: Rolf
My System: Sky+, DB 7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Spectrum analyser.
I can't realistically see why on earth you would want to do this, as there are already CAMs available which can be updated with keys and patches, why insist on trying to introduce a third element into this?
It may well be possible, but it would require someone to work out how to do it by changing the architecture of a CAM and I can't see it happening, as it is a backward step.
Rolf
Old 14-03-2008   #9
Thank you rolfw
the problem with cam is that if i want to work with different type of encryption (nagra, viaccess, irdeto, ...) then i need different cam for each one with related smart card
OR
maybe there is a cam for all type of encryption [multicrypt] that i don't have information about it
if there is this type of cam can you give me information about it?
Thank you
Old 14-03-2008   #10
rolfw's Avatar
Real name: Rolf
Do a forum search for TRex or Dragon, this is a programmable multicrypt CAM.
Rolf
Old 14-03-2008   #11
Thank you rolfw
But i am confuseing between CAM and CARD
In some fta receiver they write that the receiver has built in smart card reader [ x crypt smart card reader ] or [1 x smart card reader] same as Dreambox receiver is this mean that the smart card reader work as a multicrypt cam or no?
IF NO
what is this smart card reader for?
Thank you again
Old 15-03-2008   #12
stuzeeuk's Avatar
Your all over the place here mate .......... you really should do some reading.
- To answer the question the smartcard is normally for an official subscription card.
You have 3 main pieces of equipment
- Satellite receiver, most have some kind of embeded software, fta, viaccess, irdeto, nagravision and some have built in multicam (i.e. more than one of the above). Some also have CI slots. A CAM can be inserted into the CI slot.
- CAM, this holds the software for encyption type (viaccess, irdeto, nagravision). You can also buy programmable multi cams that manage several encyption types, Diablo and Dragon cam are examples of the above.
- Cards nowadays as ROLFW states are now normally for official subsciptions only. In the past 'fun cards' could be programmed to decrypt channels however the technology has now moved on and these are more or less redundant.
I suggest you dont buy a dreambox until you have the basics of the above ......
Old 15-03-2008   #13
Archived Member
A CAM is a hardware part in PCMCIA format which has a connector that can be inserted in a receiver which has a CI CAM slot.
This CAM has a slot for inserting a smartcard.
Dreambox model 500S has a card reader for official smartcards, but you need an emulator (Software MULTICRYPT CAM) like CCcam to open the channels.
Other Dreambox models like 7000S has both card reader and a Hardware CI CAM (CI=Common Interface) slots.
Check this page for CAMs from one of our site sponsors Pulsat, to understand what a CAM looks like:
http://www.pulsat.com/satellite/site...s.php?cat_id=3
HB13DISH is offline   Reply With Quote
Old 15-03-2008   #14
Thank you
I am reading many sites
So there is 3 method for decryption
1. use receiver frimware and patch
(it is easy but risky because in some case receiver damaged with wrong file and need jtag method for repair it)
2. use receiver with multicard reader and smart card
(it is old method and most of you don't use it)
3. use receiver with CI module and multicrypt CAM
(most popular but expensive)
If there is other method or my writing is wrong please correct it
Now new questions
1. If i find a key of one provider is it same for that 3 method?
or
depending of wich method i am useing i need related key?
2. what is benefit of method 3 (useing CAM) that most of you interested about it?
Thank you
Old 16-03-2008   #15
rolfw's Avatar
Real name: Rolf
Method 1 is now by far the most popular.
Rolf
Old 16-03-2008   #16
Robbo's Avatar
Real name: Mark
Method 3 is useful if you don't want your receiver choice to be restricted, or you have gone and bought a receiver but method 1 doesn't work on it, because either someone can no longer be bothered to write new software for it, or no-one ever bothered in the first place.
Method 2 can be used, when neither method 1 or 3 work and if someone has some cards programmed up.
Robbo is online now   Reply With Quote
Old 16-03-2008   #17
stuzeeuk's Avatar
Originally Posted by GIVARGIS View Post
Thank you
Now new questions
or
Thank you
Personally I would advise to buy a multicam receiver that is well supported with regular software updates and has a CI slot. Thus you get the best of both worlds if and when your box becomes obsolete.
Its more expensive but gives you greatest flexibility. You can also purchase official subscription if you so choose at a later date.
Old 17-03-2008   #18
In wich method i can edit the file myself and put key in it?
for example if i choose method 1 can i edit the receiver frimware with some softwares that edit *.BIN files?
or
it needs some special information that i can't find them
How about other methods?
Thank you
Old 17-03-2008   #19
Archived Member
Please Update Profile
It would help if you can add to your profile your location, dish size and which satellites you are interested in pointing to.
Also what would you like to watch and in which languages.
A receiver like Dreambox model DM7020S can give you a lot of flexibility.
Spend few hours reading the Dreambox section. You can learn a lot from there.
Old 17-03-2008   #20
Thechnical information
I know dreambox is linux based receiver with many flexibility but i need thechnical information in general not about some special receiver
Thank you.
Old 18-03-2008   #21
Archived Member
You will find that other members can be more helpful when they see that you have updated your profile.
There is a lot of technical information in this forum. Just use the search button and type the relevant key words.
Old 18-03-2008   #22
rolfw's Avatar
Real name: Rolf
It is practically impossible to get all of the Is dotted and Ts crossed in advance, take a leap of faith, go with your gut and get yourself a cheap patchable receiver or CAM. You can then experience the hobby in real time and in the real world, you cannot learn this without actually doing it.
Answering every minute detail of different aspects of the hobby becomes tedious after a while and members will switch off, as I already have.
Rolf
Old 19-03-2008   #23
What is next step
Thank you rolfw
i got good information about neotionbox3000 2 years ago from this site but now ?????????
what is the next step after i have a receiver and its patch?
for example if somebody ask me how can i update my receiver i will answer
1.receiver loader or software that can make connection with your receiver
2.RS-232 cable
3.latest patch
now how can i put new key in receiver patch?
1.special loader that can send key file?
2.key file or softcam key file or bin file?
3.key editor or bin editor?
4.downloader?
wich receiver that you want or you have information about it, is ok just give me 1.,2.,3.,.......
Thank you again
Old 30-03-2008   #24
key file
i serch about editing bin file and find some information and understand why no body likes give information about editing bin file
but
in this serch i find that in some receiver you can send key file to it's flash memory
dose any body have information about sending key file to receiver's flash memory and in wich receiver i can send key file?
Thank you
Old 30-03-2008   #25
Topper's Avatar
Well
It is now 7 hours since you posted and it may as well be 7 days. As Rolf has mentioned previously everyone has flicked the switch. You seem to have the wrong concept of what a self help forum is all about. All this information is contained on the forum but it is up to you to go and find it and then try it out and at that point if something does not work as anticipated or as expected then you ask a question. As far as I can see you really only have two options:-
1. Get a dreambox if you are confident about linux ftping chmodding etc
2. If not I would suggest either a patcheable stb like a Technomate
3. Or an FTA box having a Common interface that can take a Dragon Cam.
Again each of those items have sections on the forum for you to go and read.
Show Your Support
Thank you.
card, receiver, smart, software
[IMG] code is Off
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. Uptime monitoring by PageUtils.com
