Visionnet Help
Old 12-06-2008   #1
My System: Visionnet 8000
Visionnet Help
Hey guys, need some help here if possible. I just recently bought a Visionnet.
System Inofrmation
SW : m2.03 VN-8000FS
HW: 8000 - 0.3-SZV0-M1.4DE
A8C0 - FEFE - FF0BEBF4C0F26AB1
From what I understand, this is a card sharing system. Ive been trying to get ART & Showtime. Would greatly appreciate some help
Thanks in advance.
TbMack is offline   Reply With Quote
The Following User Says Thank You to TbMack For This Useful Post:
didoabc (26-10-2008)
Old 12-06-2008   #2
Site administrator
Analoguesat's Avatar
Have you got it plugged into a broadband router with ethernet cable?
Analogue forever!
Old 12-06-2008   #3
Turok's Avatar
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband!
,i think there is no support for visonet is stopped,all servers are ofline
Turok is offline   Reply With Quote
Old 12-06-2008   #4
Site administrator
That would certainly stop it working
Analogue forever!
Old 12-06-2008   #5
Archived Member
I think that you can get a relatively cheap official subscription for both packages in your location, compared to subscribing in Europe.
ShowTime Package
ART Al Awael Package on Nilesat 7W
HB13DISH is offline   Reply With Quote
Old 13-06-2008   #6
The receiver is plugged in to a broadband router. The thing is I had ART & Showtime for around a week until I uprgaded the software. Ever since then its showing Scrambled and the Connection Status is red. Any suggestions?
Old 13-06-2008   #7
Site administrator
Put the original firmware back on it!
Analogue forever!
Old 13-06-2008   #8
Turok's Avatar
there are difrent version of firms out there,im the past there was a firmware,for multichoice,but it does not work with the european bootloader,for asia you have to change the bootloader !
with european loader .you get cecksum error,of you try to load other type of images!
does other channels currencly working in your image?
or is only showtime gone?
if you want you can send the image and i will test it,have the modell without ci slot,the internal cam never works,maybe i have to patch it speratly?
Old 13-06-2008   #9
Thats the actual problem, I do not know the original software. And Turok, Bootloader doesnt even connect to my receiver. All the other channels are there, its just Showtime & ART. What image should i send? Btw you kinda lost me in your last 2 lines, im pretty new to this. Thanks for the help still
Old 13-06-2008   #10
Turok's Avatar
Hi send me your image that you curencly using,long time not upgraded my visonet,i cant contact you via pm,you have disable it in your profil!
Old 15-06-2008   #11
i couldnt figure out how to turn the pm on. couldnt find it in my user cp. anyways i attached the software im currently using. thanks again for ur help
_http://rapidshare.com/files/122709036/m1.70_up_FF_MDR_NL_81_TX1000S.zip.html
Edit by mod:
You will have PM turned on only after posting many posts.
Removed the attached software as it is against the forum rules.
Read them again and again before posting.
If you want to show someone a file, use _www.rapidshare.com
Old 16-06-2008   #12
Graham7's Avatar
You can get a pay server for vissionet if you can get the pay codes if you can find them. If you had a code in for the pay server and you have updated again you will lose the code for the pay server and will have to but a other one in to get it back on. DO NOT UPDATE YOUR STB IF YOU HAVE IT WORKING ON PAY SERVER. I have got SW 1.24 on and I do not update the SW for it.
Graham7 is offline   Reply With Quote
Old 17-06-2008   #13
Guess its too late for that...damage is done SW has been updated. Where do i take it from here?
Old 17-06-2008   #14
Graham7's Avatar
You will have to but a other pay server code in to get it back. If you do get one remember do not update it and write down when you us the code so you know when it runs out.
Old 17-06-2008   #15
Graham7's Avatar
Here how you update to pay server for you.
1.push menu on remote.
2..go installations
3.push fn on remote
4.enter your user id (free selection)
5.enter ip 218.xxx.xxx.xxx from manual
This is what it should look like.
Us name G7(But what you want here not G7)
password (No password)
IP 218.***.***.***(This is the IP you have to us for the s3rv3r)
Do not us the IP from the VN you have to us the s3rv3r IP.
6.push blue key on remote
7.enter your access code manually and confirm with apply
8.wait for message registration successful
9.confirm with apply
10.exit menu
11.done.
wait for s3rv3r connection.
If you cannot get connect do this.
1.Press menu
2.Press installations
3.Goto factory default
4.Press yellow button
5.A box will come on click OK
6.A other box will come on saying (Backup completed)
7.Click OK
8.The box will go off
9.Goto OK and press OK
10.The STB will save the information and reboot
11.When the STB comes back on
12.Click menu
13.Press installations
14.Press FN
15.But in usname
16.Goto IP address and but in the IP ***.***.*.***
17.Goto OK
18.Click apply
19.A box will come on click YES
20.Press exit
visionnet
[IMG] code is Off
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. Uptime monitoring by PageUtils.com
