Technical Assistance about DCW | |
| Member Join Date: 18-10-2008 Location: Egypt
My System: STRONG 4620x |
Dear Firiends , My Receiver is STRONG 4620 x . I need to add DCW decryting software . my question is 1- is DCW decrypting prog. is assiciated with any of the current Decryting progs. i,e CONAX , SECA, iRDETO ... OR it is stand alone soft 2- if it is standalone soft , what is the source soft ware compatable with STRONG 462-x receiver to be loaded , or, what is the website name which have this soft. I am aware of how to download proceedures . Appreciating your sincere assistance Best Regards A.E | ||
| Regular Member Join Date: 31-05-2006 Location: glasgow
My System: 1.2m motorised qualitv decoder manhatten blind search decoder echostar 3600ip | DCW is an option in a cam in the CONFIGURATION menu where you can have it switched off or on.It stands for Direct Control Word and is in either option for different channels.Hope this helps. | ||
My System: STRONG 4620x | Thanks my friend As far as I undersstand from your kind replay that DCW is just an option in the receiver config. manue which can be switshed ( on ,or, off) . and is not an encrypting program as am previously understood. please confirm if what I got is correct. thanks a lot for your concern my best regards | ||
| assistance, dcw, technical |
