how to insert the keys with remote control of hornet
Info exchange on hex/plain/masters, handler/service-keys, Prov-IDs, ChIDs, PPUAs, etc. NO KEYS MAY BE POSTED!
Old 06-09-2009   #1
My System: hornet
please somebody help me! i dont know how to insert the keys on hornet model AT-6030DCIAZ
thank you
sate is offline   Reply With Quote
Old 06-09-2009   #2
Amo Amas Amant Admin
Topper's Avatar
Hello
Welcome to the forum sate
What are you trying to open? most encryptions are now secure and the ones that are not , soon will be. How do you know your stb accepts keys, has it been patched?
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
The Following User Says Thank You to Topper For This Useful Post:
sate (10-09-2009)
Old 06-09-2009   #3
Turok's Avatar
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband!
hi the answer is
here
_http://www.satellites.co.uk/satellite/receiver-software-international-section/28605-how-do-i-enter-keys-kaon-ksc-receiver.html
Turok is offline   Reply With Quote
The Following User Says Thank You to Turok For This Useful Post:
sate (10-09-2009)
Old 06-09-2009   #4
Topper's Avatar
Originally Posted by Turok View Post
hi the answer is
here
Can you confirm they are the same stb Turok
i.e. a KAON 570 = hornet AT-6030DCIAZ?
Show Your Support
Thank you.
Old 06-09-2009   #5
Turok's Avatar
Hi!
i only now this combination,there is no other,should work on all kaons,and hornet also made by kaon!
when you have the orginal software on it,then i think it will not work,you neeed alternative software,that is diffrent from each modell,there are so many in the meantime,that it is a long time search to find the compatible version for your modell!
normaly,the softloader only starts,when you have the right firmware for the stb!
otherwise,it will not begin to load!
the easiest way,to upgrade the keys,is not the menu,yous the kke files with the loader,over rs232,
then the job will be done in secounds!
it can happen,that the boatloader,you have installed,will be not accept the keys,that you load over the com,then nothing would happens!
there are,also many hints,and manuals on the net,where you can change,some modell types,into another type,simply,soldering a bridge,and change some jumpers on the mainboard,for example my kao ksc 520,i can make then,another receiver typ,for the loader programm that would accept it,and recogneized,then a diffrent kaon modell!
good luck!
control, hornet, insert, keys, remote
[IMG] code is Off
