help for echostar dsb-808 2ciInfo exchange on hex/plain/masters, handler/service-keys, Prov-IDs, ChIDs, PPUAs, etc. NO KEYS MAY BE POSTED! | |
| Specialist Contributor Join Date: 05-04-2004 Location: Manchester, UK
| (See prof's earlier post as well at http://www.satellites.co.uk/php-bin/...58&postcount=6 - two answers for the price of one) I've got an 808 2ci viaccess, which I use with a matrix reloaded cam, without any problems, but I don't know about your cams. If you want new firmware, you'll need to register and download at: http://www.echostar-int.com/b2c/us/s...on/default.asp Or you can upgrade over the air (OTA), see: http://www.echostar-int.com/b2c/us/s...ta/default.asp Version 800 is the latest, the readme for it says the following, so it may help with your cam. As far as I am aware, there is no unofficial patched firmware: *** EchoNAV 3.0.1 release *** Embedded Teletext decoder implemented Extended channel information Group and Sort activated during Edit Improved CAM behaviour Improved network scanning and increased scanning speed Improved Search mode (digital IF - limited band scanning) List Access Control (limited channel access) Lock indication added in the channel list Multiple Audio and Video PID support added New OSG languages added (Hungarian and Romanian ) Quick access to timer list and simplified timer settings Rename and Delete option activated for SAT, Network and TP Rename Satellite and Network names USALS (Universal Satellites Automatic Location System) added | ||
| Last edited by guiri; 17-07-2004 at 09:49 PM. Reason: Edit formatting, ref to prof's post | |||
| The Following User Says Thank You to guiri For This Useful Post: | adda (09-09-2007) |
| 2ci, dsb808, echostar |
Similar Threads | ||||
| Echostar DSB 2110 2ci viaccess upgrade problem!!! | joshuatronic | Receiver software, international Section | 3 | 21-04-2005 09:39 AM |
| panasonic tu dsb 30 sky digibox switches itself off - help!!! | pworsley | Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 3 | 24-08-2004 11:14 PM |
| Echostar 808 2ci | GeoffH | Receiver software, international Section | 5 | 17-07-2004 08:13 PM |
| Echostar DSB 2330 2CI | altaf23 | Cams and decoders General | 5 | 15-06-2004 07:42 PM |
| echostar dsb 808 +funcard4 | dave32 | Cams and decoders General | 1 | 19-02-2004 12:36 PM |
