enterd polsat key didnt work
Old 24-07-2005   #1
pothead13's Avatar
My System: Technomate 1500ci + 1000d super + skystar 2 pci card 1M Motorised dish Ivacon twin lnb pc + laptop on network
enterd polsat key didnt work do i have to do something else
al keys ok but channel still black
pothead13 is offline   Reply With Quote
Old 24-07-2005   #2
pothead13's Avatar
its keeps changing the first king
Old 24-07-2005   #3
Hi pothead13,
where are you getting your keys? As Polsat update so frequently it's best to have an AU system, you can find the latest keys here:
_http://www.turkeyforum.com/satforum/showthread.php?t=1194&onlybyuserid=0&page=26&pp=20
Scroll down to 23/7 keys
Best wishes
Mickha
Mickha is offline   Reply With Quote
Old 24-07-2005   #4
pothead13's Avatar
yes im using the last one on that page it is the first time i put keys in
i think i got au system what that mean anyway
do i have to set default key or something
Old 24-07-2005   #5
Hi pothead13,
if you're using the correct keys Polsat should be open, which channels have you been trying, and what equipment are you using ?
If nothing else works try deleting the problem channels and re-scanning.
Best wishes
Mickha
Old 24-07-2005   #6
ghamdan's Avatar
polsat new key 24-7
Polsat Cyfrowy 13°EAST HOTBIRD
Ident: ****
DEC: *****
Key **************************
NO KEYS TO BE POSTED IN THE FORUM
READ THE RULES
I have just noticed this is the second time you have done this in only 4 posts.
Once more and you will be BANNED.
You have been warned
ghamdan is offline   Reply With Quote
Old 25-07-2005   #7
pothead13's Avatar
been told dont work on matrix
enterd, key, polsat, work
[IMG] code is Off
Similar Threads
Matrix Reloaded How To by AHAC rolfw Matrix Reloaded, Revolutions and CAS interface 52 27-12-2005 12:02 PM
---> This is C.sky.Net for 76.5 key ( Viaccess pc2.4) china Viaccess 2 18-07-2004 06:07 AM
PolSat key plz Nokia9800 Keys and Key editing 1 24-12-2003 07:23 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. Uptime monitoring by PageUtils.com
