Fortec Diamond help with keys
Info exchange on hex/plain/masters, handler/service-keys, Prov-IDs, ChIDs, PPUAs, etc. NO KEYS MAY BE POSTED!
Old 27-07-2005   #1
My System: 1mtr Triax dish gold lnb fortec diamond ci reciever
Question Fortec Diamond help with keys
Hi all
could somebody point me in the right direction for updating keys on the above system it is patched but need to get some keys in so i can watch the pron when wife goes out i have the codes menu there but aint got a clue on how to do it total n00b i also have a program called key enchanter found some keys but the keys are .cod format and the keyenchanter needs .ke i believe
any help would be gratefull
regards si
simmy is offline   Reply With Quote
Old 27-07-2005   #2
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
In the code menu, input 1668 to get to the encryption systems.
Rename .cod file to .ke2
Llew is offline   Reply With Quote
Old 27-07-2005   #3
thanks for that info
if i press 1010 that shows me the encryption stuff is that the same thing also can i upload the .cod file after renaming to .ke2 using key enchanter?
regards
Si
Old 27-07-2005   #4
Llew's Avatar
Yes, that's the other code entry combination.
And yes, .cod files renamed .ke2 are used by Keyenchanter.
Old 11-08-2005   #5
My System: USING A LIFETIME DECODER PENTIUM 4 ON WIN XP
key enchanter
someone tell me what a key enchanter is? I am using a fortec lifetime decoder
danda is offline   Reply With Quote
Old 11-08-2005   #6
Llew's Avatar
A program that allows you to upload satellite transponder settings to your Fortec.
Find it here -
_www.zackyfiles.com/secciones/dekos/fortec.htm
diamond, fortec, keys
[IMG] code is Off
Similar Threads
how to enter keys in matrix for Globecast 97.0 W djuro Matrix Reloaded, Revolutions and CAS interface 5 06-06-2008 05:09 PM
Cable Conax Keys (in Finland) Quubee Keys and Key editing 2 30-07-2007 07:46 PM
Fortec Star 5100 Diamond Problems mark_k Receiver software, international Section 2 29-08-2005 11:15 AM
Fortec Star 5100 Diamond queries markhunter99 Digital systems 0 29-03-2005 03:46 PM
How do I get the keys from the data stream? jagost02 Keys and Key editing 1 28-02-2004 09:47 AM
