Golden Intersar Receivers Aes problems | |
| Member Join Date: 14-12-2005 Location: Morocco
My System: Golden Interstar 8005 ci PREMIUM CLASS | Hello ! Well ,i 'd like to know why Golden Intersar Receivers don't accept updating Aes Keys by Remote Control. Is there any Trick for this. As i know for others receivers is possible to do that. Thanks. | ||
| Regular Member Join Date: 31-10-2004
| The software does not accept aes keys by remote, you need a little prog called STBuUtil which opens the software file and allows you change the aes key, save and then upload to your reciever. be careful not to change anything in the main program as this will screw it up if you don't know what you are doing. You can also change the keys in the cas section. You can find what you need at satexperts (google it) you will need to register (it's turkish I think) but they do have an English section. | ||
| aes, golden, intersar, problems, receivers |
Similar Threads | ||||
| upgrade problems with golden interstar 8001 | hass | Receiver software, international Section | 2 | 03-07-2005 05:05 PM |
| Golden Interstar | Lss | Golden Interstar | 0 | 30-05-2005 04:05 PM |
| golden interstar | chinoca | Golden Interstar | 0 | 22-05-2005 08:29 PM |
| Golden Interstar DSR8001Premium -Problems | arbanasi | Receiver software, international Section | 0 | 04-04-2005 12:58 AM |
| HCAS mode in world in box receivers (star sat receivers ) | satellite_2004 | Receiver software, international Section | 0 | 30-11-2004 04:45 PM |
