Digital+ problems
Info exchange on hex/plain/masters, handler/service-keys, Prov-IDs, ChIDs, PPUAs, etc. NO KEYS MAY BE POSTED!
Old 17-01-2006   #1
nilefish's Avatar
My System: DB 500 S,Strong 4622, Viasat Denmark card and receiver, Moteck 2100 Motor, Triax1.1 dish, infinty programmer, cas interface2.
Angry Digital+ problems
Hello every body
I'm trying since 2 weeks to unlock D+ on hispasat or Astra but without success.. I'm mgetting TV cabo ,TPS ,ect so my dish is pionting right but I'm not sure about the ID I have 00400 on Nagra and 006400 and 006700 on Seca !!!! and the keys I have are very long so I don't know where to insert them and I got the same problem with M*Vision AES key can someone help me plaese
nilefish is offline   Reply With Quote
Old 17-01-2006   #2
Mod and septic resident
Channel Hopper's Avatar
I dont think anybody has D+ on Magic Cams or similar.
Old 18-01-2006   #3
nilefish's Avatar
I'm having TM 7755 2CI but still nothing working
Old 18-01-2006   #4
Your profile yesterday mentioned a Starlight, but the same answer applies. I dont think anyone has D+ on the Magic/Matrix CAMS
You will have to be patient
Old 18-01-2006   #5
nilefish's Avatar
thank I have just update my profile.. I know it's possible with the latset patch but I have difficulty patching my receiver ,or to make it short , how to connect RS232 to my PC and make sure it's using COM 1 , because a message -cannot open com port or STB power on appear any help
many thanks
Old 18-01-2006   #6
Are you using the correct lead ?
Old 18-01-2006   #7
nilefish's Avatar
yes sure I got one from the dealer when I bought my receiver and I bought another one from e-bay it RS 232 female to female ..the funny thing is I tried in 2 other pc but nothing happened
Old 18-01-2006   #8
My System: satelite receiver
Can Someone Help Me Step By Step To How,update My Liberty Ci9800 Receiver By Computer,to Get Cabo Tv Etc Thank You
jj34 is offline   Reply With Quote
Old 18-01-2006   #9
Female to female is usually a null modem type
Does the 7755 require serial or null ?
If null, have you tried enabling another port, eg com 3 just in case its sharing protocol with another device ?
Old 19-01-2006   #10
nilefish's Avatar
it's require RS 232 serial port ..so what is the diffrent between the serial and nul ? I tried diffrent com ..but nothing happen the PC cannot detect the cable as a new harware
Old 19-01-2006   #11
The difference is in the cable
If it says serial in the manual, then you will need a serial cable, (and presumably a gender bender ).
Your local PC shop will stock them
Old 19-01-2006   #12
nilefish's Avatar
it says serial but does it look the same as the nul modem 9 pin female to female? I will check the PC shop
Old 21-01-2006   #13
simonnev's Avatar
My System: dm7020s\dream500s\technomate7755 triac 88 moteck motor 45W-42E
I have a 7755 and i used a null modem lead also I am getting 30w 19.2e with the patch
Simon
simonnev is offline   Reply With Quote
Old 21-01-2006   #14
nilefish's Avatar
Simon
That's good to know but how did u connect this cable to the PC as I said my pc cannot detect any new hard ware and I don't know what to choose from the list in the control panel can you help me please
Old 21-01-2006   #15
simonnev's Avatar
just looking through the post again, i notice you have tried it on couple of pc's
So I would think the problem lies elsewhere.
However Is the com port on in the bios? can you see the com port in the device manager? and is it clear of any conflicts?
have you used the com port for other connections?
Sorry to ask a silly question but do you have power on to the stb when flashing?
reason being I read somewhere when flashing, have power off, but i found you need power on
let me know how you get on simon
Old 21-01-2006   #16
nilefish's Avatar
Thanks 4 replying but I got very confused ..I try add hard ware Wizard in the control panel but I don't know which device to choose !!! is it multi port serial adapters? coz there is no nul modem cable in the list ..this nul modem is not a USB for sure and as I said before when I conncet it to the PC nothing happen
Old 21-01-2006   #17
Mick21367
Mick21367's Avatar
My System: Technomate 1000CI Silvercrest (Comag) SL65 (x2 - couldn't resist!)
I don't have experience of that techie but on the TM 1000 the machine doesn't appear on the PC as 'new hardware' - or anything else for that matter. Don't try to add it as hardware. The receiver is just a passive device on the end of a lead as far as your PC is concerned.
The COM port could be any one of up to four listed on your PC. Does your loader have a COM test button? If so, you would probably be able to select which COM port to transmit info through.
Oops - just had a look at the TM loader from their website - obviously everything I've said above is wrong! Sorreee!!!
Mick21367 is offline   Reply With Quote
Old 22-01-2006   #18
nilefish's Avatar
I know the receiver will not appear on the PC as new hardware but I thought the cable will, as any usb or aother input- ouput devices and in the control panel I still don't know what to choose from the list , I made sure that COM 1 is not in use
Old 22-01-2006   #19
My System: dreambox 500 1meter dish motor advent 7017 laptop
have a little look here m8
_http://www.technomate.com/software_updates.php
might be of some help also try this one
_http://www.*****.co.uk/shop/list.php?c=downloads
thomaz is offline   Reply With Quote
Old 22-01-2006   #20
simonnev's Avatar
This is what your looking for in device manager see attched pic..
best bet open device manager and hit print screen, then open ms paint and paste your device manager in the window save as a jpeg and send it to me.. simon
Digital+ problems-untitled-jpg
Old 22-01-2006   #21
nilefish's Avatar
sorry m8 but can you send the attached pic again
Old 22-01-2006   #22
rolfw's Avatar
Real name: Rolf
Sorry, missed it, the attachment needed approving.
Rolf
Old 22-01-2006   #23
Amo Amas Amant Admin
Topper's Avatar
Mmmm
simonnev was just having a chuckle to myself as I noticed on your screenshot the messenger message bottom right. That drove me mad for about four months as quite clearly you are not logging in again from another computer and I was not but after weeks of correspondence with MSN and Microsoft I finally discovered that windows messenger and msn messenger were both installed and loading, I just uninstalled windows messenger and have never had that message since. They are both using your MSN passport and thus arguing all the time as to who should have it.
Digital+ problems-mess-jpg
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 22-01-2006   #24
simonnev's Avatar
Its me just too damn lazy to delete the older messenger. But you now have forced me into it...
Thats about 10 mouse cliks I have just done extra, im off for a good earned rest now...
Simon
Old 22-01-2006   #25
nilefish's Avatar
Simon
Sorry Simon I could not send my device manager to u anyway it looks like this:
Port ( com & lpt )
Communications port ( com5 )
Communications port ( com 6 )
ECP printer port ( Lpt 1 )
when I check COM5 I could c that COM 2,3,4,5,6 r in use
Itry to install to move COM 5 to COM1 but and error code appear ( code 10) saying this device could not sart ..so waht to do???
digital, problems
[IMG] code is Off
Similar Threads
Transponder update 10/07/03 Satdude Transponders & channels 3 01-01-2005 10:24 AM
Transponder update April Satdude Transponders & channels 17 30-04-2004 10:43 PM
Digital Britain: the Ofcom report net1 Terrestrial Television, Digital and Analogue 0 23-02-2004 05:40 PM
IFA 2003 Berlin exhibition report net1 Digital systems 0 01-10-2003 08:02 PM
BBC accused of £500m digital spend net1 Terrestrial Television, Digital and Analogue 0 16-07-2003 07:41 PM
