help with entering keysInfo exchange on hex/plain/masters, handler/service-keys, Prov-IDs, ChIDs, PPUAs, etc. NO KEYS MAY BE POSTED! | |
| Member Join Date: 12-09-2005 Location: surrey
My System: sr 1902 vc |
hi, I have technomate tm1000d and as i am a newbie dont know how to enter the keys. for example for cartoon network: i go to menu--system info---- then there is two menus cas menu and biss menu. in cas menu there is cas, indent and other hex numbers, but i can not find cartoon network under the cas. then there is biss which says cartoon network and says off, then lines of hex keys. can you help pls | ||
| Super Moderator Join Date: 10-12-2004
![]() | Hello hieveryone, you need to post more information, on which Cartoon Network you're trying to open, 13E, 19E and others, as most belong to a package which you update not a single channel. With a Technomate receiver it is easier to load the latest Darkman patch, for the 1000 series, with keys updated, this is especially necessary for TPS has they change their keys every 20 minutes although Cartoon Network doesn't. Best wishes Mickha | ||
My System: sr 1902 vc | hi, thanks for your reply. yes it is 13 e hotbird cartoon network europe. but my reciever(technomate tm1000d ) has not got a ci slot so can i apply the patch to it with the cable? | ||
![]() | Hi hieveryone, just get the cable and download the loader and patch from *****, you will discover it is very easy and quick to patch the receiver and you will gain access to a number of channels. Best wishes Mickha | ||
| entering, keys |
