Keys via remote controlInfo exchange on hex/plain/masters, handler/service-keys, Prov-IDs, ChIDs, PPUAs, etc. NO KEYS MAY BE POSTED! | |
| Member Join Date: 23-02-2004
I have found an excellent little program called: Downloader 2.5 Whenever any of the encryption codes change, I connect to the Internet and run Downloader 2.5. In a few seconds all the changed channel keys are downloaded .My only problem is how to use the downloaded keys to update my CAM using the remote control .I accidently learned that when I receive the Polsat 13E Nagra Key "***********************", I would use the remote control to enter "**********************" instead. I don't know why, but it works. However, I have no clue on how to enter the other Nagra,Seca, Viaccess, and Conax codes using my remote control. Can anybody explain/help pleeeeeeease. Ossama Haggag Keys removed by admin, please observe the rules. | ||
| The Following User Says Thank You to haggag For This Useful Post: | mnashed (29-09-2008) |
| | #2 | |||
| Member Join Date: 11-03-2004
Can you tell me please where I can get this Downloader 2.5 Thank You
| Thanks to all who have viewed my original post. But, doesn't anyone have a reply to my simple query regarding how to enter the codes for various encryption systems via remote control? For Nagra, I enter 700 100 xxxxx. But what about the remaining Viaccess, Seca, Mediaguard, etc...? Best Regards to all, Dr. Ossama Haggag | ||
| | #8 | ||
| Member Join Date: 04-04-2004
Hi all, First thing i have to say is that this forum is great,keep it up guys. I would like to know how can i convert the hex to remote keys with a kind of software,and secondly is it possible to enter seca keys by remote? | ||
| | #11 | |||
| Member Join Date: 04-04-2004 Location: Hyde, Greater Manchester. U.K.
Press the HEX button and enter the 2 hex digits. Then press the DEC button and read off the converted numbers. You may have to put in leading zero's Keith | |||
| | #12 | |||
| | #13 | ||
| Member Join Date: 15-04-2004
| hello , yes downloader 2.5 has a virus in it, good downloader is multicameditor 3.3 who want is write me at paris_frma@yahoo.fr | ||
| | #15 | |||
| Regular Member Join Date: 11-06-2004 Location: Belgium
My System: Multi Lnb dish, pointed to Astra1 &2, Hotbird and 23°.Dreambox and one FTE receiver. | The downloader has a virus, do you know any better one?I know how to update the keys with the remote control. If you still need send me a mail. Thanks
| | #16 | ||
| Hi every body, i can tell about the using of the remote control entry for different enc sys. First u need to know some cheat code of the Rc"remot cntrl" buttons for your type of reciever specially when it's an embedded decr sys. Secondly you should have to know the indent of the hex code will be entered and also, its index.Indent will be 6 digits number, index is 2 digits number, and the hex code to be modified.Last thing is to save your changes and use the codes. | ||
| | #17 | ||
| Member Join Date: 03-07-2004
| http://www.la-cafetera.com/soft.htm Items of interest here...... I am getting a 2.3 m dish. What set top boxes are best? What do I really need to know? Cheers | ||
| The Following User Says Thank You to bmcconac For This Useful Post: | عزت جبر (10-01-2008) |
| | #18 | ||
| Member Join Date: 06-07-2004
I would like to learn how to punch in keys in Humax 5400 using the remote control.What software is needed to get the keys and step by step instruction.Until now i am using funcard 2 and 6-1 files.My humax has ToH3.1. | ||
| | #23 | ||
| Member Join Date: 21-07-2004
| the keys are her www.luy.com | ||
| control, keys, remote |
Similar Threads | ||||
| The Ultimate Idiot Guide! For Idiots by Idiots!Answers,Questions,Tips + Tricks: RTFM! | T_G | Dreambox Guides, Stickies and FAQs | 51 | 11-07-2009 01:14 PM |
| Keys via remote control | haggag | Conax, Cryptoworks, Nagravision, NDS and Others | 8 | 14-11-2006 05:22 PM |
| ZENEGA CD -1002S software needed for Dish TV India- Part II | Tom Robert | Indian Subcontinent General Section | 467 | 02-08-2005 12:55 PM |
| Keys via remote control | haggag | Seca/Mediaguard system | 5 | 22-04-2004 12:35 AM |
| Echostar remote control protocol? | easysat | Digital systems | 0 | 10-10-2003 10:16 AM |
