MM & Strong 4350 ( not so strong !! )You can swap the latest Magic Module news and links here........No Files, No Keys and No Hexes may be posted | |
| Guest
Posts: n/a
Hi all I have SRT 4350 which I understand from some good advisers does not handle MM very will except MM1.01 with Penta1.11. If I am unable to get hold with MM1.01 can I buy current versions and downgrade ? or is this hardware and therefore not feasible ? Cheers | ||
| Member Join Date: 04-02-2003
| the reason a strong 4350 as well asa other receivers like echostar work with a MM101 but not a MM102 / 103 is that the fuse settings in the XILINX XC9536XL chip is different if you put the same code into the XC9536XL from the MM101 into the MM102 you then will get your cam working 100% in your strong as well as getting the kiosk channels this as already been proved as i have done many now all with positive results stevie | ||
| well luckily these XC9536XL chips can be reprogrammed so you need excellent soldering skills a programmer and adapter for this type of device and the MM101 code itself i can send you the code to do it yourself or you can PM me if you want me to do the job for you stevie | ||
| | #5 | ||
| Guest
Posts: n/a
| Stevie Thanks for the feedback. Email me on ciscoexpert@aol.com, I shall give it a go ( since I am stil a beginner I will end up contacting u again). Cheers Sam | ||
| 4350, strong |
Similar Threads | ||||
| srt strong 4350????? | psykotico | Receiver software, international Section | 1 | 16-05-2006 07:19 PM |
| Help me Strong 4350???? | psykotico | Receiver software, international Section | 2 | 03-03-2006 03:13 PM |
| restore software version for strong 4350 | dreher | Receiver software, international Section | 2 | 25-03-2005 12:55 PM |
| MR on Strong 4375 (& Hispasat) | Godzuki | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 5 | 04-05-2004 08:39 PM |
| Strong 4355 rx with Matrix cam | neil.fisher | Digital systems | 0 | 05-02-2004 06:26 PM |
