problems with a Magic ModuleYou can swap the latest Magic Module news and links here........No Files, No Keys and No Hexes may be posted | |
| Regular Member Join Date: 30-06-2005 Location: ENGLAND
My System: DreamBox7000s120HDD,MMv1.05,Fun6,CAS2(add-on)90cm satellite dish,2LNBsDISQ,BSkyB dish,HP Pavilion dv1000 Intel Pentium M processor 1.60GHz 512 MBRAM 60GbHD DVD RW,1 Mb broadb,LAN,PanasonicSA-HT520 home cinema system,28"JVCflat,wide. |
hello, situation is: ive bought Magic Module about 9 months ago On the back of module is written P/N : 8106/2003 v 1.05 i remember long time ago i have put this module into my dreambox 7000s. Common interface menu said Penta 1.1 but i didnt use it till now anymore. when i try to put know CI says DREAMLOAD. WHY?????? ive got CAS2 as well. So, ive tryed to flash it. connected CAS2 to my laptop, run cas studio 6.1, pressed "connect" ive got : CAM connected Xilink XC9536XL CPLD Version 3 detected Functionality not warranted Flash unknown : Manufacturer ID : 0x0090 ID : 0x0000 Detecting CAM Pressed Erase All and i have "Erasing Error on Block 0,1,2,3...............34. Erase compleated. i extracted my Penta 1.11 rar file ive got penta1.11.mbf (or something....), changed to .bin(just changed 3 last letters) After that i started to write Penta 1.11 After mesagge "flashing compleated" just pressed EXIT.(once i tryed write Xilink, but the same problem anyway) i put Magic Module into the Dreambox....and have DREAMLOAD. ive tryed 3 or 4 times....same problem. any idea??? thank you very much | ||
| | #2 | |||||
Sorry i cannot help you with the CAS 2 as I have never used one to flash a magic cam | |||||
My System: DreamBox7000s120HDD,MMv1.05,Fun6,CAS2(add-on)90cm satellite dish,2LNBsDISQ,BSkyB dish,HP Pavilion dv1000 Intel Pentium M processor 1.60GHz 512 MBRAM 60GbHD DVD RW,1 Mb broadb,LAN,PanasonicSA-HT520 home cinema system,28"JVCflat,wide. | because CAS cant find mbf file. In the guide is written : need to upload .bin file So, i have changed 3 last letters after dot. Or...maybe i am wrong, do i need to change it by another way? | ||
| | #4 | ||||
| | #5 | ||
My System: DreamBox7000s120HDD,MMv1.05,Fun6,CAS2(add-on)90cm satellite dish,2LNBsDISQ,BSkyB dish,HP Pavilion dv1000 Intel Pentium M processor 1.60GHz 512 MBRAM 60GbHD DVD RW,1 Mb broadb,LAN,PanasonicSA-HT520 home cinema system,28"JVCflat,wide. | hi, what exactly program do u mean? to convert .mbf to .bin? thanks | ||
| | #6 | ||
My System: DreamBox7000s120HDD,MMv1.05,Fun6,CAS2(add-on)90cm satellite dish,2LNBsDISQ,BSkyB dish,HP Pavilion dv1000 Intel Pentium M processor 1.60GHz 512 MBRAM 60GbHD DVD RW,1 Mb broadb,LAN,PanasonicSA-HT520 home cinema system,28"JVCflat,wide. | and couple more questions...can anybody explain to me, what can happen if i load penta 1.11 to my Magic Module?I mean if it would be non original.I ve got 8106/2003 v1.05.as i heard it is not original card.but...i remember, when i bought that CAM was loaded penta 1.1 thank you | ||
| | #7 | |||
| | #8 | ||
My System: DreamBox7000s120HDD,MMv1.05,Fun6,CAS2(add-on)90cm satellite dish,2LNBsDISQ,BSkyB dish,HP Pavilion dv1000 Intel Pentium M processor 1.60GHz 512 MBRAM 60GbHD DVD RW,1 Mb broadb,LAN,PanasonicSA-HT520 home cinema system,28"JVCflat,wide. | sorry ,mate CAS guide.i mean during the programming.In the same window is written.Upload the .bin file. and xilink need to upload before flashing or after? thanks | ||
| | #9 | ||
My System: IDD CI24 ECONO MM Penta 1.20 Galaxy II 1.2Mtr Polar MTG yes it has been on the arc for 21 years and is still driven by a modified wiper motor from a Ford Anglia. It's like me sometimes groans but always performs ![]() Saved us from the black plague of ignoratio elenchi, he awaits a special badge with jugs | As I explained I do not have a Cas interface I use a magic module rs232 programming card like the one shown. I suggest you use the dedicated web site to find out how to do successfully program your module using CAS interface by clicking here This takes you direct to the correct English section of casinterface.nl where step by step details are given. Good luck | ||
| War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back Last edited by Topper; 07-07-2005 at 09:34 PM. | |||
| | #10 | ||
| Member Join Date: 16-10-2005 Location: LIVERPOOL
My System: humax5300 sammy dsr9500 Dragon twin reality MM MR |
i know it's an old post but here goes the cas2 software will accept both .bin and mbf without the need to change .mbf to .bin you need to load dreamload.bin first when complete, change the start address to 10000 then load the penta file. or look for penta 1.09 or 1.11 full dump which is dreamload + penta file all in one. when complete, put cam into receiver, if you see DREAMLOAD, switch receiver off then on http://www.satellites.co.uk/php-bin/...ons/icon14.gif and it should show pent1.09 or whatever is on cam. regards spider | ||
| magic, module, problems |
Similar Threads | ||||
| magic module and icecrypt cam. | radiotech | Magic Module | 9 | 19-12-2005 11:51 PM |
| manhattan 5500 magic module | wopla | Magic Module | 12 | 28-08-2004 06:51 PM |
| Magic Module connection problems | naffats | Magic Module | 8 | 01-04-2004 02:54 PM |
| FAQ:Programming the Magic Module for the second time or more | Nickolai | Magic Module | 0 | 19-09-2002 12:44 AM |
| FAQ: Programming the Magic Module for the FIRST time | Nickolai | Magic Module | 0 | 19-09-2002 12:41 AM |
