Magic CAM: what the future holds?
Thread Tools Display Modes
Old 01-08-2003   #1
jimbo's Avatar
My System: Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
questions on magic module
Personally, I feel the MM may be on the cusp of it's usefulness now that the ice cams (such as blue ice) are handling 6 in 1 although I appreciate that Connax is not available to the ice but is on the MM. For lovers of porn, the blue ice also offers 2 'built in' porn channels so can decrypt 3 channels from the one CI slot in turn. The green ice willl have 4 channels programmed in late this year. Updating of the ice cam is easier for those whose receiver is not near their PC because it can be done with C2 x Fun4s or 1 x fun5. I think the support for the ice is far better than for the MM and the debacle of the bad software in Penta 1.10 which wiped many of them has made me rather wary.
__________________
Jimbo
jimbo is offline   Reply With Quote
Old 01-08-2003   #2
Nickolai's Avatar
Jimbo,
In a nutshell, I agree. Specifically on the support site. I feel that the lost court case vs SCM at the time signalled the decline of MM, as it had to go "underground".
I am almost thinking of getting the Ice cam myself
Just to clarify, there is currently no Conax access on MM for hobbyists. Do you mean that one can use MM with an official sunsription card instead of the Conax cam, and if so, are you sure?
Also, what about the rumoured Magic II - may be that will cut more mustard.
Anyway, I think, Magic was a revolutionary and innovative product for the time, it gave us all long pleasant hours and deserves for that!
__________________
Nickolai
Echo AD3600, Magic v.1.01, Penta 1.11
Nickolai is offline   Reply With Quote
Old 05-08-2003   #3
easysat's Avatar
My System: Dreambox 7000S + motorised 80cm dish, Amstrad DRX550 Digibox + fixed dish
Just to clarify what you are saying: you're saying that MMs are in a grey area legally but Icecrypt CAMs are fine legally because they include a CA system that is used by a couple of European channels ? To me there seems to be little practical difference in their uses.
Mind you, I am curious how people discover how to flash these modules into more exotic beasts. Is is just intuition or are they software gurus or did they have access to some design information? Presumably the SIDSA chip comes with all the info needed to program it when you buy it. But where do you get info about whatever is in the Icecrypt?
__________________
pc::
easysat is offline   Reply With Quote
Old 05-08-2003   #4
jimbo's Avatar
I had the impression that the MM will decrypt a conax official card but I do know that the Ice will not. The Ice is advertised on the 'Don't Panic' channel (why is it called that?) so purchasing it seems perfectly legal to me. As for programming it, I'm not sure about the vagaries, only where to obtain the updates. I don't have any knowledge of the MM II, Nickolai but would be interested if you have.
__________________
Jimbo
Old 06-08-2003   #5
Irish Mod
Razor's Avatar
According to adds in whatsat mag The Green ICE cam will be available in Sept/Oct and will have 4 H/C channels.
__________________
Don't mind my spelling
Razor is offline   Reply With Quote
Old 31-08-2003   #6
jamidonuts
Posts: n/a
Hi guys I am new to the hobby and bought a MM Having all probs. I got bin files and Mastera 4 with gold & Silver Cards. Do I have to change Bin to Hex for card to work. Love the hobby but utterly lost.
Old 31-08-2003   #7
rolfw's Avatar
Yes, convert to hex files, or you can find them on Phill's, see Nobbly's big links list.
__________________
Rolf
Donate
Old 31-08-2003   #8
Overclocker Supreme & General Mad B*st*rd
Burnt Chips's Avatar
As far as i understand it (up till now the ICE ver of cams, all pay an amount to the provider as a form of subscription) What you can do with the CAM after that "is the GREY AREA". Now the "much awaited Green ice" with 4 NEW xxx porn Channels
wont be so legal ?. Only four XXX porn channels i know "that aint hacked are the Satisfaction Channel group" VIA2 (as IRDETO2 aint hacked) So cant see these being subscrition (as cards range from £130 each channel). But a lot of rumors flying about "at the moment" most ive had confermed elsewhere, and MM`S, HUMMIES, and likewise could soon be dinosaurs, To sit next to D2MAC boxs.
Burnt Chips is offline   Reply With Quote
Old 14-09-2003   #9
-- BIG GUN SPECIALIST --
>COR<'s Avatar
Think this will not happen so fast.
As original MM it will go on for a long time doing 6 in 1 files.
With the CAS interface it is easily reprogrammed to MR, and works fine.
Due to the better quality of chips the magic works fine here in Matrix Reload moe 1.03.
No time yet for the MM to be on the stack of redundant equipment...
CHeers,
Cor.
>COR< is offline   Reply With Quote
Old 14-09-2003   #10
Originally Posted by >COR<
CHeers,
Cor.
HI COR M8, Put it this way "WOULD YOU GO OUT AND BUY "a new £140
MM, or is there plenty above this in the queue,
Old 14-09-2003   #11
>COR<'s Avatar
Well,
In the UK they may be that price , here 125 euro's is more normal m8.
So, the mainland is a lot cheaper and more people will buy them for that price since the clones are not that much cheaper too.
And as MR the magic can work for the next year nicely m8, have 2 running here, testing them and now waiting for 1.04 software to be put on them.
What is the alternative? ice crypt cams, doing the same as the magic with 6 in 1 cards, and a few xxx channels , not a real winner too.
Dragon cam? not since the first bach was recalled for broken welds and in 95% of the recievers incompatible, and now the N*S is not on them, just another ice clone.
SO, no real new cams out there, and with a CAS interface i have at least full control over the magic/matrix/clone cams.
CHeers M8,
Cor.
[IMG] code is Off
Forum Jump
Similar Threads
diablo cam wolfav Cams and decoders General 0 08-05-2006 04:28 PM
Matrix Reloaded How To by AHAC rolfw Matrix Reloaded, Revolutions and CAS interface 52 27-12-2005 12:02 PM
magic module and icecrypt cam. radiotech Magic Module 9 19-12-2005 11:51 PM
magic cam programmer richardp Cards & Programmers General 1 02-12-2003 07:28 PM
Axas Cam and Dreamload jderby Cams and decoders General 2 28-08-2003 05:52 PM
