magic module and icecrypt cam.You can swap the latest Magic Module news and links here........No Files, No Keys and No Hexes may be posted | |
| Regular Member Join Date: 16-05-2003 Location: USA
I am new to this magic and icecrypt cams. I'm in N.America and i have to use two receivers for receiving irdeto1 and viaccess1 channels from telstar 5. I bought the receivers cheaply from Ebay | ||
| Regular Member Join Date: 01-01-2000 Location: Berkshire
| Yes, radiotech - both multicrypt cams will do the job. You need to be careful when selecting receiver/ CAM combination as not all of them marry well together. Regards, Nickolai | ||
| Nickolai Echo AD3600, Magic v.1.01, Penta 1.11 | |||
| Thank you Nikolai. Do you have any recommendation for the receiver/magic cam combination? thanks again. I can purchase bec, satcruiser, or coship receiver with CIs in north america. | ||
| | #6 | |||
| Regular Member Join Date: 05-02-2004 Location: it prepares the Magic Cam, or either to leave in dremload
I WAIT URGENT RETURN? HOFFMANN/BRAZIL | |||
| | #7 | ||
| GOOD AFTERNOON donhatem! AS I PROGRAM MAGIC CAM IN RECEIVER SATCRUISER ? I WAIT URGENT RETURN? HOFFMANN/BRAZIL | ||
| | #8 | ||
| Member Join Date: 01-06-2004
| Hi ! there seems to be a lot of poeple in here who have done their time with all types of reciever setups. My problem is > I have an extreme" looks like the latest model " receiver one Magic Module and a couple of fun cards . however now is the time for programming them which I have done with hex files and a serial port card read/writer. I wanted to know what is the most hassle free method of either programming the MM or the funcards '" one is a 4th generation open platform "" card. so in a nut shell, what hardware do I need > how much and where to get! software and support files > how much and where to get? sorry to sound Blunt its just exactly what I need... I think! Kind regards Scorps PS Do laptop PCMCIA slots ever double as a medium to program a magic module or similar??????????????????????????????????????????? ??? | ||
| | #9 | ||
| Regular Member Join Date: 01-01-2000 Location: Manchester
| Hi scorps, how's it going? First off, where are you and what do you want to recieve? The next couple of bits that you need to buy are a cas programmer from duolabs, check the sponsers of this site, this will update the software on your magic module and change it to a matrix reloaded cam. Fairly easy to do and only around £30-£40. Make sure that you already have a printer cable to connect the cas. From my experiance the next thing would be a Smartmouse/Phoenix card programmer, around about £15-£20. Then buy a Titanium card. These are quite dear at around £40 but they have worked well for me over the past six months and have quite a lot of support on the net. The next thing to do is read through this forum and try messing about with all your new kit. If you get stuck we'll all jump in and help out if we can. And finally, laptops can program your cam if you have the right drivers installed on it although I've never tried it myself. Be lucky, and don't rely on this as your major source of T.V. just treat it as a hobby and you won't go far wrong, Regards, Dom. | ||
| Don't play silly buggers with me because I always win! | |||
| cam, icecrypt, magic, module |
