BISSCAM KeyingAll information about the Matrix Reloaded and Revolutions CAMs, plus the CAS interface for programming MMs, MRs and UCAS embedded modules. | |
| Member Join Date: 16-07-2008 Location: Bayern
My System: ASTRA |
I test at present the BISS-CAM - firmware on a MatrixReloaded. I use: 1) Biss_10final.bin (firmware 129kB) 2) Softcam.key (current version) 3) EmuKreator v2.27 4) BISS-Editor v1.9 5) CAS interface 6) CAS studio v2.1 Problems result in the case of editing the providers and the keys. EmuKreator transfers the Softcam.key to the associated masks. The entries can be worked on and be secured also as control file *.txt. Under the point of menu BiscamEditor lets itself assign the Biss_10final.bin. With the function INSERT EMU provides EmuKreator a changed Biss.bin file (580kB). Loding this file in with the CAS takes place without error message. The CAM is recognized afterwards in the receiver, not however the added providers nor keys. The appropriate menu indication of the Cam is empty. What goes there wrong? Test way produced a Bin_key.bin with the BissEdit.exe from the same Softcam.key. This file is only 4 KB largely and must obviously still the Biss_10final.bin be still caused. I do not know for it planned the expiration however. Who knows more to it? For each reference I am grateful. Thanks. | ||
| The Following User Says Thank You to ticra For This Useful Post: | Ratoju (29-07-2009) |
| bisscam, keying |
