Using CAS 3 with UBUNTUAll information about the Matrix Reloaded and Revolutions CAMs, plus the CAS interface for programming MMs, MRs and UCAS embedded modules. | |
| Member Join Date: 04-05-2008 Location: N.Ireland
My System: Dreambox 500sDarkstar 2 image, Darkbox Super 2008 HD, Fortec Star 90cm dish SG2100 Motor. Diablo 2.3 |
Hi All I have recently made the change from windows to ubuntu, very easy and pain free apart from one. Is it possible to get the cas studio working under linux? it will not work with wine, nothing happens. I tried loading a virtual xp and the programme installs ok but the drivers dont, when i look in task manager the icon is yellow beside the drivers, trying to install the drivers manually doesnt work. This is more than likely due to the virtual xp not supporting usb that easily. Has anyone tried this with any success, if its not possible i can still reboot into windows and run it from there but it would be nice to try have everything running under linux (sort of) | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Don't think there's any specific Linux support for Jungo drivers as used for the CAS interfaces. It may be possible to build one, but I wouldn't know where to start. _www.jungo.com/st/linux.html Llew | ||
| The Following User Says Thank You to Llew For This Useful Post: | berty642 (03-11-2008) |
My System: Dreambox 500sDarkstar 2 image, Darkbox Super 2008 HD, Fortec Star 90cm dish SG2100 Motor. Diablo 2.3 | Thanks for the reply, i havent a clue about building drivers either, i think the easiest is a reboot into windows and do what needs to be done | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | I'm still trying to find one for Linux for my Skystar HD2 card (Mantis driver). Otherwise, plenty of apps to play with on my distro (Linux Mint). Llew | ||
| The Following User Says Thank You to Llew For This Useful Post: | delvin (29-03-2009) |
| cas, ubuntu |
