CAS 3 Waiting to Start ProgrammedAll information about the Matrix Reloaded and Revolutions CAMs, plus the CAS interface for programming MMs, MRs and UCAS embedded modules. | |
| Member Real name: lanun cas studio Join Date: 08-02-2009 Location: malaysia
My System: cas studio | Currently i'm using WINDOWS XP Pro. When I try to run cas3 with cis8.6b programmed I just get a screen pic with "waiting to start programmed..." programmed does not start. I have done restart pc then run CIS 8.6B and plug cas3 into usb. Already follow readme procedures but still with same problem. Previously this CAS3 working well with CAS7.4 until that software expired. Need Help.. ![]() ![]() | ||
| Regular Member Join Date: 26-04-2006 Location: Ireland
My System: Dreambox 7025, Dreambox 500s, Technomate 6900 Super, Foxsat HD Freesat, 90Cm and 1.2 CM | Hi mate, Did you start the program without the cas connected, I have the feeling that you need to run it the first time without the programmer connected. I have not usd either of my cas interface programmers for years now, but as far as I can remember you must run the software with the cas connected. Regards Wez | ||
My System: cas studio | already done.. 1. Start Cas Interface Studio 8.6b. (display show >> Pelase Connect the device in your USB Port) 2.Connect CAS3 to USB Port. (display show >> CAS Interface 3 Connected.Waiting to start program......) ............go on waiting to start program. | ||
| | #5 | ||
| Super Moderator Join Date: 10-12-2004
![]() | Try uninstalling all the Cas software currently on your computer, disconnect your Cas 3, re-install Cas 8.6b and then connect your Cas 3 programmer. Also check in Device Manager to see if the software is correctly installed, right click on My Computer, click on Properties, Hardware and Device Manager. | ||
| | #6 | ||
My System: cas studio | already uninstall and re-install Cas 8.6b.. Device manager show >> JUNGO Install >Win Driver >Cas Interface 3 USB (only appear when USB connected) Still with same problem.....keep waiting to start program... please help | ||
| | #7 | ||
![]() | Try a differwnt USB slot and cable, if this fails try installing it on a different computer, using 8.6b. The problem might be in the Windows registry, which can be repaired using a system restore or by re-installing XP. | ||
| | #9 | ||
My System: cas studio | Bad luck for me…after install CAS8.6b to new PC with fresh windows XP Pro SP3, same problem still remain. CAS 3 Hardware can be Diagnostic / firmware update ? Much Appreciates for your advice. | ||
| | #10 | ||
| Member Join Date: 27-07-2009 Location: uk london
My System: techomate TM 5400 CI+USB -PC IMEDIA A3317 UK Windows vista home bacic.AMD phenom(TM) 8550 triple core processor.3.00GB RAM.AT Radeon 2100 PACKARD BELL | hi can any one tell me how to programe with cas interface3? i have it 4 years and never managed. thanks | ||
| cas, programmed, start, waiting |
