Can I do anything with a Matrix CAM?All information about the Matrix Reloaded and Revolutions CAMs, plus the CAS interface for programming MMs, MRs and UCAS embedded modules. | |
| Member Join Date: 08-05-2004
Hi guys, Years ago I bought a Matrix CAM with my first digital receiver. Never actually used it then I bought a CAS 2 programmer, never really used that either. So is there anything I can use my Matrix cam on these days? Thanks, Mark. | ||
| Super Moderator Join Date: 10-12-2004
![]() | it depends which version of the Matrix Cam you have as I believe there are still some files for the Matrix Revolution or Reborn, so they can still open Digi TV. Official support for the Matrix cams ended some time ago so I don't think there's much use for the older Matrix Cams, except as a card reader. | ||
| Manic Midlander Moderator Join Date: 24-09-2006 Location: West Midlands. UK
My System: Dreambox 7020si, Technomate TM600, Technomate TM9100 Fracarro Penta 85 Dish, Televes 0.6dB Quad lnb, TM SG2200 motor. 60cm Channel Master BSB dish on 28e, Mti Blueline 0.2db Twin Lnb. Rover ST-4 Meter Cyfra+ Subscription | Like Mickha said you can still probably open DigiTv with them and use it as a card reader. ![]() I just use my original matrix cam to stop the table from wobbling in the kitchen ![]() Matrix cam on one side and an old On Digital Cam on the other ![]() ![]() Nano | ||
Sanity is nothing more than an excuse to be boring <<<<<<<<****** Dreambox DM7020 Si , S.I.F 1.9.3d ******>>>>>>>>> <<<<<<<<******** Technomate TM9100, EDG 4.4 ******** >>>>>>>> <<<<<<<<<<******* Technomate TM600, UR 23 *******>>>>>>>>> | |||
| cam, matrix |
