Xilinx problem with MATRIX REVOLUTIONS
Thread Tools Display Modes
Old 28-09-2004   #1
Question Xilinx problem with MATRIX REVOLUTIONS
I think i have a big problem with my matrix revolutions cam !!
I have erased the xilinx file, not knowing anything about it.
Is there a possible way to return a xilinx file to the cam ??
Would be nice though so I can use it again.
TNX for helping me out here.....
GRTZZZZZ.... RYVM
ryvm is offline   Reply With Quote
Old 28-09-2004   #2
rolfw's Avatar
You should be able to do it with a CAS interface RYVM.
__________________
Rolf
Donate
Old 28-09-2004   #3
Jaffer's Avatar
My System: Samsung A300W with component output Hotbird & Astra2
Get the file downloaded (i believe you can get it from some source - i dont have rev). In CAS press connect, then press Xilinx where it will look for the file click on the right file - All done.
__________________
Every little helps and a little help goes a long way!
Jaffer is offline   Reply With Quote
Old 28-09-2004   #4
Jaffer's Avatar
Sorry ROLF i have CAS2 not CAS.
__________________
Old 29-09-2004   #5
But where can i find a original xilinx file for the revolutions cam ?
Thats my biggest problem i think
A cas2 interface is coming to me soon i hoop.
Tnx for helping me out here.....
Greetz Rein
Old 29-09-2004   #6
Jaffer's Avatar
Can you please tell me what it says when you click on Connect. I am at work now. I will try toget a file for you when get home this evening.
__________________
Old 30-09-2004   #7
Smile
I have to wait a bit longer when my cas 2 interface arives, it will be here shortly i hope.
Then i will tell you wat I see when I press connect.
Grtz Rein
Old 04-10-2004   #8
Angry
At last i have my cas2 interface.
This is what i see when i press connect :
CAM Connected
Xilinx XC9536XL CPLD Version 4 detected
Searching for flash...
Functionality not warranted
Flash unknown: Manufacturer ID: 0x90 Device ID: 0xC2
Grtz Rein
Old 04-01-2005   #9
Help Me Please
I HAVE THE SEEM PROBLEM DID YOU FOUND A SOLUTION FOR YOUR MCR ?
CAM Connected
Grtz Rein
bonami is offline   Reply With Quote
Old 06-01-2005   #10
Nope I have not found a solution jet.
I do not know if there wil be a solution for this problem.
If You lnow something about it please tell me.
Good luck
RYVM
Old 07-01-2005   #11
use this m8 works 100% read the read me
neil306 is online now   Reply With Quote
The Following User Says Thank You to neil306 For This Useful Post:
murien (29-05-2007)
Old 09-01-2005   #12
Talking
WORKS GREAT DUDE !!!!!!!
No problem at al with mrev 216
Thanks you very much....
Grtzz.... RYVM
Old 14-01-2005   #13
Thumbs up
thanks neil306 sorted my cam out too have been searching all top man
gfcc1 is offline   Reply With Quote
Old 23-01-2005   #14
i have a "fortecstar magic world plus" receiver with embedded matrix (i have alredy upgraded it to mrv2.16 using fun cards)
i can update the matrix embedded only using fun cards but the problem is:
the mrv2.16 doesn't support card read
so if it's possible: i can update it using the serial connector found in the back side of the receiver
i just need a matrix loader that can upload bin files to my receiver!!!
i have the mrv2.19 binary file but i dont have the appropriate loader to transfer it to the stb!!!
pls help
mail:
kaisounovsky*yahoo.fr
trappa is offline   Reply With Quote
Old 25-02-2005   #15
adn
have you got ???
trappa,
have you got what you 're looking for ? I do need the same. thx for helping anyone here.
pls help
mail:
adn is offline   Reply With Quote
Old 26-02-2005   #16
hi everyone
i have a astrovox with embedded matrix revolution version 2.19
i want to know how to upgrade the version with cable rs232 i have laptop presario 1120
help me and tell me how to upgrde step by step because Iam beginer in this .
fantazma is offline   Reply With Quote
Old 01-03-2005   #17
hi, you can try matrix DN here : http://www.uploadfly.com
module area-> matrix rev/rel
i have not tested but it might work :-)
MrFreeze is offline   Reply With Quote
Old 02-03-2005   #18
My System: yumatu asus
Smile xilinx matrix revolution
Great great )) I used it and my mrev. work again, thank you so much
lazaronon is offline   Reply With Quote
Old 03-03-2005   #19
adn
how to
Can you give me some explanation how to use please.?
Old 08-03-2005   #20
hooo sorry :-/
I never use it
Old 09-03-2005   #21
adn
Thumbs up Yeah, so great site for cas 2 and MRV
Hi all,
this site is of great helpfullness. I had big concern with MRV and after buying cas 2 as I can read here, upgrade was OK. recover my sweet MRV now at 2.2.
Thaks to you all.
Old 23-09-2005   #22
My System: Echostar DVR7000HDD, Motorized Triax 110cm.
Thumbs up
thanks a lot m8, this sorted my kinda dead MRV.. it was programming well, but when inserted in receiver it wont clear any channels, soon as i loaded this jed file it was all 'clear'
F31SAL is offline   Reply With Quote
Old 26-07-2006   #23
My System: i setup through private engineer
hi i had same problam with matrix reborn z-cas cam
can anybody find the file for it.
thanks in adv
jerenus is offline   Reply With Quote
Old 22-08-2006   #24
My System: i a god shearsheer if matrix key
Angry plz HELP§
I HAVE A NOT GOD MRV2.19 PLZ HELP ME AND MY DREAM IS ENTER A AES KEY TO THE MATRIX
bouckedi is offline   Reply With Quote
Old 25-08-2008   #25
My System: multi lnb
Wink initalizing problem.
Hi
can some one please point me in the right direction. i have a matrix revolution cam i have tried to progam the firmware using cas 3.
After writing the firmware and then pressing verify it shows multiple errors. so tried the process from scratch when i select erase it does nothing and frezzes in that mode.
Thanks for your help in advance.
shakyA23 is offline   Reply With Quote
Forum Jump
