Xilinx problem with MATRIX REVOLUTIONSAll information about the Matrix Reloaded and Revolutions CAMs, plus the CAS interface for programming MMs, MRs and UCAS embedded modules. | |
| Member Join Date: 28-09-2004
| I think i have a big problem with my matrix revolutions cam !! I have erased the xilinx file, not knowing anything about it. Is there a possible way to return a xilinx file to the cam ?? Would be nice though so I can use it again. TNX for helping me out here..... GRTZZZZZ.... RYVM | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | You should be able to do it with a CAS interface RYVM. | ||
| Specialist Contributor Join Date: 19-05-2004 Location: South East England
My System: Samsung A300W with component output Hotbird & Astra2 | Get the file downloaded (i believe you can get it from some source - i dont have rev). In CAS press connect, then press Xilinx where it will look for the file click on the right file - All done. | ||
| Every little helps and a little help goes a long way! | |||
| | #6 | ||
My System: Samsung A300W with component output Hotbird & Astra2 | Can you please tell me what it says when you click on Connect. I am at work now. I will try toget a file for you when get home this evening. | ||
| | #8 | ||
| At last i have my cas2 interface. This is what i see when i press connect : CAM Connected Xilinx XC9536XL CPLD Version 4 detected Searching for flash... Functionality not warranted Flash unknown: Manufacturer ID: 0x90 Device ID: 0xC2 Grtz Rein | ||
| | #9 | |||
| Member Join Date: 28-10-2003
I HAVE THE SEEM PROBLEM DID YOU FOUND A SOLUTION FOR YOUR MCR ?
| | #10 | |||
Nope I have not found a solution jet. I do not know if there wil be a solution for this problem. If You lnow something about it please tell me. Good luck RYVM | |||
| | #14 | ||
| Member Join Date: 02-12-2004
| i have a "fortecstar magic world plus" receiver with embedded matrix (i have alredy upgraded it to mrv2.16 using fun cards) i can update the matrix embedded only using fun cards but the problem is: the mrv2.16 doesn't support card read so if it's possible: i can update it using the serial connector found in the back side of the receiver i just need a matrix loader that can upload bin files to my receiver!!! i have the mrv2.19 binary file but i dont have the appropriate loader to transfer it to the stb!!! pls help mail: kaisounovsky*yahoo.fr | ||
| | #15 | |||
| Regular Member Join Date: 17-02-2005
trappa, have you got what you 're looking for ? I do need the same. thx for helping anyone here.
| | #16 | ||
| Member Join Date: 23-02-2005
| hi everyone i have a astrovox with embedded matrix revolution version 2.19 i want to know how to upgrade the version with cable rs232 i have laptop presario 1120 help me and tell me how to upgrde step by step because Iam beginer in this . | ||
| | #17 | ||
| Regular Member Join Date: 10-02-2005
| hi, you can try matrix DN here : http://www.uploadfly.com module area-> matrix rev/rel i have not tested but it might work :-) | ||
| | #19 | |||
Can you give me some explanation how to use please.? Thanks | |||
| | #21 | |||
this site is of great helpfullness. I had big concern with MRV and after buying cas 2 as I can read here, upgrade was OK. recover my sweet MRV now at 2.2. Thaks to you all. | |||
| | #22 | |||
| Member Join Date: 14-03-2005
My System: Echostar DVR7000HDD, Motorized Triax 110cm. |
| | #23 | |||
| Member Join Date: 30-05-2005
My System: i setup through private engineer |
can anybody find the file for it. thanks in adv | |||
| | #25 | ||
| Member Join Date: 24-08-2008 Location: uk
My System: multi lnb | Hi can some one please point me in the right direction. i have a matrix revolution cam i have tried to progam the firmware using cas 3. After writing the firmware and then pressing verify it shows multiple errors. so tried the process from scratch when i select erase it does nothing and frezzes in that mode. Thanks for your help in advance. | ||
| matrix, problem, revolutions, xilinx |
Similar Threads | ||||
| Matrix Revolutions Cam problem | T-E-E-N-A | Cams and decoders General | 21 | 25-09-2005 01:56 PM |
| Matrix revolutions problem | vladvas | Matrix Reloaded, Revolutions and CAS interface | 4 | 26-01-2005 09:24 AM |
| matrix problem | freddeifk | Matrix Reloaded, Revolutions and CAS interface | 5 | 21-01-2004 08:40 AM |
| Matrix question... | ixer | Matrix Reloaded, Revolutions and CAS interface | 1 | 02-01-2004 06:50 PM |
| is this a diseqc problem | doggy | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 14 | 05-09-2003 02:44 AM |
