allcam/matrix/magicAll information about the Matrix Reloaded and Revolutions CAMs, plus the CAS interface for programming MMs, MRs and UCAS embedded modules. | |
| Member Join Date: 04-05-2003
hi i just wanted to know a thing that might seem simple to you. what benefit (in slight detail) would i get if i replaced the all cam irdeto from my receiver with 1- magiccam 2-matrix reloaded cam? since at least the magiccam will offer me the same the allcam does thanx | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | The first difference is that the Magic and matrix can accept original cards from several encryptions, the Irdeto based Freecam will only accept original Irdeto based cards or x in 1 type cards. The second is that the Irdeto will Emulate Irdeto based encryption cards (no card needed), but the Magic and Matrix can Emulate several encryptions and also autoupdate on some (nagravision for instance). The Irdeto based Free/Allcam is probably at the limit of its capability, whilst the other two and in particular the Matrix Reloaded,have much more scope with ongoing software versions being produced and the hardware itself being more powerful. | ||
| thanks rolfw but do you mean that if i can get the matrix cam i won't be needing any funcard to go along with? and also is there any difference concerning the channel zapping time between the allcam and the magic cam since that the allcam emulates already and that could be a load on the system lastly if i get the matrixcam right now knowing that my topfield 3000ci is patched with all cam software ,do i have to change the software or it's just remove that ,put this .] thank youi again | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Not sure how well the Matrix reloaded and Magic Module work on the Topfield. The zapping as a rule, is quite a bit quicker on the MR than on the Irdeto CAM, the CAM has a better processor so can handle the higher workload. To be able to update the MR CAM and view some channels, you will need a funcard 5 or 6. | ||
| allcam or matrix or magic |
