matrix reloadedAll information about the Matrix Reloaded and Revolutions CAMs, plus the CAS interface for programming MMs, MRs and UCAS embedded modules. | |
| | #26 | ||
| Member Join Date: 01-03-2005
My System: BEC 6600 CI | a big thanks to norm for helping me out and sending the user guide anyway another quartion do i have to upgrade to use a cam or which cam the system accept without upgrading please dont laugh at me lol i am really confused with the names of all sort of cam dragon cam is it ok ? irdeto or via accces? | ||
| | #27 | ||
| Regular Member Join Date: 01-01-2000 Location: Aberdeen, Scotland
My System: Channel Master 1.2m motorised, V Box, Technomate 1500ci. | I expect the Dragon would be OK. I have a DB6800 and I have been using an Matrix Reloaded CAM for some time now. I currently have it running on Matrix Rev firmware. You can get MRs at exceptionally good prices at Spectrum at the moment, but whether that's the best option - well it depends on how much you have to spend for a start. Had you anything in mind viewing wise? | ||
![]() Satellites.co.uk F1 SupaLiga 2009 - CHAMPION UniSat Champions League 2008/2009 - CHAMPION | |||
| | #28 | ||
My System: BEC 6600 CI | norm i recieved your user guide you sent thanks a lot now i am looking to buy a cam which i decided to buy a MR somebody recommend dragon but i have no idea if it works on BEC ROLFW maybe you can help please and should i to upgrade my system and how you do it? | ||
| | #29 | ||
| Regular Member Join Date: 28-01-2005 Location: Manchester (53'N 2'W)
My System: Manhattan 5900, Infinity USB, Panasonic skybox & triax zone2, Gemini 90 and other dishes, triax & grundig lnbs | -this was a mistake- | ||
| Last edited by NiCad; 10-03-2005 at 09:53 PM. Reason: Posted in wrong place.... | |||
| | #30 | ||
| Member Join Date: 19-02-2006 Location: texas,usa
My System: bec6600 | I cant seem to get BECLink68 to connect to my BEC6600CI+. Im using a know good straight thru serial cable and my pc comport 1 is also been checked ok on other devices. I even tried com 2, just wont connect. I tried factory defaulting the receiver, but still wont show connect after selecting com1 in the software. Any suggestions, thanks Zener22 | ||
| | #31 | ||
| Member Join Date: 04-09-2006 Location: KOSOVO
My System: Bec DB-6800 CIP SW Version. 2.00 |
I HAVE TESTED BECLink68 ON WINDOWS XP BUT IT DOES NOT WORK. IT ONLY WORK ON WINDOWS 95/98/ME. THATS WHY YOU CANT CONNECT TO THE PC (IF YOUR CABLE IS OK) YOU GET MESSAGE LIKE WRONG PARAMETER OR SOMTHING... BUT THAT IS NOT. | ||
| matrix, reloaded |
Similar Threads | ||||
| Matrix Reloaded Cam - How to update | user909090 | Matrix Reloaded, Revolutions and CAS interface | 54 | 22-08-2006 08:29 AM |
| How to add a new ID in Matrix Reloaded Cam | farrukh | Matrix Reloaded, Revolutions and CAS interface | 7 | 24-10-2005 08:07 AM |
| Matrix ReLoaded .... please help me understand it | war head | Matrix Reloaded, Revolutions and CAS interface | 25 | 03-01-2005 10:03 PM |
| Matrix reloaded or stay as I am ? | redrooster | Matrix Reloaded, Revolutions and CAS interface | 23 | 26-05-2004 08:26 PM |
| Matrix Reloaded CAM & No ZAP Channel | user909090 | Matrix Reloaded, Revolutions and CAS interface | 2 | 06-01-2004 02:50 PM |
