matrix reloadedAll information about the Matrix Reloaded and Revolutions CAMs, plus the CAS interface for programming MMs, MRs and UCAS embedded modules. | |
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | May not be the absolute cheapest price radiotech, but for support and service I would be inclined to point you at Toecutter's Den. That's where I got mine and unlike many other places, it comes fully loaded and ready to go, plus there is always someone here or there to help you through any teething problems. | ||
| If you need help in finding TCs den just look at the Irdeto section for a link. You will have to register first before accessing By the way where in the US is Hell on Earth (or is it an alternative name for the place ?) | ||
| There is a very fine line between "hobby" and "mental illness" | |||
| | #4 | |||
| Regular Member Join Date: 16-05-2003 Location: USA
| Thanks Rowf and Channel hopper. i already registered with the Den. Heh heh, Hell on earth, USA is just for fun. I have not found any place on earth that is resemblant of Hell.
| | #5 | ||
| Regular Member Join Date: 01-01-2000 Location: Aberdeen, Scotland
My System: Channel Master 1.2m motorised, V Box, Technomate 1500ci. | Hi Rolf, have just decided to take the plunge and order an MR from Toecutter's. I see from having a look around Toecutter's that you have a BEC receiver - is that where you use the MR? I also have a BEC, the 6800CIP. | ||
![]() Satellites.co.uk F1 SupaLiga 2009 - CHAMPION UniSat Champions League 2008/2009 - CHAMPION | |||
| | #6 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Yes it is Norm, mine's the 6600ci though, it had problems with CAMs until I updated the software to the latest version. I also used it to update the CAM with my CAS Interface and the new initialisation, so you should be OK. | ||
| | #8 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | I have it here, it was sent to me by Chaintech in the far east, I'll see how big it is and see if I can upload it. Can't upoad the PDF with the instructions, too big, will see if I can split the file. OK, all done, normal warnings though.....use at own risk etc I would also add that this is the European software, it may be different for the states. | ||
| | #9 | ||
My System: Channel Master 1.2m motorised, V Box, Technomate 1500ci. | Thanks for the encouraging response Rolf regarding the MR CAM. Do you know how I would be able to check what the latest version of software is for my BEC 6800? And where I could find it if required? I'm sorry - I seem to have turned this thread around a bit! Norm. | ||
| | #10 | ||
My System: Channel Master 1.2m motorised, V Box, Technomate 1500ci. | A short update - I received my CAM yesterday and it works just fine in the BEC6800. Rolf, that was an absolutely excellent tip you passed on about buying it from Toecutter, thank you very much! | ||
| | #11 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | No problem Norm, hope you get as much enjoyment from it as us other users. ![]() Only problem with this hobby, is that the next purchase is always waiting around the corner. | ||
| | #14 | ||
| Irish Mod Join Date: 30-09-2002 Location: Ireland
| Sorry only if you use Cas-Interface, see below In stock due to many requests ! Cas Interface for Magic, Axas, Universal, Matrix Cams This Product can be used for Programming the cams listed above . We do not advise the use of this product as it can easily damage your cam and the unit is also fragile . No warranty , software or support is issued with this product . We will not cover warranty on Cams purchased from us after using this product . | ||
| Don't mind my spelling | |||
| | #15 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | I think what they are saying is that it is possible to do physical damage to the CAM with the CAS interface and to damage the contacts of the CAS itself, nobody is going to cover the CAM or interface against self inflicted damage. Once you change the software on any of this type of equipment, you in effect void any warrantee, but as far as I know Toecutter's will always help if possible. PS I don't believe that there are any close ties between Astratech and the Toecutter forum, but even if both offered the same service and price, I would always go to Toecutter's, as the money goes straight towards running the forum. | ||
| | #16 | ||
| Yes, I also would choose Toe's over Astratec, and if he does offer better support anyone reading this thread might now lean his way. That is if they are in the market for some new gear. I do drop into the den once in a while and see that he is well respected and trusted. | ||
| | #19 | ||
| Member Join Date: 21-08-2004
| hi im in canada is`any one have program for my BEC6800 FTA or update plese send me to miketriff88@hotmail.com | ||
| | #20 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Try E-mailing Jasonpeng @ chaintech.com.tw Send details of your existing software and receiver model and serial number. | ||
| | #23 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | You may be able to download one from Chaintech as above, if not, send them an E-mail, they are very helpful. | ||
| | #24 | ||
My System: Channel Master 1.2m motorised, V Box, Technomate 1500ci. | I have a DB6600/DB6800 operation manual that I can photocopy at work if you're stuck. You can PM me your address. But be warned - it's not exactly a comprehensive document. | ||
| | #25 | ||
| Member Join Date: 01-03-2005
My System: BEC 6600 CI | thanks rolfw thanks norm dear norm i cant access your e mail please e mail me that my e mail lionheart_558@hotmail.com | ||
| matrix, reloaded |
Similar Threads | ||||
| Matrix Reloaded Cam - How to update | user909090 | Matrix Reloaded, Revolutions and CAS interface | 54 | 22-08-2006 08:29 AM |
| How to add a new ID in Matrix Reloaded Cam | farrukh | Matrix Reloaded, Revolutions and CAS interface | 7 | 24-10-2005 08:07 AM |
| Matrix ReLoaded .... please help me understand it | war head | Matrix Reloaded, Revolutions and CAS interface | 25 | 03-01-2005 10:03 PM |
| Matrix reloaded or stay as I am ? | redrooster | Matrix Reloaded, Revolutions and CAS interface | 23 | 26-05-2004 08:26 PM |
| Matrix Reloaded CAM & No ZAP Channel | user909090 | Matrix Reloaded, Revolutions and CAS interface | 2 | 06-01-2004 02:50 PM |
