Receivers which work with the MR and those which don't
All information about the Matrix Reloaded and Revolutions CAMs, plus the CAS interface for programming MMs, MRs and UCAS embedded modules.
Old 17-04-2004   #26
Moschino's Avatar
Talking
Working wonders with my technomate 5500 dapci upgraded to v1.08 still working wonders.
Moschino is offline   Reply With Quote
Old 18-04-2004   #27
Donrandy's Avatar
works fine with Eurosky DSR2002 ci [zapmaster ci] software ver 121503. MR 1.080
Donrandy is offline   Reply With Quote
Old 28-04-2004   #28
mole4319's Avatar
Echostar AD3000ip (updated with V1100)
Constant pixellation and some freezing. With The MR inserted together with a Conax CAM/**3 card there is break-up, take the MR out and everything's fine.
So not working too good on my receiver, but the same CAM in Humax 5300 and Technomate 5500 is fine - so it's the Echostar at fault
pc::
mole4319 is offline   Reply With Quote
Old 03-05-2004   #29
works fine with an ICE MM1100
just newly out receiver at a fair price
johnbruce is offline   Reply With Quote
Old 03-05-2004   #30
Pixellation and eventual freezing on a Manhattan APCI 2500 with MR 1.08 and a Blue T. Card with 1.06 OS. A change of cam to Conax solved the problem for 1W so I assume it is a box/cam problem. Will try an earlier version of MR when I get the time.
AllyFraser is offline   Reply With Quote
Old 03-05-2004   #31
Perfect work with Technisat cam 1....
musti74 is offline   Reply With Quote
Old 16-05-2004   #32
Nokia 9800S - software version to use!
Nokia 9800S - Can anyone tell me which software version to use? I have tried MR 1.055 and MR 1.080 without success! The Cam is not recognized by the receiver
Stromboli is offline   Reply With Quote
Old 18-05-2004   #33
do you know if the emtech Fas-200n will work thanks
atlas150 is offline   Reply With Quote
Old 18-05-2004   #34
Unhappy Nokia 9800s
Dear Rolf,
Do you know which software versions works with Nokia 9800S? I have tried MR 1.055 and 1.080! I am stuck, so your advise is appreciated!
Originally Posted by rolfw
Started this thread so that any member can add their experiences.
Tested by me.
BEC 6600ci Works well, also for reflashing
Digiquest 2000ci Works well, also for reflashing
Hyundai HSS800ci Works well, but havent tried with uninitialised MR.
What I've heard.
Humax 5400 Works with the MR, has problems with initialisation after flash upgrade, but can be made to work
Hyundai HSS1000ci Doesn't work well at all with the patched embedded CAM.
Comag (Lidl cheapie) Works, not sure about flashing.
Echostar Whole range appears to work
Samsung 9500 Worksss
Nokia 9800 Works with some sofware versions
Old 21-05-2004   #35
DCG
DCG's Avatar
My System: dm 7000 and 7020 cas 3 blue ice cam sv card redlight card seca cam reality cam opos 1.03 and 1.05 lynksys router gold cards fun cards 1.1 mtr trix dish 0.3 sharp lnb hh100 moter xplus tv and inxtc card sex view + ceribro card
“The offyce of a knyght is to mayntene and defende the idyot gyde"
works great with echo 3600via silver m8
DCG is offline   Reply With Quote
Old 13-06-2004   #36
wave rider :I have an extreme box and having all sort of problems even get black sceen on free to air channels.
rigidigi is offline   Reply With Quote
Old 13-06-2004   #37
DEC3000 also works with this cam .
dante1354 is offline   Reply With Quote
Old 14-06-2004   #38
Technomate TM-5500CIp - works with MR1.05 MR1.08 MR 1.081 but had to program CAM using a laptop because the serial cable dreamloader module were "erroring" badly trying to use STB (Dreamloader display lights went out constantly & "invalid card inserted message"). Got it nearly working once. Rolfw thinks possibly there is not enough power to the CAM from the Technomate for upgrading.
petchletch is offline   Reply With Quote
Old 15-06-2004   #39
kaon 510
hi fellas
my kaon 510 works like a dream with mr.1070
i am still on hispasat n***avision.
rgds to all davidwood1
davidwood1 is offline   Reply With Quote
Old 15-06-2004   #40
my xtreme 6400 mr. 1o70 jams all channels even free to air
tried different cam slots lower and intialized on FTA. then change channels and all goes black screen NO VIDEO error.
Any ideas appreciated.
Old 26-06-2004   #41
Location: wessex area, technomate, 80cm, matrix reloaded
Technomate TM-5500 works fine
Hi Guys, digital novice returning after some years away from this scene (do I really have to throw away my old D2-MAC?)... anyway, I bought a Technomate TM-5500 primarily because I could keep my old disk and motor and it has worked fine from day 1 with MR 1.080 I just need to work out how to program my own keys next.
Cheers all
Meridian
meridian is offline   Reply With Quote
Old 26-06-2004   #42
I've seen this one before
Originally Posted by tirosh
My brother's Technomate TM5500 working fine with MR1.03.
Update - last night he had a problem with his setup. The CAM is making the receiver turn itself off and on. In fact at one point it lost all it's positions and these had to be put in again. The CAM is also refusing to initialise. So there may well be problems with this combination.
Hello mate... I did see a post on another site about this...I also have a TM5500. The solution was to put the CAM into a PCMCIA slot in a laptop and boot it. Apparently resets everything to its initial state and you can then install it again into the receiver.
Meridian
Old 01-07-2004   #43
"Technomate 5500CIP" needed MR1.081 with a Funcard inserted at all times. Bought a "Technomate 5500CI Super" and the CAM works without a card. Both STB's had the same, latest software revision - Weird. Also had problems connecting to RS232 port to try and reload the software on the CIP.
Old 05-07-2004   #44
HI guys
Comag (Lidl special) 2 Ci initialises MR1.081 quickly but channels not decoded
the same MR CAM work perfectly in my Echostar 2110 Ci Viaccess
Any thoughts on this perplexing problem
Do i need to downgrade MR version or is there a patch or fix to Rectify
Need to know cos my mate needs to get porned up with Multivision etc
Any Helpful Comments Much Appreciated
All the best
war head is offline   Reply With Quote
Old 11-07-2004   #45
brad5150's Avatar
definite thumbs down to humax ci 5100,invalid cam message after reprogg of cam,now im searching for another receiver,anyone know about the manhattan starlight mx
brad5150 is offline   Reply With Quote
Old 12-07-2004   #46
Echostar ad-3000ip
I have a matrix reloaded 1.071 and tit card 1.06. Works fine for Conax 1West. If I program it for S*Y Italia 13E no picture.
Took Cam and card to friends echostar d-2500 ip - works fine for S*Y Italia.
Anyone else with Echostar ad-3000ip with same problem with S*Y Italia?
DelP is offline   Reply With Quote
Old 18-07-2004   #47
potatoelf's Avatar
MR 1.07 works with Humax 5400Z only when like in my case updated to MR 1.10 and afterwards must be initiated in some other receiver (e.g. Nokia). After that it works fine.
Potatoelf
potatoelf is offline   Reply With Quote
Old 18-07-2004   #48
Grundig Selio DTR5210 S CI itself is buggy (it generates IR commands by itself!) but as far as I can tell MR is working fine. Grundig firmware is "106" and I've tried at least 1.07, 1.081 and 1.10 of the MR.
SkyPerfecTV is offline   Reply With Quote
Old 23-07-2004   #49
Humax Ci-5100 works fine with MR 1.081
My Humax CI-5100 and Humax 8100 PVR works fine with the MR 1.081.
hoschi08152 is offline   Reply With Quote
Old 31-07-2004   #50
[QUOTE=>COR<]Hello Rolf,
Echostar AD 3000 IP working fine, programming with CAS fine too.
Cheers,
Cor.
Hi Cor
I also have an Echastar AD3000 but am a complete novice. Please can you give me some advice on which programmer and cards I need. And how to obtain keys and program them.
Peter (Nottingham UK)
squiddo is offline   Reply With Quote
receivers, work
