Receivers which work with the MR and those which don't
All information about the Matrix Reloaded and Revolutions CAMs, plus the CAS interface for programming MMs, MRs and UCAS embedded modules.
Old 10-08-2004   #51
don't work with nokia 9902s +hd
nobann is offline   Reply With Quote
Old 12-08-2004   #52
Question Pb with echostar 2220 CI
facing some problems with MR 1.100 + Echostar 2220 CI (with internal emu) ie picture freezing some explanation? conflicting soft? what about S*ca keys and nagra boxkey? thanks
moas98 is offline   Reply With Quote
Old 18-08-2004   #53
No1 Satellite Thick Idiot
My System: Sony KLV26HG2 LCD TV, Humax HD-CI 2000 on a Fixed Sky/Astra/Hotbird. Cerebro Card. Infinity USB Phonix. Dragon Cam v4.1 w/Firecrypt & Loader Card.
Does it work with Nokia 9800 software ma2.0
Dear rolfw .
Does the Matrix Reloaded cam wotk with the Nokia 9800s with the latest software version MA2.0
MA2.0 is the latest updated software over the air for the nokia9800s.
What channels will can be opened and which card type shall it need?
Cheers rolfw
Shahid is offline   Reply With Quote
Old 18-08-2004   #54
rolfw's Avatar
Real name: Rolf
Not sure Shahid, there seems to be a question mark on that one, don't know anyone who's running that combination.
Rolf
Old 20-08-2004   #55
jcab's Avatar
That works fine with Neotion B 3000.
jcab is offline   Reply With Quote
Old 21-08-2004   #56
I have just got a manhattan starlight mx .but i dont know how to start the matrix,anyone any ideas?
caretaker is offline   Reply With Quote
Old 28-08-2004   #57
Talking Nokia 9902 Modification to work with MR (MRev)
I've created a modification thats done to the cam to Fix forever the Nokia problems among other receivers and issues!
Search for my postings
Lunchy is offline   Reply With Quote
Old 31-08-2004   #58
ajmac42's Avatar
Talking Technomate Yeahhhhhhhhhhhhh
Hiya Guys
Technomate TM5500 CI Super with Matrix Rev V1.03 workin like a dream, no prob's at all. Sometimes re-iniatialises but seems to cause no hassle so i reckon we have a success. Technomate take a BOW
Have Fun.
ajmac42 is offline   Reply With Quote
Old 31-08-2004   #59
gandalfthegrey's Avatar
My System: AZbox HD Gibertini 85cm dish 4 way Diseqc switch........ linksys access point connected to Azbox..
Rowlf:
In your thread you say the comag (cheapielidl job) will work with the MR (assume you mean the Matrix Rev CAM) if this is true, in basic noobie terms how does it work..please reply
gandalfthegrey is offline   Reply With Quote
Old 31-08-2004   #60
Has anybody had experience with the Palcom 2100CI and MR,
Thanks,
Londubh
Londubh is offline   Reply With Quote
Old 02-09-2004   #61
kisser's Avatar
MR 1.1 works fine with Manhattan Plaza 3300CI
kisser is offline   Reply With Quote
Old 02-09-2004   #62
fario's Avatar
Cool Mr
Hi, to all
What is MR
Thank you
F
fario is offline   Reply With Quote
Old 02-09-2004   #63
rolfw's Avatar
Real name: Rolf
Matrix reloaded CAM, as per section heading fario.
Rolf
Old 11-09-2004   #64
weeks77's Avatar
HELP about MR and TOPFIELD TF5000PVR
have just bought a TF5000PVR and I have a MR CAM.
I have programmed the CAM with a CAS2 and the MR 1.1 version.
I haver also tried with other versions.
My TF5000 has the may 29 2004 firmware version.
Wen I put the CAM in the TF5000, it is recognised, I can see it in the menu, enter the cam and see all the keys that are correct.
When I select a not FTA channel., nothing happens as if there were no CAM.
Does someone know what happens ?? Is there a patch I have to install ?
weeks77 is offline   Reply With Quote
Old 11-09-2004   #65
5100 problems
Originally Posted by cowboy
Ive spent the past 10 days trying all the advice from any forum I could think of and I still can't stop my Humax CI 5100 from displaying 'Invalid CI Module'
A lot of the advice said initialise the cam in another receiver....well that would be fine if I had another receiver.....If I had another receiver I wouldn't need the Humax!!!
I have now decided to sell the Humax and buy a Technomate, hopefully life will be a bit easier with that receiver!!
So as far as RolfW's survey goes I would definately give the Humax CI 5100 a thumbs down.....I tried and failed!!!!
Cheers Guys
Cowboy
The 5100 in my experience has been a wast of time,i've had one for four years and it is still in the box,as for cams it would only ever recognise a viaccess cam which i traded in for a magic cam at the time, even then it never decoded anything.i upgraded the reciver software and added the allcam patch.
a true waste of time.
satellite eye is offline   Reply With Quote
Old 16-10-2004   #66
just had mr patched into a nextwave 2500 embedded ucas. working great. rob43
rob43 is offline   Reply With Quote
Old 18-10-2004   #67
stevo's Avatar
My System: humax 5300 VACI humax f1 vaci *sat 6000 fta patched pixx adt1200 fta infinity usb phoenix cardmaster v 1.0 cas 2 interface matrix revelotion matrix reloaded mii card fun cards gold cards 1 metre dish technomate h to h motor
works fine on my humax5300+technomate 5500ci plus
stevo is offline   Reply With Quote
Old 24-10-2004   #68
Smile thank u
that is cool , thank you
ealzw is offline   Reply With Quote
Old 24-10-2004   #69
MR Cam compatible receiver
Hi Dear Mates
Good Evening
I tested following STBs with all versions of MR Cam :
1- Humax 5400/5300/5100
2- Technosat 6600plus (Embeded Conax 2 CIs)
3- Starsat (embeded conax)
4- Databox(embeded UCAS)
Best regards/wishes
Mumtaz Rizvi
mumtazrizvi is offline   Reply With Quote
Old 04-11-2004   #70
flash ADT PIXX 1200
Originally Posted by silvernet
ADT PIXX 3500, working OK, but not with 1.18 software, works fine with 1.17 (well mine does ) software, not sure about flashing cam with it though.
Hope this helps
Silvernet
Is it possible de flash a PIXX 1200. What is the software and how I have to do for that ?
Thanks!!
mimide89 is offline   Reply With Quote
Old 05-11-2004   #71
Ikusi Sri 102 Works Very Good...
Best Regards..
John..
jpps is offline   Reply With Quote
Old 11-11-2004   #72
My System: Strong SRT 4335 Evolution using 80cm dish have got motor but just have it locked on 16e for DigitAlb for the football
Wink
also a Strong 4355 works with a Matrix Reloaded MR 1.081 (no card)
I get Multivision and TPS all OK so got my footy, the odd film and come
11pm loads of porn what more can I ask for!
bigkenny is offline   Reply With Quote
Old 13-11-2004   #73
MasoodButt's Avatar
MR 1.130 is working very well with Opentel ODS 2000 CI s/w ver.6.70 and Super-6000 CI PLUS
MasoodButt is offline   Reply With Quote
Old 22-11-2004   #74
El Marcus's Avatar
Smile Nokia 210S
Work fine <img>
El Marcus is offline   Reply With Quote
Old 23-11-2004   #75
My System: TM 6900 Combo Motorised 80cm + dual lnb in UK TM 1500 Motorised 80cm in Cyprus Pinnacle Showcenter 200 MR Reloaded Diablo 2.3 Hotbird 13E Astra 1M widebeam Astra 1H 1W T2 Beam 7E,5E,10E,16E,26E,33E,42E 4W,7W,8W,12.5W,15W All Ok with 80
Hi All
I have Humax 5100ci + Mr no card
So far i have run mr 1.12
Recently upgrade mr to mrv 2.13 using Laptop
Works great
I do have problem with the cam initialising but find if i put the cam back into the laptop
and run the loader program but dont update the cam initialises when i put it back into the humax
Very Strange
Also the laptop has problems recognising the cam but when i rollback the drivers and then update its ok
regards
Uk2cyp is offline   Reply With Quote
receivers, work
