Receivers which work with the MR and those which don't
All information about the Matrix Reloaded and Revolutions CAMs, plus the CAS interface for programming MMs, MRs and UCAS embedded modules.
Old 28-08-2006   #126
My System: 1m dish ehcostar 2110
Originally Posted by rolfw View Post
Started this thread so that any member can add their experiences.
Tested by me.
BEC 6600ci Works well, also for reflashing
Digiquest 2000ci Works well, also for reflashing
Hyundai HSS800ci Works well, but havent tried with uninitialised MR.
What I've heard.
Humax 5400 Works with the MR, has problems with initialisation after flash upgrade, but can be made to work
Hyundai HSS1000ci Doesn't work well at all with the patched embedded CAM.
Comag (Lidl cheapie) Works, not sure about flashing.
Echostar Whole range appears to work
Samsung 9500 Works
Nokia 9800 Works with some sofware versions
EHCOSTAR DSB.2110. works, Matrix-Reloaded
demojohn is offline   Reply With Quote
Old 29-08-2006   #127
Originally Posted by mosafu View Post
works fine with the older echostar 2110 2ci via with software(700).
I have the same setup and cas3 Matrix-Reloaded, but clears for 60Sec then scrambles again then 10Mins later it clears again do you have the same problem,can you help. D.J.
Old 27-03-2008   #128
My System: teknsue
mersi .b....
azizi is offline   Reply With Quote
Old 10-10-2008   #129
My System: old sky box and dish with origional card
i have a amstrad drx550 and a matrix rev cam does this work having probs getting it running got a cas 3 to help me along the way
nomic is offline   Reply With Quote
Old 10-10-2008   #130
aileen's Avatar
My System: Technomate 6800 HD. Motorised 88 cm dish Installed by Robbo Mac computers
Could someone please tell me what 'MR' means.
aileen is offline   Reply With Quote
Old 10-10-2008   #131
matrix revoloutions or reloaded
The Following User Says Thank You to nomic For This Useful Post:
aileen (10-10-2008)
Old 10-10-2008   #132
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
No CAM slot, so no workee.
Llew is offline   Reply With Quote
Old 11-10-2008   #133
it has a cam slot in the back but cant seem to get any extra channels i power up box with cam in screen goes black for about 7 seconds then it goes to fuzzy screen i power on the box all the same channels ????
Old 11-10-2008   #134
Llew's Avatar
That's a PCMCIA slot, not necessarily to be used for a CAM module. Not for domestic use, don't stick anything in there!
receivers, work
