Receivers which work with the MR and those which don't
All information about the Matrix Reloaded and Revolutions CAMs, plus the CAS interface for programming MMs, MRs and UCAS embedded modules.
Old 11-10-2003   #1
rolfw's Avatar
Real name: Rolf
Receivers that work with the MR and those which don't
Started this thread so that any member can add their experiences.
Tested by me.
BEC 6600ci Works well, also for reflashing
Digiquest 2000ci Works well, also for reflashing
Hyundai HSS800ci Works well, but havent tried with uninitialised MR.
What I've heard.
Humax 5400 Works with the MR, has problems with initialisation after flash upgrade, but can be made to work
Hyundai HSS1000ci Doesn't work well at all with the patched embedded CAM.
Comag (Lidl cheapie) Works, not sure about flashing.
Echostar Whole range appears to work
Samsung 9500 Works
Nokia 9800 Works with some sofware versions
Rolf
Old 11-10-2003   #2
-- BIG GUN SPECIALIST --
>COR<'s Avatar
Hello Rolf,
Echostar AD 3000 IP working fine, programming with CAS fine too.
Cheers,
Cor.
>COR< is offline   Reply With Quote
Old 13-10-2003   #3
Topfield 3000 ci pro working fine too
wisebird is offline   Reply With Quote
Old 14-10-2003   #4
>COR<'s Avatar
The latest Echostar 7000 + hd works too
Cheers,
Cor.
The Following User Says Thank You to >COR< For This Useful Post:
azizi (27-03-2008)
Old 14-10-2003   #5
tirosh's Avatar
My System: Echostar AD3600IPVA Channel Master 1.2M VxMulti, MM1.04
My brother's Technomate TM5500 working fine with MR1.03.
Update - last night he had a problem with his setup. The CAM is making the receiver turn itself off and on. In fact at one point it lost all it's positions and these had to be put in again. The CAM is also refusing to initialise. So there may well be problems with this combination.
tirosh is offline   Reply With Quote
Old 15-10-2003   #6
Kaon 570 and ID E20, both work with 1.03. ( tested in Spain ) Not sure about flashing them .. The Kaon 570 performs better than the ID E 20, much faster.
Hope this helps
silvernet is offline   Reply With Quote
Old 24-10-2003   #7
ADT PIXX 3500, working OK, but not with 1.18 software, works fine with 1.17 (well mine does ) software, not sure about flashing cam with it though.
Hope this helps
Silvernet
Old 24-10-2003   #8
works fine on my OLD series HUMAX F1VACI..
gazz is offline   Reply With Quote
Old 25-10-2003   #9
Works fine with Echostar DSB 808 Vi, no problems upgrading from 1.03 to 1.04 with a Fun5
Seansean is offline   Reply With Quote
Old 17-11-2003   #10
mosafu
Posts: n/a
works fine with the older echostar 2110 2ci via with software(700).
Old 24-11-2003   #11
BEC-6600ci works well with nagravision. no problem upgrading from 1.03 to 1.05 with funcard 5, or laptop PCMCIA. However, it does not autoupdate (irderto 1)with sub. information.
coship cdvb5300B works well with nagravision. no problem upgrading from 1.03 to 1.05 with funcard 5.
radiotech is offline   Reply With Quote
Old 06-01-2004   #12
user909090's Avatar
works also fine with Astra 9500
user909090 is offline   Reply With Quote
Old 07-01-2004   #13
Can't get it to work with my Humax 5400. I've tried the original HIC software, and all the versions from +CAM ToH2.0 to 3.2..
The picture is digitized, and comes and goes.. What seems to be the problem? I've tried re-inserting the MR CAM several times as some suggested, same result..
magomag is offline   Reply With Quote
Old 12-01-2004   #14
Update...Pixx 3500 with 1.17 and / or 1.18 now OK with Matrix.
Flashes upgrades with 2 x Funcard 6's OK
Old 23-01-2004   #15
cowboy
Posts: n/a
Humax CI 5100 dosent work
Ive spent the past 10 days trying all the advice from any forum I could think of and I still can't stop my Humax CI 5100 from displaying 'Invalid CI Module'
A lot of the advice said initialise the cam in another receiver....well that would be fine if I had another receiver.....If I had another receiver I wouldn't need the Humax!!!
I have now decided to sell the Humax and buy a Technomate, hopefully life will be a bit easier with that receiver!!
So as far as RolfW's survey goes I would definately give the Humax CI 5100 a thumbs down.....I tried and failed!!!!
Cheers Guys
Cowboy
Old 04-02-2004   #16
cowboy
Posts: n/a
Technomate TM 5500 CI
Hi fellow sat people
Well I changed my Humax for a Technomate TM 5500 CI and it works like a dream, I don't know about reprogramming the cam yet ... but thats in the future..
Definitely a thumbs up for the Technomate
Cowboy
Old 05-02-2004   #17
Manhattan 3300 Works OK but sometimes gets in cycle if you fiddle too much
with the channels. Needs reboot or in&out the CAM
simel is offline   Reply With Quote
Old 23-02-2004   #18
works fine on my NOKIA 9600s
jose guerra is offline   Reply With Quote
Old 24-02-2004   #19
@rolfw
check this link and you will find all Receivers that work with the MR and those which don't
http://www.cam-modul.info/matrixrelc...n/seite_41.htm
msawad is offline   Reply With Quote
Old 24-02-2004   #20
rolfw's Avatar
Real name: Rolf
Thanks Msawad, not absolute, but a good list.
Rolf
Old 26-02-2004   #21
Cool
works well with my gbsat 2ci-o
pieman is offline   Reply With Quote
Old 26-02-2004   #22
Salty Tech Monster Mod
waverider's Avatar
My System: TM-5400 CI+USB Super. Cryptik Digital H-H Mount. Diablo 2.3 Light. Cas 3+
Well I have to say aye for the Xtreme too....only thing is the MR clears much slower than the embedded cam of the receiver
waverider is offline   Reply With Quote
Old 03-04-2004   #23
Single
jagost02's Avatar
My System: Yamaha YZF-R1
SAMSUNG-702E Working Fine. Menus and all...
Regards,
jagost02 is offline   Reply With Quote
Old 06-04-2004   #24
MR and compatible receivers
Works fine with opentel 3000ci (open-tech)
robuto is offline   Reply With Quote
Old 06-04-2004   #25
OK with Topfield4000 pvr
geemac is offline   Reply With Quote
receivers, work
