MR cam on xtreme | |
| Regular Member Join Date: 14-01-2004
Hi, I just received a MR cam with ucas 3.0 When I insert it in my xtreme it does not get recognized, the menu just reads CI 1 not installed. Is there anything I am missing? XTREME HORNET info 03.02.05 CECC S/W v12.05.04 h/w v12.03.A5 Loader: v. 06.01.06 C.A. - 2.1.9 Thanks Last edited by satello; 15-01-2004 at 08:23 PM Reason: adding details | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Sounds like you are missing the software on the CAM satello, did the company you bought it from say that it would arrive loaded?
__________________ | |||
| | #3 | |||
| | #4 | |||
| Salty Tech Monster Mod Join Date: 17-11-2003 Location: South East England
My System: TM-5400 CI+USB Super. Cryptik Digital H-H Mount. Diablo 2.3 Light. Cas 3+ |
| | #5 | |||
I went back to the shop where I bought the xtreme and tried one of theirs MR and that does not work either, I think the problem is on my receiver but could not do anything because the house tech is not in until friday. As far as you know how could that happen? none of the slots work? Firmware problems? And another question that nobody has been able to answer anywhere else. The receiver has a @sky embedded, which I upgraded to Joker with firmware from la cafettera. Do you guys know if I can upload Joker firmware on it, i.e. 0.70 or similar? I really need to get naaaaaagra to work and that would be a big step forward. Thanks for your time Last edited by satello; 21-01-2004 at 02:17 AM Reason: update | |||
| | #6 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | For the laptop to recognise the cam, you need the correct drivers installed, there is a file by Tutut on Toecutter's Den which talks you through the installation, it's in the Matrix reloaded section. Did they try the MR in one of their other receivers?
| | #7 | ||
| I ended up giving it back to the dealer because they could not sort it out. Than I tried a TM 8000 PVR, absolutely ridicolous machine, it just does not work. What Am I going to do next? I thought about a "classical" humax 5400z but the dealer is suggesting a FortecStar FSCI- 5200 PVR What would you guys do? In the end of the day I was quite happy with the xtreme and I found it quite user friendly and apart from the ci slots, everything worked fine. By the way I managed to upgrade my MR to 1055 in the TM 8000 (the only thing it has done right yesterday...) | ||
| | #8 | |||
| | #9 | ||
| Irish Mod Join Date: 30-09-2002 Location: Ireland
| Are we all mad ? to have a hobby like this....We spend loads of cash, turn our hair grey, and spend all our time typing on our PCs, just so we can look at some TV.
__________________ Don't mind my spelling | ||
| | #10 | |||
| | #12 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | No to NoZap, a couple of the Dutch channels may be OK.
| | #13 | |||
| | #14 | |||
| | #16 | |||
| | #17 | ||
| Member Join Date: 31-07-2004
Hi Everybody I recently bought a hornet sat receiver. I also bought a MR card and a friend of mine updated it with all latest keys. After the keys changed I changed them via the remore. However, the receiver does not accept the new keys and for all free channels it gets me a/v and for encrypted nothing. Does the MR work with hornet? What can I do? Thanks | ||
| | #18 | ||
My System: TM-5400 CI+USB Super. Cryptik Digital H-H Mount. Diablo 2.3 Light. Cas 3+ | Well m8 I have an Xtreme PVR and to be Honest the Fun 6 card with the right file works well!.......The Mr seems to clear a lot slower! | ||
| | #19 | |||
| Member Join Date: 01-01-2004
| Hi m8, waverider where are you getting the latest firmware for your xtreme as the site is down as usual, any ideas regards andy
| | #20 | |||
...been a while since we last had a chat...hows life treating you m8 and is Dad ok?As for for the latest firmware.....I have not used any since my last upload and now that the footy season has just started spose I shall start hunting around for files etc for channels my top box can't clear m8. | |||
| | #21 | ||
| Member Join Date: 29-04-2006 Location: London
My System: 2.4m Precision Prime Focus Dish. Dream 7020, V-Box II Asus P5K E6570 (twin 2.66meg) CPU 2gig ram Technisat Skystar2HD DVBViewer, CoreAVC, WinDVD9, PowerDVD8 Nebula DTT, 3.7.11 |
Well chaps I have an Extreme Hornet and to be honest don't have much of a clue what to do with it... In the good olde analogue days it was easy, point and shoot! now it seems i have to be cammed up! Any of you experts care to tell me what i should cam up with and how? All the posts seem to be rather old for this reciever! I have it attached to my Pc and have managed to make contact but would like to-1) Update with latest channel lists 2) Get best cam and card to max my channelage 3) Tweek the clock in it to run a bit faster, its always loosing time. 4) Update to latest firmware 5) Have modded it to allow it to be a PVR version but havent upped the power supply yet so it can take a hard drive, what firmware should i use then. Any help much appreciated Stu | ||
| | #22 | ||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
Welcome to the forum stuboy First post and you don't really ask for much there from a self help forum. Unless you decide what it is you want to watch nobody can begin to advise you there is very little open these days and all the rest are subscription. What satellites can you receive, are you motorised?
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | ||
| | #23 | |||
A few years ago we were spoilt for choice and had a great variety of pretty much everything ![]() You mention about modifying your stb to a PVR! What advise or website did you get the info on? As there's been in the past on the old Xtreme site quite a few blown boxes posted on there! | |||
| | #24 | ||
Ah more info yes ok, I can see from 63 East to 48 West with a 2.2 prime focus.I'd like to watch everything for free just like in the 90's please , I suspect i may be asking a bit much nowadays?! I originally installed system so i could watch outgoing feeds of motor racing Nascar, Champ car, Le Mans etc, now just interested in crusing the sky and seeing whats there, so far it seems every other channel has some soft core phone me bint adorning the screen! Although having RTL is useful when ITV go to adverts on GP days ![]() So just want a setup that can deliver the most bang per buck, with this reciever. Cheers Stuart | ||
| | #25 | ||
On the mod front yes I've turned it into a PVR hardware wise but i know the PSU wont take a Hard disk without some beefing up, and i still havent blown the PVR version firmware into the rom so it is still a standard box as far as it is concerned, so many jobs so little time! B interested to know what you can get | ||
