Matrix Reloaded Cam - How to update
All information about the Matrix Reloaded and Revolutions CAMs, plus the CAS interface for programming MMs, MRs and UCAS embedded modules.
Old 21-01-2004   #1
user909090's Avatar
Cool Matrix Reloaded Cam - How to update
Hi Everybody,,,
I do have a matrix reloaded cam & seem to work properly with my Patched Astra 9500 receiver.
In the future, and upon need, I would like to make the matrix cam updates by myself. I do have a compaq Armada E500 Laptop, with 2 pcmcia slots.
I dowloaded the UCAS loader ver 1.2.1 from the matrixcam.com website. I already installed it on my laptop.
May I ask any professional here to
(1) tell me in simple steps 1,2,3 .. what to do next so that I do the right thing from the first time & update my cam properly whenever needed.
(2) Generally speaking what are the does & donts for a matrix cam update.
(3) what can spoil the matrix cam
Thank you in advance.
user909090 is offline   Reply With Quote
Old 06-02-2004   #2
Single
jagost02's Avatar
My System: Yamaha YZF-R1
User909090,
Try the following link:
http://www.matrixcam.com/laptop.htm
Donīt remove the CAM while programming (Duh) :-)
If you do screw things up just start all over again...
Reguards,
jagost02 is offline   Reply With Quote
Old 08-02-2004   #3
user909090's Avatar
Tried it .. but ..
Thanks for responding Jagost ..
I read this before .. but I need some directions in the software versions to be used .. any does & don't in this specific point?
Originally Posted by jagost02
User909090,
Reguards,
Old 08-02-2004   #4
Single
jagost02's Avatar
The loader software I use is UCAS Downloader tool Ver. 1.2.1 and MR 1.055 as per the links. Thats all...
Reguards,
Old 21-02-2004   #5
Best to get latest UCAS loader version 1.3 from http://www.westlandelectronics.co.uk...interface.html
I can't get my Windows XP laptop to recognise the MR CAM as a new DVB hardware.
Has anyone managed to get it to work with PCMCIA slot on XP?
elega is offline   Reply With Quote
Old 21-02-2004   #6
rolfw's Avatar
Real name: Rolf
This post is by Halkar on Toecutter's
Don't uninstall the drivers as XP will put the same drivers back again.
Here what you can try:
1. Right click and choose update driver, wizard starts,
2. Chose Install from specific location (advanced install, second choice)
3. Don't search I will chose the driver to install
4. Click have disk and point where you extract the MR pcmcia files XP folder. Choose the inf file and click ok
5. Now you will see standard card bus controller click on it and click next, XP will complain, click continue anyway and it will install the drivers.
6. Insert your MR card and XP will detect.
I just tried all these above and worked for Dell T.I 1410
Rolf
Old 22-02-2004   #7
Thanks rolfw for advise on XP configuration, I have followed the manual install process described, but it is the inf file that has no infornation specific to XP, hence fails to install. May be I have the wrong/old inf file, will look around abit more and thank you once again.
Old 22-02-2004   #8
rolfw's Avatar
Real name: Rolf
Try this one elega.
Rolf
Old 22-02-2004   #9
Salty Tech Monster Mod
waverider's Avatar
My System: TM-5400 CI+USB Super. Cryptik Digital H-H Mount. Diablo 2.3 Light. Cas 3+
I've got a shortcut for win 98 if anyone comes up with problems Rolfw
waverider is offline   Reply With Quote
Old 08-03-2004   #10
Any luck with that Armada E500?
I've got one too and not managing to get the pcmcia drivers to work...
Allready had to manually repair the XP to get it loading again...
I've tried both the driver packages i found (mr_by_laptop.zip and mr_by_pcmcia.zip) - no luck with those.
Do I need to get a pcmcia adapter for my desktop pc?
How do i know which one to get?
astro76 is offline   Reply With Quote
Old 09-03-2004   #11
user909090's Avatar
Astro76, I actually got an advice not to use my Armada for MR upgrade.
And it ended up by going to a professional to upgrade it for me using cas interface against a fee. That was with less headache for me simply.
I am currently having windows 2000 prof. as an operating system. what's yours?
Old 09-03-2004   #12
I'm using XP Pro.
Unfortunately there's no "professionals" in my area so updating the MR is up to my skills.
I've been searching a Toshiba lappie for future use as i need it for other purposes too.
Do you know what Toshiba lappies are compatible with MR?
Old 09-03-2004   #13
rolfw's Avatar
Real name: Rolf
Not sure about the Tosh laptops, but the Compaq Presario series running win 98 is very CAM friendly, works well with the old Irdeto CAMs as well.
Rolf
Old 09-03-2004   #14
Can say any specific model of presario?
This would help a lot to find one as cheap as possible.
Old 09-03-2004   #15
rolfw's Avatar
Real name: Rolf
Mine is a CM2060 560Mhz.
Rolf
Old 10-03-2004   #16
Hard to find those in Finland...
Seems that the one's available are too expensive.
I'm not ready to spend more than 100 euros (about 60 gbp).
Otherwise I'll get the CAS Interface 2. That's more like 80 euros (50 gbp).
Old 17-03-2004   #17
neo00000000000000001's Avatar
Question first post mr files?
can and body tell me were i can find the latest mr files ?
neo00000000000000001 is offline   Reply With Quote
Old 18-03-2004   #18
jimbo's Avatar
My System: Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
Latest files at _http://www.matrixcam.com
Jimbo
jimbo is offline   Reply With Quote
Old 18-03-2004   #19
Smile Mr 1.071
thanks i got the mr 1.071 wtwork great looks like a Matrix Reloaded 1.080 (??.03.2004) will be out soon
Old 18-03-2004   #20
rolfw's Avatar
Real name: Rolf
Wouldn't hold your breath on that, looks more like it may have been a ploy to keep the interest going in the MR CAM, would love to be proved wrong though.
Rolf
Old 14-05-2004   #21
I've problems with w98 in my Armada 1560 making it recognise the MR CAM. Any suggestion??
TKS.
robscor70 is offline   Reply With Quote
Old 28-08-2004   #22
Unhappy problem with upgrading matrix cam
hi everybody
i have a magiccam which i flashed into matrixcam 1.081
recently, i found the new version of matrix (2.07) . i upgraded my matrixcam with funcards now i can see both of taquilla and calcio but all channels work just for 1 minute. afterwards, i tried to upgrade it into matrix 2.06 with funcards but it couldn't work so i decided to upgrade it by my laptop with loder_setup 1.3 but winxp couldn't detect my cam, so what can i do ?
Help me, please? i am waiting for you,thanks.
gasper is offline   Reply With Quote
Old 28-08-2004   #23
guiri's Avatar
@gasper - 2.07 is for the matrix revolutions and not the matrix reloaded
you'll need a cas2 interface to go back (can't be done with fun cards or laptop method)
guiri is offline   Reply With Quote
Old 13-09-2004   #24
Unhappy Help
I now this question might have been asked many times but i still cant solve my problem cause im a complete newbie.
WHERE do i find the drivers for MR to work with my laptops PCMCIA slot???
globus2 is offline   Reply With Quote
Old 13-10-2004   #25
arjanv's Avatar
IBM thinkpad notebook
Mine is an IBM thinkpad 600E. It recognizes the pcmcia cardbus driver but not the Matrix Reloaded. Does anyone know how to solve this problem
arjanv is offline   Reply With Quote
cam, matrix, reloaded, update
Similar Threads
matrix reloaded cam martyn Matrix Reloaded, Revolutions and CAS interface 20 28-08-2006 01:37 AM
Matrix Reloaded How To by AHAC rolfw Matrix Reloaded, Revolutions and CAS interface 52 27-12-2005 12:02 PM
Matrix Reloaded CAM & The Fun Card user909090 Matrix Reloaded, Revolutions and CAS interface 2 01-07-2005 02:51 PM
Matrix Reloaded CAM Pandora Matrix Reloaded, Revolutions and CAS interface 11 04-02-2004 07:41 PM
Matrix Reloaded CAM & No ZAP Channel user909090 Matrix Reloaded, Revolutions and CAS interface 2 06-01-2004 02:50 PM
