MR 1.04 & NOVA card (IRD2) & Manhattan 3300
All information about the Matrix Reloaded and Revolutions CAMs, plus the CAS interface for programming MMs, MRs and UCAS embedded modules.
Old 25-01-2004   #1
Hi guys,
I just plugged in my new (and activated) NOVA card (irdeto card) but the channels I was supposed to be able to watch are still encrypted...
I'm using a Matrix Reloaded Cam (S/W MR 1.04, H/W 1.5, Loader 1.0).
Should the card work straight away, or I actually have to change any settings on the MR CAM?
As far as I know, NOVA uses IRDETO 2 encryption. My card should be able to support this, correct?
Thanks in advance for your help!
Arkadian is offline   Reply With Quote
Old 26-01-2004   #2
rolfw's Avatar
Real name: Rolf
You may need to leave the card in for a few minutes to update. The MR software version is now out of date, but it should AFAIK, work with the genuine card.
Rolf
Old 26-01-2004   #3
Rolfw,
many thanks for your quick reply!
The card has been in the CAM for at least 3 hrs...
I think I will try to get the MR 1.055 at some point this week...
Old 26-01-2004   #4
rolfw's Avatar
Real name: Rolf
Just had a look in the MR menu, there is a section in the setup section which can turn irdeto EMU on or off. You may need to turn this off.
Rolf
Old 26-01-2004   #5
I tried that; no luck...
I'm not very familiar with the IRDETO encryption, but I think there are two versions, and that NOVA uses IRD 2.
Is there a chance that 1.04 doesn't support IRD 2?
Old 26-01-2004   #6
rolfw's Avatar
Real name: Rolf
It should do, but I'll need to do a bit of fishing to find out. When making any changes to the CAM menus, you will probably need to reset the receiver and possibly even pull the CAM out and replace to force a reinitialisation.
Rolf
Old 26-01-2004   #7
I have just reset the receiver, with all the possible combinations: with / without the CAM, with / without the card; no luck again...
What can I do to check if the CAM is actually working?
The only thing that I can think of right now is that the card has not been activated yet (even though I personally called them to activate the card, and they confirmed that the card is now activated...).
Rolfw, once again, thank you for your help!
Arkadian
Old 26-01-2004   #8
rolfw's Avatar
Real name: Rolf
If you can see the cam details in the cam menu and it can see the card (you'll see it in the status section) then it probably is working.
Did you have the card in the receiver when you asked them to activate it?
Rolf
Old 26-01-2004   #9
I'm not sure if I had the card in, Rolfw. Does it make a difference?
I got today an IRDETO CAM card, but it's getting worse... The decoder most of the times does not initialise the cam, and when it does, as soon as I put in the card, the cam dissappears...
It seems that I actually have a problem with the Manhattan box, doen't it?
Being a newbie, I decided to get a Manhattan Plaza 3300 box, because it was cheap and relatively new (so I wouldn't have to do any updates). But now, I think I should have gone for a Humax (the one with the embeded Irdeto would actually be ideal for me...).
I anyone can give me some advice, I would really appreciate it!
Please help!!!
Arkadian
Old 27-01-2004   #10
rolfw's Avatar
Real name: Rolf
You have to have the card in the cam for activation Arkadian, they only send out a relatively short signal. What Irdeto CAM did you get, has it got a serial number on it?
You may need to try it again in the Matrix reloaded, but also ring them again, as long as the CAM can see the card (shows the number), you have a fighting chance.
Rolf
Old 27-01-2004   #11
The Irdeto Cam has a P/N: 901275 X
and under the bar code: 11310241129471
The CAM doesn't show any number (I have attached a screenshot)...
MR 1.04 & NOVA card (IRD2) & Manhattan 3300-1-jpg
Old 27-01-2004   #12
Just a note to say that I called NOVA and they activated the card again...
No change, none of my CAMs work with the card...
Any ideas?...
Old 27-01-2004   #13
rolfw's Avatar
Real name: Rolf
Hmm, looks like the Matrix Reloaded sees the card, do you get the same with the Irdeto CAM? Could of course just be a faulty card.
Rolf
Old 28-01-2004   #14
The Irdeto CAM cannot see the NOVA card...
Old 28-01-2004   #15
rolfw's Avatar
Real name: Rolf
Don't really know what to suggest Arkadian, I would have thought that if the MR could see the card, then the Irdeto CAM should also see it.
Rolf
Old 28-01-2004   #16
Irish Mod
Razor's Avatar
Originally Posted by Arkadian
Rolfw,
If you have any trouble finding MR 1.055, don't worry just send me an E-Mail, as I downloaded it today.
Don't mind my spelling
Razor is offline   Reply With Quote
Old 28-01-2004   #17
Hi I have irdeto 2 card from Albaniasat and thats work very good with Matrix Reload
vers.1.055 and the nova card is the same it must work
Haby is offline   Reply With Quote
Old 28-01-2004   #18
On Saturday, I will take the box and the CAMs back to the shop where I bought them. The guy suggested that we try the card on his box to see if it works there. I will come back to you on Saturday evening with the results. I think that either the box or the card is faulty...
I also called the NOVA helpline again and they said that it is possible that the card is faulty and didn't get activated (?...) and they said I should return the card to a guy in Athens for further checks...
[you would expect that when you buy a card for 330 euros for 6 months, they would have at least bothered to double-check it before they pack it...]
I will come back on Saturday to give you further info.
Rolfw, I want to thank you again for all your help these days. This forum is the best source of sat information and troubleshooting on the net!!!
Old 28-01-2004   #19
Guys, how can I update the card Matrix Reloaded without buying any extra hardware?
I had a look at the the matrixcam site, but I got the impression that I should get specialised adaptors, and Smart Card writers...
I have a laptop (with the standard pcmcia card slot) and a PC with all the usual ports...
Any ideas / advice ???
Old 29-01-2004   #20
rolfw's Avatar
Real name: Rolf
Hope it all works out, will be interested to hear your results.
I've just upgraded my Mr using my Win98se laptop and once it was setup it was easy. Go to This Thread at Toecutter's Tutut has posted a how to upgrade your laptop thread with the relevant files and there are links to the 1.055 update as well.
Rolf
Old 08-05-2004   #21
simple....upgrade mr to version 1.80....original card nova..ok
stratos.the is offline   Reply With Quote
104, 3300, card, ird2, manhattan, nova
Similar Threads
Matrix Reloaded How To by AHAC rolfw Matrix Reloaded, Revolutions and CAS interface 52 27-12-2005 12:02 PM
Irdeto2 decoder card POC? 'Legit only!' grwelch Cards & Programmers General 0 15-11-2003 11:08 AM
Which DVB card? alnitak Satellite PC Card Receivers & Internet by Satellite 4 26-08-2003 02:17 PM
Pentamedia card not initializing s*t*a*r*m*a*n Computer Discussion 1 14-07-2003 05:07 AM
new card don't work Robbiewright Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 3 25-06-2003 09:05 PM
