Help me find my boxkey MRAll information about the Matrix Reloaded and Revolutions CAMs, plus the CAS interface for programming MMs, MRs and UCAS embedded modules. | |
| Member Join Date: 16-02-2007 Location: West mids
My System: 2 Twinhan tuner |
Hi all, I'm new to this hobby so could do with some help in getting set up. I bought a secondhand Matrix Reloaded form fleabay but I can't get it recognised through my PMCIA slot on my lappy. I tried using the drivers and following the instructions here but still no joy. As far as I know, all i need is to be able to see the boxkey so I can program up a funcard with the same key - i believe everything should AU fine then. Is there any app i can use to view the boxkey on the CAM when it is placed in a DVB-C card? I thought I might be able to see it in ProgDVB or something like that but I haven't been able to. Any help much appreciated. | ||
| Regular Member Join Date: 03-04-2004
My System: Loads of stuff | make sure your receiver is on a FTA channel switch the receiver off completely (not on standby) insert CAM switch on & wait. use menu & follow till you get the CI menu up you have to scroll up I think to see the box key | ||
| boxkey |
